Go Back   ADVrider > Riding > Trip Planning
Old 01-04-2014, 02:49 PM   #61
oneway OP
Oddometer: 399
Time to take the side panels off and access some stuff
oneway is offline   Reply With Quote
Old 01-04-2014, 02:50 PM   #62
oneway OP
Oddometer: 399
I have a moose air filter to go in there
Old 01-04-2014, 02:52 PM   #63
oneway OP
Oddometer: 399
Remove the tank shrouds to remove the tank.
Old 01-04-2014, 02:55 PM   #64
oneway OP
Oddometer: 399
You want to remove the bolts, not the screws on this side. On the other side remove the screws closest to the frame.
Old 01-04-2014, 02:57 PM   #65
oneway OP
Oddometer: 399
The tabs stay with the shroud. and then you just pop the other tab from the rubber grommet.
Old 01-04-2014, 02:59 PM   #66
oneway OP
Oddometer: 399
Remove the fuel line. It's a vacuum petcock, so it shouldn't drip. Mine didn't.
Old 01-04-2014, 03:00 PM   #67
oneway OP
Oddometer: 399
Remove the vacuum line from the back of the petcock.
Old 01-04-2014, 03:02 PM   #68
oneway OP
Oddometer: 399
Here's a better view of the rear of the petcock and the vacuum line attachment point.
Old 01-04-2014, 03:04 PM   #69
oneway OP
Oddometer: 399
2 bolts hold the tank on.
Old 01-04-2014, 03:05 PM   #70
oneway OP
Oddometer: 399
I like to put all threaded bolts/nuts/screws back where I found them. They don't get lost and they are where you need them upon reassembly.
Old 01-04-2014, 03:07 PM   #71
oneway OP
Oddometer: 399
Lift off the tank and find a safe place to set it.
Old 01-04-2014, 03:09 PM   #72
oneway OP
Oddometer: 399
While you're here, an easy upgrade is a metal fan. I did mine earlier.
Old 01-04-2014, 03:11 PM   #73
oneway OP
Oddometer: 399
I removed the radiator guard screen
Old 01-04-2014, 03:13 PM   #74
oneway OP
Oddometer: 399
I also removed the coolant reservoir cover.
Old 01-04-2014, 03:14 PM   #75
oneway OP
Oddometer: 399
My coolant looks good.
Times are GMT -7.   It's 06:52 AM.
