Old 12-07-2013, 10:58 AM   #1
eldomike OP
Who Cares
eldomike's Avatar
Oddometer: 941
Sputnik
Bought this to use on a Guzzi backroads/gravel project rig....it won't be used for real rough going....been a while since I've had a Sputnik...how are the frames on these....tough enough? Will probably replace the body with some sort of box ...
Photobucket http://tinyurl.com/oebr5yk
eldomike is offline   Reply With Quote
Old 12-07-2013, 12:13 PM   #2
nieppi
Oddometer: 114
I think the frame is good
I have broplem with wheel axel
But my driwing is guite rough
www.nieppi.com
nieppi is offline   Reply With Quote
Old 12-07-2013, 05:25 PM   #3
eldomike OP
Who Cares
eldomike's Avatar
Oddometer: 941
Ouch! Though the axle size looks about right...
Old 12-07-2013, 06:07 PM   #4
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,202
Yea but it looks like, by the road, he might just ride that GW as hard as I push my Guzzi's.
In the stable now. '76 Moto Guzzi Convert Hack
'93 Moto Guzzi Calli 3 with Leaner turned rigid
'99 WR400F
Hack build: http://www.advrider.com/forums/showt...rt+floor+build
cleatusj is offline   Reply With Quote
Old 12-08-2013, 08:04 AM   #5
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,613
Looks like the axle already had a crack in it where it's rusted.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 12-08-2013, 08:16 AM   #6
eldomike OP
Who Cares
eldomike's Avatar
Oddometer: 941
good eye, hadn't noticed that...
Old 12-08-2013, 08:18 AM   #7
eldomike OP
Who Cares
eldomike's Avatar
Oddometer: 941
Here is the other Sputnik rig I had for a little bit....wish I had saved more pics...
Old 12-08-2013, 08:20 AM   #8
Dan Alexander
Oddometer: 7,613
I really like those old Guzzi's
I still remember taking a Cali with the big fairing out for a test ride at Americade, had the biggest grin of any bike I tried (and every year I tried everything I could get my hands on)
Old 12-08-2013, 08:25 AM   #9
eldomike OP
Who Cares
eldomike's Avatar
Oddometer: 941
Me too...
here are the Guzzi Rigs I either own or have owned...
http://s106.photobucket.com/user/eld...?sort=3&page=1
Old 12-08-2013, 09:46 AM   #10
Dan Alexander
Oddometer: 7,613
Nice history, every one great in their own way
Old 12-09-2013, 12:05 PM   #11
jaydmc
Oddometer: 1,059
We imported a lot of the Sputnik sidecars, The frames are fine, The wheels are weak, Never seen an axle problem before. We have mounting hardware to work with these for many bikes. We have a very limited supply of new parts still.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jaydmc is offline   Reply With Quote
Old 12-09-2013, 01:27 PM   #12
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,269
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
I sheared the axle on the one I had on the Tiger. Later I tore the swingarm where it is squashed flat to take the axle. I replaced the wheel with something which took a bigger axle, had an axle turned to fit and installed it in some box tube which slid over the OEM swing arm and was welded in place. Never had another problem with it.
Sputniks are pretty stout and that bike was heavy and got hammered way off road. I would be surprised if there was a problem with the axle under normal use.
http://www.advrider.com/forums/attac...1&d=1014618028
" I need to stop talking and start drinking" ...Mom
RedMenace screwed with this post 12-09-2013 at 01:53 PM
RedMenace is offline   Reply With Quote
Old 12-09-2013, 02:38 PM   #13
Lee 303
razryadka
Lee 303's Avatar
Oddometer: 64
sputnik shock
I bought mine still on the shipping pallet a few years ago and changed the wheel bearings before even unbolting the frame from the wood crate. Those original wheel bearings were not up to today's or even 50 year old industry standards. I'm still using the original wheel which is somewhat roundish makes rebalancing the wheel frequent and critical. You will likely feel a small high speed head shake generated by that imbalance. For some reason the chrome adhered to the wheel rim rather than peel off in sheets as was my experience with other Warsaw pact nations products in the 70s. The stock shock absorber started banging on sharp bumps. I took it apart to find it partially filled with foul smelling mixture of rust, metallic sludge and liquid derived from what must have been the septic system of some long forgotten Gulag. My guess is whatever state owned enterprise that made lubricants supplied both the shock oil and the bearing grease. I'd rather not comment on body style or finish. The light fixtures are identical to the Ural, the tail/brake lens was busted when I picked it up, many have posted warnings they are fragile and I would agree. Don't go nuts when you tighten the screws or you will certainly break something. Lens,housing,screw in order of probability. The lens was not available seperately a couple of years ago so I had to buy the whole schmeer. That may have changed as Ural has more dealers now.
The frame is undoubtedly the best part. Safe and sound midway between a late model Velorex and a Ural for weight and capacity. Who ever welded it did a far better job than I could even hope to do. I had a Ural tub on mine for the Summer did a few dirt and gravel roads without any drama.
Lee 303 screwed with this post 12-09-2013 at 02:56 PM
Lee 303 is offline   Reply With Quote
Old 12-09-2013, 03:18 PM   #14
sidecarxer
sidecarxer's Avatar
Oddometer: 100
That axle has had a HUGE hit in the past...maybe a previous accident, and has not been checked before re-use.
Sidecar axles take a hell of a hard life and in sidecarcross they are a part that is allways checked. That and the bearings of course.
The Wasp uses a very thick axle for that very reason as they also use the single sided swingarm set-up. Check them out.
sidecarxer is offline   Reply With Quote
Old 12-12-2013, 04:08 PM   #15
claude
Sidecar Jockey
Oddometer: 3,853
We typically convert them to a one inch axle with a different wheel etc.
Claude
http://freedomsidecars.com/
Times are GMT -7.   It's 02:29 AM.
