Old 01-15-2014, 09:25 PM   #16
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
Originally Posted by brianwheelies View Post
What type of figure is it to import one of those Honda engines from Thailand?
Don't know, had three engines shipped over some years ago from Bangkok to Shanghai.
As far as I know the Honda Nice 110cc -Thailand- engines (carb version) have been discontinued but parts are readily available.
Always a possibility to start with a set of engines cases (Honda / Takegawa) and start a custom hi-po engine build from scratch.
Beautiful work. That Takegawa build must be pricey!
Yes but buying quality in the first place pays in the end….
Are there any ride reports involving these cohorts?
See my signature line, some ride reports from our side of the world but nothing with "mini bikes" as they do not leave my eyesight, easily stolen and carried away….
Originally Posted by little_twin View Post
The quality of some of the mini bike stuff that comes out of Japan is amazing.
Yes, correct, crazy mad tuning parts available for Honda Dax / Monkey bikes and the Honda NSR's as well, pricey but worth every cent….
TBR...somewhere down the road in China... life is one lap with no restarts and the finish line is unknown ~ keep going...
China Cruising: http://tiny.cc/rummhx / China Bike Info: http://tiny.cc/ssmmhx / Australia Cruising: http://tinyurl.com/oxcx2vd
TBR is offline   Reply With Quote
Old 01-21-2014, 06:14 AM   #17
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
As initial project startup engine installing a Quickfoot QF128 (128cc) MIC = Made In China engine and not sure about later on but seriously thinking about a Takegawa Desmo based engine.
Playing around with different carbs, custom fabricated stainless steel inlet manifolds and some of our other custom parts.
Most probably will use the Keihin PE28 (Daytona pre-set) and HM Inlet Manifold (stainless steel) again.
A bikers work is never done....
Found a original 50cc engine inlet manifold and comparing to a stainless steel 28mm inlet manifold ~ well, there is a difference…
Old 01-23-2014, 04:43 PM   #18
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
Unwrapped the beautiful Big Cedar Z50JZ alloy tank, CF-Posh high flow fuel petcock and Kitaco alloy cap….
The alloy tank will get custom airbrush paint job later on.
Old 01-23-2014, 07:57 PM   #19
Texas Aggie
Texas Aggie's Avatar
Location: Nanjing, China and sometimes..... Dallas, Texas
Oddometer: 117
Looks like you already started the CNY! Always fun to see your exploits!
DT
Keeping the rubber side down........most of the time!
Texas Aggie is offline   Reply With Quote
Old 01-27-2014, 04:55 AM   #20
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
Test fitting and milling of front / rear Braking Wave Stainless Steel Discs….
Old 02-04-2014, 07:49 PM   #21
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
Nissin front and rear brake calliper, the rear calliper needs some milling to fit into the rear wheel. Stainless steel brake calliper brackets arrived as well.
Old 02-06-2014, 06:49 AM   #22
Ed_in_miami
Cubicle Traveler
Ed_in_miami's Avatar
Oddometer: 1,286
WOW... outstanding work...!
Surreal moments are the only moments worth remembering. Ride on...!
Ed_in_miami is offline   Reply With Quote
Old 03-24-2014, 07:06 AM   #23
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
March 1979 Honda Z50JZ (Australia) frame before media blasting.
The Honda Z50JZ frame after powder coating and headstock bearings pressed in.
Old 03-24-2014, 05:22 PM   #24
Texas Aggie
Oddometer: 117
Onward! I look forward to seeing the final results.
DT
Old 03-28-2014, 05:50 AM   #25
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
Stainless steel spacers installed in G-Craft / Japan CNC alloy hubs...
Old 03-31-2014, 08:03 PM   #26
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
G-Craft (Japan) alloy wheels fully assembled with G-Craft (Japan) hubs and alloy reinforcement rings, CF-Posh (Japan) alloy sprocket....
Old 04-10-2014, 12:02 PM   #27
Scubawerx
Scubawerx
Oddometer: 211
More! Come on now...don't leave us hangin'.
Scubawerx--Underwater Search Salvage and Recovery
Scubawerx is offline   Reply With Quote
Old 04-26-2014, 06:56 PM   #28
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
Well ~ picking up on the Supermoto project again due to crappy weather and watching NitroCircus with #199 Travis Pastrana and the Nitro-Crew…
Rooting through the extensive bike parts arsenal brings out some good ones for test fitting.
Checking to fit Honda NSR50 fork (55mm shortened and fitted with Takegawa pre-load adjusters), G-Craft Tripple Trees (55mm offset), G-Craft Headlight Brackets, G-Craft Fork Stabilizer, Bitubo Shocks, G-Craft Alloy Swingarm, etc...etc....
Old 01-11-2015, 12:33 AM   #29
TBR OP
One Life ~ Live It
TBR's Avatar
Oddometer: 689
A few vehicle projects going on right now but slowly moving forward with the mini bike build, installed bar risers and PROTAPER handlebar….
Times are GMT -7.   It's 06:42 AM.
