Old 12-19-2013, 06:39 AM   #1
Simple. OP
I'm Special
Simple.'s Avatar
Oddometer: 652
KTM 950 front rim question
Hate to beat a dead horse, but after reading through all of the butter Behr front rim threads, I still can't find my answer...
Will this rim: http://www.radmfg.com/DID-Original-D...ido-21x185.htm fit my stock '06 950 adv hub and spokes? I realize its a jap drilled rim, but I seem to remember someone successfully using it... I can't find the post though to confirm it ?
Jon
Sent from my SPH-L710 using Tapatalk
Simple. screwed with this post 12-19-2013 at 06:52 AM
Simple. is offline   Reply With Quote
Old 12-19-2013, 12:20 PM   #2
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,464
Jon
No, that jap drilled rim won't work. You need to buy the Euro drilled DID onl available through a KTM parts dealer.
You can have RAD Mfg supply their hub and lace the wheel up. But I've heard others complain the spacers never fit, need to be machined... And the spokes aren't as strong as the steel stock KTM ones. I did the DID swap using stock hub and spokes and it's worked really well so far as an inexpensive upgrade. When I thrash this wheel I'm going with Sun rims front and back from Buchanan... stronger then Excels.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is online now   Reply With Quote
Old 12-19-2013, 12:24 PM   #3
Simple. OP
I'm Special
Simple.'s Avatar
Oddometer: 652
Thats what I figured, i just found this... DID rim 21X185E6B01T from oemcycle.com. Fitment says 07+ 990. Wonder if that one will work?. Its only $156 online. Cheaper the better being so close to Xmas. I bent mine pretty bad on the cobdr this past September.
Old 12-19-2013, 02:01 PM   #4
EZ300
EZ300's Avatar
Oddometer: 1,109
Jon
I used that rim on my 07 990 and it was perfect.
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 12-19-2013, 02:21 PM   #5
DesertSurfer
Tail sprayin
Oddometer: 1,464
That is an XLNT deal!!!
Snap that Mofo up, like yesterday...
Old 12-19-2013, 07:20 PM   #6
Simple. OP
I'm Special
Simple.'s Avatar
Oddometer: 652
I'm on it! I'll have that puppy laced up in no time.
Thanks guys
Jon
Old 01-09-2014, 07:50 AM   #7
keener
Speed changes you.
keener's Avatar
Oddometer: 959
Can a dimpled like this one be drilled to work with larger spokes and nipples?
I have an Excel rim that is bent out of shape and is drilled and its non-dimpled.
04 ADV 950
keener is online now   Reply With Quote
Old 01-10-2014, 11:20 PM   #8
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,071
Dimpled can use the stock spokes. Non-dimpled, like the SUN, needs special spokes that are longer. You can't interchange them.
"Son, you can't do both"
Old 01-11-2014, 03:18 PM   #9
Simple. OP
I'm Special
Simple.'s Avatar
Oddometer: 652
For the record, the DID Dirtstar 21X185E6B01T wont fit a 950/990 , despite what all the online fitment guides say. Woodys hooked me up and was able to countersink/redrill it so I could still use it though. Not a total loss but still enough to be frustrating.
Jon
Old 01-12-2014, 01:38 AM   #10
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,003
So what do you say?
Jon
It can fit after widening and countersinking the spoke holes?
Old 01-12-2014, 05:03 AM   #11
Simple. OP
I'm Special
Simple.'s Avatar
Oddometer: 652
Sort of... One side of the rim laced up normal with stock spokes, the other side had the dimples pointing backwards. I sent the rim to woodys and they drilled and countersunk the rim but I still had to purchase 18 longer spokes for one side. The rim will have an x3 pattern with longer spokes on one side now, and the stock x2 pattern on the other.
I suppose I could have re-angled the spoke holes etc myself to make something work, but the cost was very minimal to have woodys do it... and my spokes and nipples were corroded, so I bought the heavy duty SS ones at the same time.
Jon
Old 01-12-2014, 05:25 AM   #12
Maoule
Maoule's Avatar
Oddometer: 526
I put a Sun 3.5" on mine with the stock spokes. What's going to happen? I've put ~1000 miles on so far.
Maoule is offline   Reply With Quote
Old 01-12-2014, 09:13 PM   #13
Dustodust
Dustodust's Avatar
Oddometer: 985
I am using a KTM 21" dirtbike indexed 36 hole Excel A-60, not one dent yet !!!! Crazy tough rim !
it had different indexing than the Adventure hub. The stock spokes will not work but offsets perfect with a spoke kit I got from CJ that he happened to have on the shelf
I was at Buchanans building a custom cush hub and they said they have the formula for making the spokes to fit an A-60 to an adventure hub
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Times are GMT -7.   It's 07:14 PM.
