Old 12-17-2013, 07:20 AM   #16
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,297
Originally Posted by COXR650L View Post
I really hope the pistons/jugs and heads are in good shape. Like most things this will cost more than I expected but if those items need replacing it will really drive up the cost
If the price starts going too high, remember you can always go for Plan B.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 12-17-2013, 11:21 AM   #17
DirtyADV
DirtyADV's Avatar
Oddometer: 2,284
Brand new crate engine? Or 2nd hand replacement?
If new how big was the hole in the wallet?
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 12-17-2013, 11:23 AM   #18
crazybrit
crazybrit's Avatar
Oddometer: 8,559
not new but I'm still not listening, la la .. la la .. la la .. is it over yet
Oh and Munn quoted me $3750 for a freshly rebuilt motor from KTM, not new but rebuilt with all new parts; no clue if this means the latest cases (re: Pyndon's rebuild thread which is must-read if the OP hasn't read it).
crazybrit is offline   Reply With Quote
Old 12-17-2013, 11:53 AM   #19
MortimerSickle
Semi-Adventurer
Oddometer: 12,297
/Johan
I got mine for an incredibly low price that probably couldn't be matched now, but I have seen them on Ebay for not much more than a couple grand.
The trick is to find an Adventure, rather than a Super Duke. I guess they crash more SDs; Ebay has three of them right now. The $1300 one has some case damage BTW.
If you can live with the close-ratio tranny, or want to swap gears, the SDs will work fine.
That price doesn't sound too bad (I mean, other than being a hell of a lot of money).
Four years ago, used, un-rebuilt engines were going for that, or more.
G.H.W.S. 1878-1962
Old 12-17-2013, 12:03 PM   #20
crazybrit
crazybrit's Avatar
Oddometer: 8,559
I think Dirty may well know this
Old 12-17-2013, 12:05 PM   #21
MortimerSickle
Semi-Adventurer
Oddometer: 12,297
That part was meant more for the OP.
G.H.W.S. 1878-1962
Old 12-17-2013, 12:13 PM   #22
crazybrit
crazybrit's Avatar
Oddometer: 8,559
You're supposed to be helping me to find a low-priced used motor, not encouraging a bidding war
Old 12-17-2013, 02:37 PM   #23
COXR650L OP
Oddometer: 1,509
LOL dont worry I think a used engine is out of my price range and hell $3700 for Munn is a ton more than I paid for the bike in the first place.
I am getting prices together, but ball park I should be around $800 without too much of a problem as long as the piston/cylinders and heads are reusable.
COXR650L is offline   Reply With Quote
Old 12-17-2013, 11:27 PM   #24
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,022
Head Work
Generally, with that mileage you'll find: intake valve's seats are slightly worn, guides will be in tolerance, rings will be worn, but the piston ring lands may be out of spec.
The valves are stainless, you can get them ground if the wear is not too bad. May cost you $30. Do them all.
Find a shop with a Neway Seat cutter and have them touch up the seats. May take one hour $80.
Do NOT lap the valves. That will ruin the seat shape and you'll get fast wear. The Neway system leaves the surface rough and it gets peened into the perfect shape when the engine is started.
Chemically clean the pistons then measure them. New rings are a bitch to break in on a chrome bore. Do not hone a chrome bore. I've use only fine scotch brite pads to wipe a little texture on the cylinder. Don't put any oil on the bore when you assemble, just a little on the skirt of the piston. This get the ring break-in started quicker.
Why do you think the shift drum needs replacing?
I don't see why you'll need to split the cases. This plain bearing engine will go many more miles than a roller bearing engine. It needs more oil, but it can tolerate more dirt. If you do split the cases, replace the transmission bearings, esp. the output bearing behind the CS sprocket and the bearing behind the clutch. These go first and aren't expensive.
Buy a full engine gasket kit. Way worth the money.
"Son, you can't do both"
Old 12-18-2013, 06:06 AM   #25
DirtyADV
DirtyADV's Avatar
Oddometer: 2,284
The grub screw for flywheel removal is M16 with a 2mm thread pitch.
And bolt is a M20 with a 1,5mm thread pitch.
Will add pictures once I get back home, at work now but wanted to correct previous post that was wrong as soon as possible.
/Johan
Old 12-18-2013, 06:45 AM   #26
COXR650L OP
Oddometer: 1,509
DirtAdv.....
Thanks if you have time I would really appreciate to see some pics.
Zuber.......
Thanks for the info. That makes me feel better about the potential condition of the heads and pistons. A lack of aftermarket support really makes these items expensive. I will look into finding a machine shop to grid the valves.
If I go this far I feel I may as well split the cases. One thing I want to replace is the oil pressure plunger (as documented by Pydon) as I have occasional timing chain clatter when the bike is hot.
I may leave the crank bearing as is depending on what they look like, I just did not know if that was more reliable than a ball bearing.
I was looking at the shift drum because it is an engine update. However, mostly I will have a fixed budget and will need to prioritize what I replace once I am in there. Thanks for the heads up on the output CS and clutch bearing
Old 12-18-2013, 08:39 AM   #27
DirtyADV
DirtyADV's Avatar
Oddometer: 2,284
Here grub screw can be seen:
Will upload a few more when I get home.
/Johan
Old 12-18-2013, 08:52 AM   #28
MortimerSickle
Semi-Adventurer
Oddometer: 12,297
G.H.W.S. 1878-1962
Old 12-18-2013, 04:57 PM   #29
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,022
Oil pump pressure relief is out side of the center cases.
Not aware of a shift drum upgrade. There may be an updated part, but that doesn't always mean you need it.
One more thing, pull all the oil jets and clean out the passages. Don't need to split the cases for this.
Old 12-18-2013, 07:09 PM   #30
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,866
In my case I found the parts to be cost prohibitive.
400 piston x 2, 400 cylinder x2, cam chains I don't know, valves/heads, crankshaft?.
So I bought a 10k mile engine on Fleabay.
DELTATANGO is offline   Reply With Quote
Times are GMT -7.   It's 09:32 PM.
