Go Back   ADVrider > Riding > Trip Planning
Old 01-03-2014, 09:52 PM   #16
oneway OP
Oddometer: 393
trying a different size picture here......
The shock is back. sent off Friday, returned by Thursday. And that's over the New year holiday. Rod at top gun emailed me and said the shock was about half worn, easy to compress and a little quick on the rebound. He estimated about 10-15 thousand left on it or rebuild for an estimated 30,000 miles. I opted for the rebuild. The total job, spring, rebuild, and shipping back $217.50
They also sent back the old seal head and piston O-ring.
oneway is offline   Reply With Quote
Old 01-03-2014, 09:59 PM   #17
oneway OP
Oddometer: 393
I've heard the KLR leaves the factory light in the grease department on the swing arm, so I'm going to take it off and have a look.
Old 01-03-2014, 10:01 PM   #18
oneway OP
Oddometer: 393
There's enough room to just move the spring out of the way, but I'm gonna take it off to get it out of the way.
Old 01-03-2014, 10:04 PM   #19
oneway OP
Oddometer: 393
This nut comes off, and bolt removed.
Old 01-03-2014, 10:05 PM   #20
oneway OP
Oddometer: 393
Of course, the normal stuff first. Remove brake caliper and tie it out of the way.
Old 01-03-2014, 10:07 PM   #21
oneway OP
Oddometer: 393
And remove the axle bolt, etc.
Old 01-03-2014, 10:09 PM   #22
oneway OP
Oddometer: 393
Like so.
Old 01-03-2014, 10:10 PM   #23
oneway OP
Oddometer: 393
Now the swing arm
Old 01-03-2014, 10:12 PM   #24
oneway OP
Oddometer: 393
It's out. Let's have a closer look.....
Old 01-03-2014, 10:14 PM   #25
oneway OP
Oddometer: 393
The bolt shows some corrosion.....
Old 01-03-2014, 10:16 PM   #26
oneway OP
Oddometer: 393
The bearings turned easy, but needed some grease!
Old 01-03-2014, 10:21 PM   #27
oneway OP
Oddometer: 393
The inside is corroded, but the outside bearing surface is fine. I clean up the inside where the bolt slides through with some 400 grit, then 180 grit, then steel wool. This bike had 3600 miles on it, was ridden in fair weather, and garaged. Of course it was washed a few times. What does yours look like?
Old 01-03-2014, 10:23 PM   #28
oneway OP
Oddometer: 393
a little elbow grease here. I did all of them this way
Old 01-03-2014, 10:25 PM   #29
oneway OP
Oddometer: 393
here's the bolt for the lower shock pivot mount. It's got to come out.
Old 01-03-2014, 10:26 PM   #30
oneway OP
Oddometer: 393
here is the shock pivot.
Times are GMT -7.   It's 07:55 AM.
