Old 12-25-2013, 12:48 PM   #16
davide
Oddometer: 285
Originally Posted by teamgrizzly View Post
standard russian iron toolkit:
1.) big hammer
2.) small hammer
3.) spare hammer
4.) vodka
mike
#4):
davide is offline   Reply With Quote
Old 12-25-2013, 02:36 PM   #17
Gasket
Wandering Samurai
Oddometer: 201
Originally Posted by FLYING EYEBALL View Post
I recently narrowed it down to this
jack, tire spoons and some other bits not pictured.
what I took out
I like that you've included a mallet. I have memories of being out in the middle of nowhere and trying to find a suitable rock to do a bit of pounding on a sticky bolt.
Mike
Port Orchard, WA
2002 Harley Super Glide
1967 Triumph TR6C
1957 Triumph 650 Flat Tracker
Gasket is offline   Reply With Quote
Old 12-25-2013, 03:32 PM   #18
hsblue
hsblue's Avatar
Oddometer: 109
Originally Posted by usgser View Post
I'm a big fan of a 3rd tire iron.
Make mine a big one http://www.amazon.com/Motorcycle-Ste.../dp/B004MBJRSO
Henry
hsblue is offline   Reply With Quote
Old 12-25-2013, 04:18 PM   #19
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,909
Don't know much about this topic as I've only ridden once with a guy who's Ural broke down. But on that occasion he needed a hacksaw to get it going again. He borrowed mine.
WUMPA
Sidecardogs.com
DRONE is online now   Reply With Quote
Old 12-25-2013, 08:21 PM   #20
ridenfly
Oddometer: 110
Remove centerstand. A leftover from the two wheel days. Get a small bottle or scissors jack. Soft ground, sloping ground, almost anywhere off road the centerstand is useless.
A proud member of the Patrol Patrol
2003 Ural Patrol "Goslovna"
1987 SP200
ridenfly is offline   Reply With Quote
Old 12-25-2013, 08:29 PM   #21
norton(kel)
vintage
norton(kel)'s Avatar
Oddometer: 1,208
[QUOTE=teamgrizzly;23064511]Standard Russian Iron Toolkit:
1.) Big Hammer
2.) Small Hammer
3.) Spare Hammer
4.) Vodka
+ large quantities of mood elevating drugs
norton(kel) is offline   Reply With Quote
Old 12-26-2013, 04:14 PM   #22
warkshop
uncbob
warkshop's Avatar
Oddometer: 592
norton you only missed one thing,,,the trailer with the spare engine. They say if you have one you'd never need it.
"The business of life is far too important to take seriously" Oscar Wilde
http://www.warkshop.com
warkshop is offline   Reply With Quote
Old 12-27-2013, 12:34 AM   #23
tbird649
tbird649's Avatar
Oddometer: 172
Lucky he had the right tool for the job, ie a HACKsaw not a solosaw
tbird649 is offline   Reply With Quote
Old 12-28-2013, 12:08 PM   #24
Thermos
Thermos's Avatar
Oddometer: 240
I disagree.
The center stand is very good. Most people ride on pavement. For when I don't, I carry a couple of 2 by 4's that I could use under the center stand in the dirt.
Carry a scissor jack also. Don't remove the centerstand.
-T
Thermos is offline   Reply With Quote
Old 12-28-2013, 02:15 PM   #25
ridenfly
Oddometer: 110
Not to totally disagree with you but have you tried to get the bike on the stand on a 2x4 in the dirt? It's hard to get the bike on the stand on the garage floor. And how do you get the hack or front wheel off while on the road shoulder. I am glad you carry a scissors jack. Happy New Year
1987 SP200
Old 12-28-2013, 03:21 PM   #26
Thermos
Thermos's Avatar
Oddometer: 240
Sure have. Roll the pusher back over the first 2 x 4, then up onto a set of 2 x 4 ' s nailed together. Pull down center stand onto the first 2 x 4 and it's easy. As far as a garage floor, that is easy also. You could go the easy way and use the 2 by 4 method , but usually I just put it on a centerstand. Remember to have one foot on the stand, then with a motion like you are trying to pull the bike over the side car, it should pop up.
As far as the front, put bike again on center stand, push the bike back so it's on the pusher, then prop 2 by 4 under the oil pan area. As for sidecar, I just lift it and let it rest on the engine guard.
Always an easy way.
If you like jacks, that's cool, but I feel pretty secure most of the time without. (I still have on just in case)
Sent from my SCH-I545 using Tapatalk
Old 12-28-2013, 05:07 PM   #27
Rango
Phaneropter
Rango's Avatar
Oddometer: 1,200
No fuzz
No need for center stand or 2 by 4's:
Parking in dirt as displayed on the home site
There is also a less extreme way, which is often demonstrated at biker fairs.
I spent too much time searching a picture. It's titled "Billy G and Odin show Ural parking". Maybe someone knows where that pic is?
Moriunt omnes pauci vivunt
Rango is offline   Reply With Quote
Old 02-11-2014, 12:20 PM   #28
swoody126
swoody126's Avatar
Oddometer: 425
a coupla tools i have adapted for DS riding
one is a set of tyre i-rons made from LONG combination HF wrenches(axle nut size), by cutting off the open end(@ a length that fits into my kit bag) & grinding a hollow in it
another is a JACK STAND, made from the adjustable portion of an aluminum crutch
a hammer driven IMPACT DRIVER, w/ an assortment of bits, similar to
http://www.sears.com/search=hammer%2...oRedirect=true
a smaller one is available @ HF, butt i couldn't find a link
a 12v ICE PICK TEST LIGHT, that lives in a small piece of aluminum tubing, to reduce the possibility of it getting smashed
http://www.harborfreight.com/automot...ter-30779.html
as above, a smaller one is available @ HF
JUMPER CABLES, 10ga x 6'+, W/ A-DAPT'R to BATTERY TENDER plug
many sources, if you don't make your own
12v AIR COMPRESSOR, w/ A-DAPT'R to BATTERY TENDER plug
i use AEROSTITCH brand, that comes w/ proper plug
5A FUSE IN BATTERY TENDER PLUG, to handle extended use/heat build up
i keep finding items i wish i had in my kit
this is a KIT IN THE MAKIN
sw
"Life isn't about waiting for the storm to pass,,it's about learning to ride in the rain."
swoody126 is offline   Reply With Quote
Old 02-24-2014, 01:27 AM   #29
leethal
3 wheel Monarch #37
Oddometer: 159
I needed a crankshaft bearing puller during a 9500km ride........!
leethal is offline   Reply With Quote
Old 03-02-2014, 08:31 AM   #30
exhaust_nut
exhaust_nut's Avatar
Oddometer: 191
I have zip ties, quick steel, safety wire, & duct tape in mine. Can fab &/ or reattach most parts.
Do not lean to turn the sidecar rig as you would on a solo motorbike, advises Jim Davis in the magazine "Popular Science."
exhaust_nut is offline   Reply With Quote
Times are GMT -7.   It's 10:42 AM.
