Old 01-01-2014, 08:28 PM   #1
sstewart OP
sstewart's Avatar
Oddometer: 1,058
Horsepower
What set-up will gain the most hp on a 2013 990Adventure?
sstewart is offline   Reply With Quote
Old 01-01-2014, 09:42 PM   #2
paturoa
paturoa's Avatar
Oddometer: 266
Swap it for a 1190?
paturoa is offline   Reply With Quote
Old 01-01-2014, 09:43 PM   #3
Eldon
950 ADV
Eldon's Avatar
Oddometer: 509
A turbo and some nitrous oxide
05 KTM 950 ADV Black (FOR SALE)
06 YZ250 Smoker
Eldon is online now   Reply With Quote
Old 01-01-2014, 09:48 PM   #4
Denalidirt
High Plains Drifter
Denalidirt's Avatar
Oddometer: 924
imo
intake and exhaust.
Denalidirt is offline   Reply With Quote
Old 01-01-2014, 11:10 PM   #5
tinwelp
Professional Idiot
Oddometer: 166
You could do worse than than take a peek at Gregor's thread... you'll need a few days spare to read it all, but there's a lot of very interesting information in there.
If you've not the time, the short version is an open exhaust with less restrictive collectors, convert to FCR 41 carbs and fit appropriate 'velocity stacks'... probably more too, but I forget more than I remember these days.
The thread is here http://advrider.com/forums/showthread.php?t=461267
Cheers... Paul
tinwelp is offline   Reply With Quote
Old 01-02-2014, 05:53 AM   #6
charlie264
charlie264's Avatar
Oddometer: 8,324
Super Duke cams...
Old 01-02-2014, 05:54 AM   #7
Katoom72
Katoom72's Avatar
Oddometer: 900
Even better, look for a '08 SDR engine.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 01-02-2014, 07:30 AM   #8
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,822
Interesting question. Horsepower is an engineering term. A theory.
If the true question is "how can I make my bike go faster" the answer is almost universal:
Training and practice.
One could certainly make an argument for better suspension as well.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 01-02-2014, 09:03 AM   #9
sstewart OP
sstewart's Avatar
Oddometer: 1,058
Horsepower
I want to know,what exhaust,what intake,and which map?
Old 01-02-2014, 12:49 PM   #10
srad600
srad600's Avatar
Oddometer: 674
...awesome responses...
My thoughts:
Intake - Foam Filter (Either SW7 of CRP Fab)
Exhaust - Lighter/Free flowing (Wings, LeoVince, Akras, etc...)
Mapping - Use Tune ECU to turn off EPC, Powertripp Map worked best on My bike.
These combined modifications will make the bike breathe much better all around.
srad600 is offline   Reply With Quote
Old 01-02-2014, 01:15 PM   #11
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Yup the three that will gain you the most without spending thousands are:
-Rottweiler Air Filter Intake System
-Free-flowing exhaust (Akra, Leo Vince, FMF, etc.)
-Re-map of ECU (preferably by a pro dyno shop or by using Power Commander V with Auto Tune module. (Tune ECU is the cheap but also effective route)
The combination of these three, of course done properly, will gain you 12 or 13 horsepower. Again, depending how correctly you do it, you'll go from a bike with 113 hp stock to a bike with 125 or 126 hp.
In my opinion, any sub 500lb bike with over 100hp is more than enough for the average joe. But for those of us who want more for less than $1,000, doing the above mods will not only gain you 12 or 13 hp, it will substantially increase your power to weight ratio, which is what in the end matters most. You can talk horsepower all day, but if your weight goes up linearly with your horsepower, performance gains are nil. That's what kills me about the horsepower wars with adventure bikes these days. The horsepower is what's going up, yes, but you also gain quite a bit more weight on these new 'huge class' adventure bikes as well. Therefore the overall performance gains are not quite as stellar as they'd lead you to believe. It's all marketing. And all the manufacturers want you to hear is HORSEPOWER!
Now, on the other hand, if you drop weight while adding horsepower, that's where real performance gains occur. Adding 12-13 hp while dropping 12-15 lbs by getting a lighter exhaust system and installing the Rottweiler intake system, which removes 6 or 7 lbs of SAS junk, is what will do this for you.
Adding hp while staying the same weight will never give the performance gains that adding hp and losing weight will.
Of course the cheapest performance gain is to lose some body weight! Myself included!
Cheers and good luck.
Old 01-02-2014, 03:21 PM   #12
sstewart OP
sstewart's Avatar
Oddometer: 1,058
Exhaust
Cans or Rottweiler full exhaust? Anyone know the gains of the full?
Old 01-02-2014, 03:34 PM   #13
Bigolphish
That guy
Oddometer: 12
Talking
BMW emblems......
Bigolphish is offline   Reply With Quote
Old 01-02-2014, 03:41 PM   #14
spencergt66
Oddometer: 784
I think Chris Has some Numbers but there is also a lot of different configurations on that 2-2 or 2-1 with different cans on each depending on what you want.
Best $ per HP is the Rottweiler and a tune. Night and day difference
spencergt66 is offline   Reply With Quote
Old 01-02-2014, 03:45 PM   #15
SpeedyR
SE in the SE
Oddometer: 909
it's not like it's a race bike. I don't see many actual dyno charts for the ADV bikes comparing the stock to modified version or even a real chart with AF ratios very often.
basically there's few times you get to go side by side where you will tell a difference. I know my SE will out accellerate most other ADV bikes but it's got a foam filter, open exhaust, jetted correctly, is lighter, and I like to pin it to the stops often.
but like any bike, everyone has given you the basics, intake and exhaust. if you really want to open it up, get some head work done at a reputable shop, check into cams and timing, tuning the FI, lighter/bigger pistons, etc. etc. My friends 675 triple was putting out 130hp at the rear wheel. but it was peaky. I'd prefer broad powerband in a dirt bike. :)
SpeedyR is offline   Reply With Quote
Times are GMT -7.   It's 07:10 AM.
