Old 02-11-2014, 03:09 PM   #106
Rango
Phaneropter
Rango's Avatar
Oddometer: 1,193
I'll be ready
Moriunt omnes pauci vivunt
Rango is offline   Reply With Quote
Old 02-11-2014, 07:30 PM   #107
Twotaildog OP
Old Poop
Twotaildog's Avatar
Oddometer: 1,302
Things are looking a bit precarious at the moment...
Twotaildog is offline   Reply With Quote
Old 02-13-2014, 07:41 AM   #108
davesupreme
grand poobah
Oddometer: 1,475
nice south-bend!....
davesupreme is offline   Reply With Quote
Old 02-15-2014, 05:29 PM   #109
Twotaildog OP
Old Poop
Twotaildog's Avatar
Oddometer: 1,302
Bitsy gets a new pair of shoes.
Thanks Dave. According to the serial number it was made in the '30's. It's a handy size for making spacers and such. I have a larger one that was made in the teens that I started to restore, but the ways and all the sliding surfaces are so worn out that I pretty much gave up on it.
Between work at home and work at work Bitsy hasn't gotten as much attention as she likes, but I wanted to get her down off of the blocks and into a more stable position before I go out of town next week. A friend of mine has one of those No-Mar tire changers, so I let him mount the tires. The K70's that it had on it are good tires, when I was a kid we used to call that a "universal" tread. I had one on the front of my first dirt bike and I hated it because it wasn't as cool as a knobby. I couldn't afford a new tire and my dad wouldn't buy me one because the JC Whitney catalog said that the one I had was universal, so it should be fine for the dirt. I guess that feeling stuck with me because I like the look of the Mefo's on the Triumph a lot better:
I also scuffed up those headlight ears/fork covers that I bought with some wet-or-dry, and shot them with some Rustoleum:
While I had the front wheel off I slid the forks down, removed the 'cafe' style headlight ears that were on there and slide the proper ones in place:
I also changed the fork oil while I was in there, just so I'd know what they had. I started on the wiring but no pictures of that. I should be able to knock that out week after next.
Old 03-03-2014, 03:44 PM   #110
Rango
Phaneropter
Rango's Avatar
Oddometer: 1,193
Ehh,
What's up, doc?
No pressure, but how's e'going?
Old 03-03-2014, 04:27 PM   #111
England-Kev
Oddometer: 3,575
Originally Posted by Twotaildog View Post
I'm up in the air about whether to duplicate the air bottle, which I suppose was for airing up tires after punctures were repaired.
It would be fairly difficult to replicate.
Am I missing anything?
The air bottle is easy to find, they use the same bottle for spear fishing, scuba, paint ball, and air gunning, as can be seen here...
http://www.ebay.co.uk/itm/Theoben-Ra...-/261412645583
England-Kev is offline   Reply With Quote
Old 03-04-2014, 05:24 AM   #112
Twotaildog OP
Old Poop
Twotaildog's Avatar
Oddometer: 1,302
Originally Posted by Rango View Post
Ehh,
What's up, doc?
Sorry guys. I have gotten a little bit done, but other things have distracted me from taking pictures and posting. I will try to get a post together later today. The front end is back together, except for the fender, and I have rewired the whole bike. I ended up having to make my own clamp on cross-bar for the handle bar. I got a CR style throttle tube and took it and the carb in to have a new cable made, those are back now so I can mount them. Then all I have to do is mount the new clutch cable and the controls will be done.
Thanks for the tip on the bottle Kev.
More to come.
Old 03-04-2014, 08:57 AM   #113
Twotaildog OP
Old Poop
Twotaildog's Avatar
Oddometer: 1,302
and by the way, happy Fat Tuesday!
Old 03-05-2014, 07:37 AM   #114
Twotaildog OP
Old Poop
Twotaildog's Avatar
Oddometer: 1,302
Crossbar and Throttle
A little update on some of the small progress I've made since my last report.
I had ordered a clamp-on crossbar for the handlebar. It took a long time to arrive and when it got here I didn't like it. The crossbar was too short, so it sat too low, and the clamps had sharp edges and a generally modern, unfinished look. In the first picture below you see the short crossbar and above it is a piece of 1/2" diameter aluminum stock that I cut to roughly the length that I want the crossbar to be. The second picture is the clamps as they were when I received them, slid onto the handlebar:
I decided to fabricate my own crossbar from the piece of 1/2" aluminum stock. The process consisted of careful application of heat:
Forging the ends with a BFH:
Filing the ends to the desired shape:
And then I used some wet-or-dry sand paper to smooth the ends and drilled the holes.
