Old 12-24-2013, 07:55 PM   #1
revtech100 OP
Oddometer: 195
Ural tools
Any recommendations for tools to add to the standard Ural set?
The bike was the cheap part. The divorce it caused cost a little more.
2011 R1200GS Triple Black, 2003 Harley Ultra Classic
2000 Custom Chopper, 2011 KLR650,
2011 Kawasaki 110, 2013 Ural Gear Up
revtech100 is offline   Reply With Quote
Old 12-24-2013, 09:48 PM   #2
FLYING EYEBALL
out of step
FLYING EYEBALL's Avatar
Oddometer: 10,561
Bfh
if you keep poor...the struggle is simple
my photos http://jskustoms.smugmug.com/
save yourself some $ with my smuggy discount code qvMaWy1bTFU7c
FLYING EYEBALL is offline   Reply With Quote
Old 12-25-2013, 02:21 AM   #3
UralNorm
UralNorm's Avatar
Oddometer: 46
A second 17mm spanner is needed to loosen pinch bolts on both front and rear axles. And a hammer.
UralNorm is offline   Reply With Quote
Old 12-25-2013, 03:46 AM   #4
tbird649
tbird649's Avatar
Oddometer: 172
Originally Posted by FLYING EYEBALL View Post
Bfh
tbird649 is offline   Reply With Quote
Old 12-25-2013, 03:51 AM   #5
tbird649
tbird649's Avatar
Oddometer: 172
Extras
I've also got extra bits like spare tube and tyre levers (for front flat) cable ties, tape, wire etc. I always think the more bits you carry the better. Sods law says you wont need it yourself, but you can maybe help someone else, and that builds up some protective Karma!!! (I like to dream, and it is Christmas!)
Old 12-25-2013, 05:41 AM   #6
Unstable Rider
corn and tornadoes
Unstable Rider's Avatar
Oddometer: 2,544
A small socket set (1/4 drive) with a couple short to medium extensions, and a set of open-end, box-ended wrenches in a tool roll of your bike's common sizes make most roadside repair disasters better. A mid size crescent wrench not a bad idea either. Hockey stick or baseball bat tape works better than electrical tape in my book, especially for electrical temp-repairs. Some wire and JB (fast) weld wont hurt.
I like the Karma comment as well, I gave a guy some blue Loctite once, he was loosing his shifter. I had good riding after that.... no breakdowns!
Unstable Rider is offline   Reply With Quote
Old 12-25-2013, 07:04 AM   #7
rg, sw wa.
Oddometer: 272
A “VOM” from Harbor Freight, (pack one on each of your bikes), the smallest scissor jack you can find, a couple of good tie downs (I like Ancra tie downs),
small air pump, (Slime makes a nice small one), extra fuses,
It’s early an only had a half a cup of coffee. After my second cup I will come up with a few other things ?
Have a Merry Christmas and a Happy New Year,
rg, sw wa. is offline   Reply With Quote
Old 12-25-2013, 07:04 AM   #8
davide
Oddometer: 289
Here is my 2 cents for whatever they are worth...
Whenever I take off for an extended adventure (no matter what the mc is) I take 4 "kits" with me:
-Standard Tool Kit that came from manufacturer (when they do supply it... My '06 Triumph Scrambler came with a very basic kit: 1 allen wrench!)
-Augmented Standard Tool Kit which is basically my way to implement the standard kit with ratchet wrenches/bits, fixed wrenches (for those jobs that require 2 wrenches when the standard kit only supplies one, like UralNorm pointed out), 2 adjustable wrenches (medium/small), rubber mallet
-Tire Kit that contains a set of tools/supplies I like to have ready to go should I need to fix a flat on the side of the road
-Spares Kit where I pack assorted bits needed to get going again like fuses, spare bulbs, a carb rebuild kit (if the bike is carbed), assorted connectors, fastners, clamps, oil and fuel filters, fuel line, tape... basically anything that your own mc has taught you she might need. An old school Triumph has different needs than, let's just say, a UJM.
