Go Back   ADVrider > Riding > Trip Planning
Old 01-03-2014, 10:29 PM   #31
oneway OP
Oddometer: 393
See the bolt and the corresponding corrosion? Starting to see a pattern here?
oneway is offline   Reply With Quote
Old 01-03-2014, 10:30 PM   #32
oneway OP
Oddometer: 393
well.......more corrosion.
Old 01-03-2014, 10:31 PM   #33
dksd39
Oddometer: 32
your looks great...I pulled my swing arm about 2 months ago and I was shocked. My 06 has a bit over 26k on the clock and it was in dire need of some love.
dksd39 is offline   Reply With Quote
Old 01-03-2014, 10:32 PM   #34
oneway OP
Oddometer: 393
and low on grease. definitely a pattern.
Old 01-03-2014, 10:34 PM   #35
oneway OP
Oddometer: 393
After some research, here's what I settled on for grease.
Old 01-03-2014, 10:35 PM   #36
oneway OP
Oddometer: 393
I spent as much time as it took to really work it in the bearings.
Old 01-03-2014, 10:37 PM   #37
oneway OP
Oddometer: 393
Old 01-03-2014, 10:39 PM   #38
oneway OP
Oddometer: 393
And a light coat of grease on the bolt upon reassembly. Six bearings...3 on the shock pivot, and 3 on the swing arm.
Old 01-03-2014, 10:43 PM   #39
oneway OP
Oddometer: 393
Return the shock pivot to its normal upright position. If you have any problems, loosen the lower engine mount bolt shown just above where the pivot goes. It will slide right in.
Old 01-03-2014, 10:45 PM   #40
oneway OP
Oddometer: 393
Now reinstall the shock.
Old 01-03-2014, 10:46 PM   #41
oneway OP
Oddometer: 393
Old 01-03-2014, 10:48 PM   #42
oneway OP
Oddometer: 393
Evidence that the chain has tangled with this cap off. I'll have to address this.
Old 01-03-2014, 10:49 PM   #43
oneway OP
Oddometer: 393
The chain needs some attention before the swing arm goes back up.
oneway screwed with this post 01-04-2014 at 07:30 AM
Old 01-03-2014, 10:52 PM   #44
oneway OP
Oddometer: 393
I have a 16 tooth sprocket that just came in, but I want to reassemble with the stock 15 tooth first to get some base data to compare to.
Old 01-03-2014, 10:53 PM   #45
oneway OP
Oddometer: 393
Shock adjustment instructions
Times are GMT -7.   It's 04:32 PM.
