Old 01-10-2014, 03:24 PM   #16
SloMo228
World Class Cheapass
Oddometer: 1,729
I like this build, but it's making me a bit sad because I recently missed out on a $400 GS500E from my local CL. Would have made a great cheap commuter.
--------------------------- Steve----------------------------------------
'93 GL1500 frankenbike basketcase in progress
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 01-14-2014, 07:59 PM   #17
Scubawerx
Scubawerx
Oddometer: 202
Good build. Good pics. Keep it coming.
Scubawerx--Underwater Search Salvage and Recovery
Scubawerx is offline   Reply With Quote
Old 01-14-2014, 08:37 PM   #18
Navin
Navin's Avatar
Oddometer: 7,841
Did you add a tube with those Shinkos?
Navin is offline   Reply With Quote
Old 01-14-2014, 08:47 PM   #19
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 2,454
Nice!
Jonathan
If guns are outlawed, only outlaws will have guns.
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is offline   Reply With Quote
Old 01-14-2014, 09:27 PM   #20
valvesprung OP
Oddometer: 57
I did. Many opt not too, and while I understand the reasons for not doing it, I just can't get passed them being built for a tube. If this was a primarily low speed off road bike I'd not worry so much, but I intend to road trip a bit on the highway.
valvesprung is offline   Reply With Quote
Old 01-14-2014, 09:31 PM   #21
valvesprung OP
Oddometer: 57
I got the Shinko mounted up onto the dual disc 17x3.5" SV650 front wheel. I also got the SV front end pulled from the SV and ready for a quick tune up before installing. It's about time to load this beast up to head over for some steel fab!
Old 01-15-2014, 05:29 AM   #22
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,309
You won't have any issues running tubeless on those tires.They will last longer without a tube.The theory is the tires get hotter with tubes, and the tube allows the tire to flex more for the same amount of air pressure as tubeless.I don't know if it's true, but It's a bitch to dismount tube type tires, on GS rims, in the middle of no where, in the rain, with speeding traffic.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 01-15-2014, 09:21 AM   #23
Navin
Navin's Avatar
Oddometer: 7,841
Thanks for the tube info!
Old 01-15-2014, 11:47 AM   #24
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,309
You're welcome.
Old 01-15-2014, 12:49 PM   #25
Navin
Navin's Avatar
Oddometer: 7,841
Any chance you might run a tape measure across that front tire to give me the actual width? I'm fooling with the idea of riding my Ninja 300 in a easy NJ DS in the sandy Pine Barrens and would just slap a set of those on if I did it.
It looks huge so I'd just be worried about clearance with the fork tubes. The front is a 4.60, right?
Thanks.
Old 01-15-2014, 01:47 PM   #26
valvesprung OP
Oddometer: 57
Thanks.
I would run a 3.0x17 front and 4.60 rear for that application. It's what I almost went with until I went to wider wheels. I'll happily measure the tire, but I don't think the ninja runs. 3.5" wheel, but rather a 3.0".
Old 01-15-2014, 02:04 PM   #27
FTL900
White and nerdy
FTL900's Avatar
Oddometer: 268
Subscribed!!
Ya know, I saw this Yamaha Bolt scrambler conversion in a thread (on the Superhawk forum) yesterday, and honset-to-God, the first thought in my mind was how cool that would be to do with a GS500!
I can't wait to see how the final product turns out!
The older I get, the faster I used to be.
1999 ZRX1100
FTL900 is offline   Reply With Quote
Old 01-15-2014, 05:49 PM   #28
Navin
Navin's Avatar
Oddometer: 7,841
Yep, pretty sure it is a 3" front rim. I wasn't sure if that might be too thin, no real experience with this adaptation. Thank you again!
Old 01-15-2014, 07:15 PM   #29
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,309
Stock GS is 3.0 front and 3.5 rear.You can do a post Katana (98-06) Wheel swap and get 3.5 front and 4.5 rear.it's a direct swap in the rear and use GS wheel bearings and spacers in the front.
Old 01-16-2014, 12:46 AM   #30
valvesprung OP
Oddometer: 57
That's what I've done here, but with an SV front wheel.
As for the 3.00x17 on the 3" rim, it's a common swap for the supermoto crowd. Just google 3.00x17 Shinko 244" and you'll find links.
Times are GMT -7.   It's 10:28 PM.
