Old 05-29-2014, 01:30 AM   #136
avir
Oddometer: 20
ok so i finally got around to the service center to have my lead looked at for its problem with accelerating esp on hills.
it turns out that the variator was filthy.
they cleaned it out for me and the ride is much better now
they could not tell me were all the filthyness came from??? and i dont know why it wasnt taken care of at the last service that was done about a half a year ago, but they only charged me about $30 for the repair.
end good - all good
avir is offline   Reply With Quote
Old 05-30-2014, 04:19 PM   #137
DaBinChe OP
Oddometer: 1,113
The BridgeStone ML16 are going strong have almost 2k miles and they still look pretty new. Looks like they might hold up all the why thru cannonball.
DaBinChe is offline   Reply With Quote
Old 06-01-2014, 12:58 AM   #138
Inoplanetyanin
One day closer!
Inoplanetyanin's Avatar
Oddometer: 112
Your riding style is different too. You don't have as much acceleration from stop or slowing down. This is how I also put a lot of miles on tires without wearing them out too fast.
Inoplanetyanin is offline   Reply With Quote
Old 06-02-2014, 06:21 PM   #139
DaBinChe OP
Oddometer: 1,113
Just over 30k miles and changed the air filter, engine oil, spark plug, belt....getting it ready for the start of cannonball in the morning.
Old 06-06-2014, 03:55 PM   #140
DaBinChe OP
Oddometer: 1,113
So had someone tail me and they said that GPS reading is 58mph when indicated is 55mph
Old 06-08-2014, 04:37 PM   #141
Inoplanetyanin
One day closer!
Oddometer: 112
0:45 Nice white Elite 110.
https://www.youtube.com/watch?v=hyLkiCkbUjc
Ask a kid to spot the most Elites and give them something as a reward
Old 06-20-2014, 10:56 PM   #142
DaBinChe OP
Oddometer: 1,113
Over 35k miles had to adjust the valves. Exhuast was on the tight side of spec while intake was tighter then spec. This was the first time the intake has been adjusted
Old 06-25-2014, 12:20 AM   #143
Inoplanetyanin
One day closer!
Oddometer: 112
How is oil consumption? Did you add oil during the cannonball run? If so, over which interval? Which oil brand did you use while on CBR?
2010 Honda Elite 110
Old 06-27-2014, 04:46 AM   #144
Mnmsutton
Oddometer: 15
More mph
What would you recommend for more top end? Scooter has 3600 miles on orginal equipment and tires.
Take apart and clean verator, weights, sliders, and plates, verify belt width, and when comes time replace with larger tires? Clean out as much belt dust as possible. Check valves. Anything else? I have lost about 4 mph and would like to get as close to your gps verified speed as possible.
Thanks in advance for your suggestions
Mnmsutton is offline   Reply With Quote
Old 06-27-2014, 08:58 AM   #145
DaBinChe OP
Oddometer: 1,113
There isn't anything available for the nhx110 so the only choice is a larger tire. The Bridgestone ML16 4.0x10 are the best. Even now with my drive and tires worn out I still get to a 53mph indicated same speed as stock when everything is new.
Old 06-28-2014, 06:19 PM   #146
DaBinChe OP
Oddometer: 1,113
there is a little oil consumption, from the upper hash to the lower hash in 1k miles...about 50ml or so.
Over 38k miles and check the valves they are good. New air filter, old one is DIRTY. Just ordered a new variator so waiting for that to put in new belt and rollers.
Old 07-01-2014, 12:13 PM   #147
DaBinChe OP
Oddometer: 1,113
I'm gonna starting using the regular NGK high speed plugs instead of the iridium cause of the wear on the plug cap stud, it wears out long before the electrode does so would just be a waste to use iridium plugs.
Old 07-14-2014, 11:52 AM   #148
DaBinChe OP
Oddometer: 1,113
concerning oil consumption, better oil show less consumption, so synthetic like mobil 1 10w-30 extended performance, and also thicker oil shows less consumption too. At home I normally use the mobil1 extended performance 10w-30 or a diesel synthetic 5w-40 like Delo or Rottella6 but on SCBR better oil wasn't always available so I used what ever I thought was best.
Old 07-16-2014, 09:13 PM   #149
DaBinChe OP
Oddometer: 1,113
About 38,6xx miles. Put in a new variator/belt/rollers/slide guides. Prior max speed on flat was 52mph. Now with new drive parts I'm maxing out at 55mph on flat. Still on the same tires from the trip...think I can get to 40k miles on them.
Old 07-17-2014, 12:56 PM   #150
TmaxSLO
TmaxSLO's Avatar
Oddometer: 16
I have almoust 10T kilometers on my lead. I get 88 km/h (odometer) on flat (stock, nothing changed), that isnt bad ?
I m using NGK NGK high speed plug, there is no visible wear. And no oil consumption (Repsol oil for 4 stroke engine)
I almoust tread Lead for PCX 125 (2012) whit with a damaged engin (piston). About 400 EUR for repair, but in "last" minute decided to keep Lead. I do not regret the decision.
P.S. Is Cannonball finished?
TmaxSLO is offline   Reply With Quote
Times are GMT -7.   It's 05:41 AM.
