Old 01-06-2014, 06:48 PM   #1
Newbusa OP
Newbusa's Avatar
Oddometer: 613
Throttle cable install on 990
Anybody have a picture on the installation of the 2 cables to the stock throttle cam? Took it off and can't seem to figure out how to re-install it
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 01-06-2014, 08:16 PM   #2
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,866
I tried to type something but it was incomprehensible.
Try Youtube.
DELTATANGO is offline   Reply With Quote
Old 01-06-2014, 08:50 PM   #3
Newbusa OP
Newbusa's Avatar
Oddometer: 613
Yes I tried YouTube, still have not found anything.
2007 Tuono 1000R
Old 01-07-2014, 02:47 AM   #4
rider911
rider911's Avatar
Oddometer: 482
When you twist the throttle only one cable pulls.....
New RR ~ Across OZ... Corner by Corner
08 KTM 300 exce (small)
12 KTM 500 exc (medium)
07 KTM 990 Adv (large)
rider911 is offline   Reply With Quote
Old 01-07-2014, 05:42 AM   #5
Masa
Masa's Avatar
Oddometer: 300
The cable closer to rider on top of the bars is the pull cable, put it in the round hole on throttle cam and return cable in the oval shaped. Don't know how to explain it really.. Just stare at it until you figure it out - I think that's how most of us do it.
Masa is offline   Reply With Quote
Old 01-07-2014, 06:17 AM   #6
DELTATANGO
DELTATANGO's Avatar
Oddometer: 13,866
Classic.
Old 01-07-2014, 01:20 PM   #7
Newbusa OP
Newbusa's Avatar
Oddometer: 613
Okay, figured it out. the problem was I was getting stuck on the position of the handgrip, I have heated grips on the bike and the wire for the grip I thought should hang straight down when installed. I guess the previous owner did not line it up properly so now with throttle working properly the wire for the heated grips twist up near the brake lever. But meh ,who cares the throttle works.
So now, how much slack should there be in the cables down by the throttle bodies?
Amazing! Adjusted my valves,installed Rottweiler kit,all other services and I get stumped by a little thing like the throttle cables..
Big thanks to everybody for trying to help ,sometimes it's hard to see the forest for all the trees.
2007 Tuono 1000R
Old 01-12-2014, 03:08 PM   #8
DELTATANGO
DELTATANGO's Avatar
Oddometer: 13,866
See, all you had to do was stare at it.
Old 01-12-2014, 10:32 PM   #9
Newbusa OP
Newbusa's Avatar
Oddometer: 613
Cross eyed now.
2007 Tuono 1000R
Times are GMT -7.   It's 09:38 PM.
