Old 01-03-2014, 05:32 AM   #1
scootrboi OP
scootrboi's Avatar
Oddometer: 1,611
-30 f
A Honda 125 Elite scooter is in an unheated, uninsulated shop, with bitter cold temperatures predicted tonight: In the twenties below zero, 30 below possible. Does anyone have experience with pushing the antifreeze envelope? No one seems to worry about the cars when it gets this cold, can anyone from North Dakota or Alaska advise me on whether I should drain the antifreeze? Putting it in is a real hassle.
42 years on a Heinkel Tourist
scootrboi is offline   Reply With Quote
Old 01-03-2014, 06:18 AM   #2
scooterryder
Oddometer: 17
If the shop has electricity, put a trouble light with a 60 watt bulb under it. I did this several times with my old Elite 150.
scooterryder is offline   Reply With Quote
Old 01-03-2014, 06:39 AM   #3
climbamt
climbamt's Avatar
Oddometer: 200
I would also throw a canvas type tarp over it to help hold the heat from the bulb in. Just make sure the tarp can not come into contact with the bulb. I know in my garage, it has the advantage of blocking the wind which creates a warmer environment with minimal heat sources. Make sure the light bulb is an incandescent build, the fluorescent bulbs don't put off much heat.
Good luck.
03 BMW F650 GS ABS
05 Vespa GT200
06 Kymco People 150
02 Kymco People 50
Baltimore, MD
climbamt is offline   Reply With Quote
Old 01-03-2014, 06:41 AM   #4
Warney
Warney's Avatar
Oddometer: 568
Pretty sure the drain bolt is on the water pump, drain a little and test.
Warney is offline   Reply With Quote
Old 01-03-2014, 06:49 AM   #5
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,266
A 50/50 mix of ethylene glycol antifreeze and water is good to -34. If that's what you have in it I wouldn't worry about it. Though it may go down to -30 it won't stay there for anything more than a few hours, and even at -34 the antifreeze mixture won't hard freeze. More like a gel/slush.
Of course all of this assumes you've mixed your antifreeze correctly
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 01-03-2014, 07:21 AM   #6
scootrboi OP
scootrboi's Avatar
Oddometer: 1,611
OK! The antifreeze is relatively recent and a premix sold here in VT. I have a 60W trouble light I have to move 2 feet. I will only partially cover it with a drop cloth so fumes don't raise hell. Thanks for the plan!
Old 01-03-2014, 09:03 AM   #7
pnoman
Just Average
pnoman's Avatar
Oddometer: 2,049
Back in the 90s, we were stationed in Alaska for 7 years. I had an '84 Ford Escort diesel. They sold small rubber "heating pads" that glued on to the bottom of the oil pan and had a short cord that you would run up to the grille and then attach to an extension cord. They had several sizes - some as small as 4" X 6" if I remember correctly. It kept the oil from turning into molasses when it was below zero. It did not get dangerously hot - you could still touch it for a few seconds comfortably when installed. However, some residual heat would probably work its way up from the oil pan to the block/coolant. I think it used about 100-150 watts.
Retired USAF MSgt - Bandsman & Paralegal
2007 Suzuki Burgman 650
WV Historical Markers Project
My Website - Europe, Alaska, US Bike Rides
www.RidingWV.com
pnoman screwed with this post 01-03-2014 at 09:59 AM
pnoman is offline   Reply With Quote
Old 01-03-2014, 09:07 AM   #8
RedArrow
With scootrboi
RedArrow's Avatar
Oddometer: 2,667
Why not just bring your scoot inside the house where it's nice and cozy?
1984 Honda Aero NH125 Scooter
1983 Honda CT110
1980 Puch Moped
RedArrow is offline   Reply With Quote
Old 01-03-2014, 10:01 AM   #9
scootrboi OP
scootrboi's Avatar
Oddometer: 1,611
Because I'm married.
Old 01-03-2014, 12:09 PM   #10
Horizontal
Goatin' Around
Horizontal's Avatar
Oddometer: 272
I knew there'd come a time when I could post my "I've got the best girlfriend in the world" picture.
Motorcycle parts scattered around the house? No problem!
The difference between genius and stupidity is that genius has its limits.
~ Albert Einstein
1983 Honda XL250R 1971 Yamaha DT1E 250 Enduro
Horizontal is offline   Reply With Quote
Old 01-03-2014, 01:33 PM   #11
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,266
No you don't!
Old 01-03-2014, 04:07 PM   #12
klx250sfguy
klx250sfguy's Avatar
Oddometer: 816
No you don't!
What a beauty.
I stored my C70 in my kitchen once - and I'm married. Great wife, great life.
klx250sfguy is offline   Reply With Quote
Old 01-03-2014, 05:09 PM   #13
scootrboi OP
scootrboi's Avatar
Oddometer: 1,611
I keep a toaster in my kitchen too.
Old 01-03-2014, 06:11 PM   #14
k-moe
Oddometer: 2,644
I noticed how you said "once."
k-moe is offline   Reply With Quote
Old 01-03-2014, 07:10 PM   #15
JerryH
Oddometer: 5,069
I live in AZ, so no such problems. But I have 3 scooters in what used to be my living room. I ripped out the carpet and put down commercial grade VCT (vinyl composition tile) It is now my bike workshop in the summer, when temperatures reach close to 120 degrees F. I keep it 70 degrees F inside. I'm divorced, so I don't have the wife problem.
A dipstick heater is a good idea, they come as an option on almost all cars. They just keep the oil warm, not hot. I would increase the amount of antifreeze to water to about 70%, about the max recommended. You can also put a kerosene heater in the garage, somewhere near the scoot. Those things make an amazing amount of heat.
JerryH is offline   Reply With Quote
Times are GMT -7.   It's 02:06 PM.