The interesting aspect of a rig is that you have extra space and the extra weight can actually be your friend acting as ballast on a solo trip. Once I split in an old VW bus with my 3 dogs on a trip to nowhere that snowballed into 7 years off the grid which then led to 4 more on a bicycle in Mexico and Central America once the old dogs had all passed on, but I digress... Anyway, the point I was trying to make is that there are similarities with a Ural rig and a VW bus: with both you can be totally self contained in terms of equipment, both need to be driven within their limitations, both can be fairly easy to diagnose and fix even in low-tech countries/situations, both "force" you to slow down a little, not only interms of driving speed, but also in terms of velocity of life. Both trigger positive reactions in the general public. You can stroll around the world, knowing that you are completely self contained and when a small problems arises, you simply pull over, relax, take in the scenery and proceed to address it. Often, this leads to great encounters, fun and or aggravating times and, generally, it makes the trip more memorable...
davide is offline   Reply With Quote
Old 12-25-2013, 10:01 AM   #9
on2wheels52
Oddometer: 2,440
Great post davide
I like the line "can usually be repaired with items found in the average kitchen drawer" (though I think they were talking about old British bikes).
Jim
R1200GS Ural Patrol KLR650 DRz400 XL185
Austria '08 http://www.advrider.com/forums/showthread.php?t=352082
Back to the Alps in '11 http://advrider.com/forums/showthread.php?t=744205
on2wheels52 is online now   Reply With Quote
Old 12-25-2013, 10:17 AM   #10
out rider
Nearing the end
out rider's Avatar
Oddometer: 612
Cell phone and a buddy with a large trailer.
out rider is offline   Reply With Quote
Old 12-25-2013, 10:24 AM   #11
revtech100 OP
Oddometer: 195
Damn! Got the buddy with the trailer, but no cell coverage in 98% of the areas I'll be riding in.....maybe I can get a sat phone.
Old 12-25-2013, 11:27 AM   #12
FLYING EYEBALL
out of step
Oddometer: 10,561
I recently narrowed it down to this
jack, tire spoons and some other bits not pictured.
what I took out
Old 12-25-2013, 11:54 AM   #13
Prmurat
Prmurat's Avatar
Oddometer: 1,021
Is this the VOM??
http://m.harborfreight.com/1-1-2-hal...ack-66907.html
I have one from a small Toyota in the Ural but I am looking for a Porsche one to get in the HD: so light, cute and... Expensive!!
Prmurat is offline   Reply With Quote
Old 12-25-2013, 11:56 AM   #14
teamgrizzly
Even more advanced n00b!
teamgrizzly's Avatar
Oddometer: 384
Standard Russian Iron Toolkit:
1.) Big Hammer
2.) Small Hammer
3.) Spare Hammer
4.) Vodka
A VOM is a Volt-Ohm Meter. Get a small cheap digital one and you're OK. Analog meters can be hard to read. Mostly you'll be checking for voltage and continuity. If you're creative then you can do this with a chunk of wire and a light bulb.
The stuff listed above is good, but I would tend to go for tools with multiple bits, etc to keep down on size & weight. I also take a electric air-pump. A friend had his Ural pump fail on him. Also spare tubes and patches is good too. Also tubes of Loctite, JB Weld, and glue are handy to have, as well as the obvious electrical and duct tape. Also I carry a USB memory stick with the service manual on it, and any other information on the bike such as part numbers, in PDF format. I also keep this information on my iPad as well.
So far reverse voodoo has worked for me.
Mike
Motorcycle nut in the Pacific Northwet - Teamgrizzly.ca Twitter: @TeamGrizzlyCA
Owner of 'Katyusha" my 2013 Ural Gear-Up. Proudly falling down the horsepower ladder, and having fun at the same time
6 Bikes, 1 Garage. Holy crap, I`ve turned into motorcycling`s equivalent to the crazy ol`cat lady.
teamgrizzly screwed with this post 12-25-2013 at 12:13 PM
teamgrizzly is offline   Reply With Quote
Old 12-25-2013, 12:13 PM   #15
usgser
Oddometer: 2,225
The stock kit actually works pretty well for most maint/servicing chores. I also carry a 3/8 drive set and a set of ratcheting box end combo wrenches. Not needed but convenient for me. The stock tools aren't snap-on quality but adequate. The only really junk parts of the kit I replaced were the allen wrenches. They're horrible. Lotsa tools in addition to the kit make life easier but not absolutely needed. A VOM or DMM (Volt Ohm Meter or Digital Multi Meter) is a must have for diagnosing elect issues. You don't need a mega buck Fluke DMM to carry in your tool bag (nice for your shop though) for road repairs a cheap $20 DMM is all you'll need.
On a side note: I'm a big fan of a 3rd tire iron.
usgser is offline   Reply With Quote
Times are GMT -7.   It's 06:27 AM.