For the clamps I filed the edges to round them off and give them more of a vintage look:
Then I gave everything a trial fit:
And once I was satisfied with the fit I took everything back off and polished it on the cotton wheel. Here is the result:
It was good to have the handlebar and crossbar mounted now, so I could start installing the controls. I went with one of these CR style throttles that Motion Pro makes, in chrome, to get the throttle cable up out of the weeds. I took the throttle tube and the carb to a local shop and they made me a couple of throttle cables (one for a spare) that mated the CR throttle control to the Mikuni carb:
And here is the headlight dipper/horn switch assembly installed. This is a universal unit, but it has the vintage look to it. Also note the rubber end on the clutch cable adjuster, I got that from Speed and Sport, and now I've ordered some more so I can put them on all of the cables, and also small ones that will fit on the top of the carb and on both ends of the throttle cable adjuster:
More to come...
Old 03-05-2014, 09:53 AM   #115
Twotaildog OP
Old Poop
Twotaildog's Avatar
Oddometer: 1,302
Wiring
I don't very have many pictures of this, but I spent a lot of time on it. It turns out that moving the key switch/light switch from the headlight shell to the left sidecover, near to the battery, allows you to simplify the wiring harness a bit.
I have an original Triumph key switch but it has high resistances in some of the contacts, and the key is similar to a Sampsonite suitcase key from the '80's; they are all the same and none of them are very secure. You can turn the original key switches with a screwdriver or hairpin. I'm using an aftermarket key switch that is made for Sportsters, it has a round key and three positions. The switch above it is an original Triumph lighting switch, it is not wired to anything, it's just there to fill the hole. I was going to use it but again, it had high resistances across some of the contacts, so I didn't. I may replace it with a BMW/John Deere style accessory plug. Pictures of the switches:
I wired the ignition switch as follows:
Position 1 - everything is OFF
Position 2 - power to the Pazon electronic ignition, power to the brake light switches, power to the horn button.
Position 3 - power to everything in position 2 plus the headlight and taillight.
I installed a fuse block under the seat. It eliminates the in-line fuses and it also functions as a terminal block and eliminates most of the bullet connectors, and generally helps to organize things. Here is a picture of the fuse block:
The wires in the headlight shell went from this:
To this:
That's about it for now, other than replacing cables etc. I hope to get started on the fenders soon but it's getting into the busy season at work. We'll see. Thanks for listening.
Old 03-05-2014, 05:59 PM   #116
Rango
Phaneropter
Rango's Avatar
Oddometer: 1,193
Neat, neat.
Quite a sandwich
Cool how you turned the crossbar around from awful to a jolly pretty.
Old 03-05-2014, 06:17 PM   #117
k-moe
Oddometer: 2,645
What, What!? A headlight bucket with just the wires for the headlight? Heritic!!
Looking fantastic
k-moe is online now   Reply With Quote
Old 03-07-2014, 09:27 AM   #118
groop
So much to ponder
groop's Avatar
Oddometer: 3,246
I zinc plated them so they wouldn't rust:
I am still watching this build closely as I have finally started my 67. How do you like this little plating kit from Eastwood? I am considering it too but the online reviews are mixed. The hardware on my bike is rust-free, but dull and I want to make it look new but not overly polished. Would you recommend the $70 Eastwood kit?
Because you cannot eat a salad with a spork.
groop is offline   Reply With Quote
Old 03-07-2014, 09:47 AM   #119
Twotaildog OP
Old Poop
Twotaildog's Avatar
Oddometer: 1,302
The Eastwood kit is probably a little overpriced for what it is. I suspect that if a person did a little research, he could put together a similar system for less money. It's just an electrolyte bath with a piece of zinc hanging in it, an alligator clip for the zinc, one for the piece being plated, a couple of lengths of wire, and a current source. It also comes with protective eye wear and a pair of gloves, but most of us have that stuff already.
The downside of this system is that you can only plate one piece at a time, because you have to clip the little alligator clip to it. If you have a bunch of fasteners and hardware to plate, my opinion is that you would be better off just taking them to a plater, especially if you have one locally. Some of them just charge by weight, so you can take a coffee can full of hardware in to them and get a pretty good price and probably a better job. The risk is that there is always a small potential that they could lose one of your parts. If you're working on a '67 Triumph, there aren't many parts that couldn't be replaced if they were lost. If you were working on a 100 year old bike, I'd worry about it more.
What I like this system for is when I fabricate a bracket or something and it involves cutting something that was originally plated, I can plate the cut surface and prevent it from rusting.
Hope this helps...
Twotaildog screwed with this post 03-07-2014 at 11:06 AM
Old 03-07-2014, 10:45 AM   #120
ttpete
Rectum Non Bustibus
Oddometer: 5,840
Dog, I just bought a book that's recently been released called "Triumph Experimental". It covers their experimental shop during the 60s and 70s and has detail on the factory competition bikes. There's a nice color pic of Norman Hyde with McQueen's ISDT bike. It's a bit pricey, but to me, it's worth it.
It's sold by Motorsport Publications here in the US. This firm also acts as an agent for subscriptions for British motorcycle magazines. I bought a sub for Bike magazine, and it cost half of the news stand price.
http://classicbikebooks.com/catalog/...74hhuvi35u9ps2
15 BMW RnineT
09 Kaw Versys
ttpete is online now   Reply With Quote
Times are GMT -7.   It's 09:35 PM.
