Old 01-12-2014, 08:58 AM   #1
editorxx OP
Oddometer: 5
Pissed ktm 990 adv rear suspension PROBLEM
I DID THE ENTIRE SUSPENSION SETTING FOR SPORT like the manual says
front is ok
back is ok
BUT i have the problem
low speed and high speed adjustment in the rear
high speed is in TURNS so there's no problem
but the inner screwdriver setting is suposed to be in clicks
i dont hear or feel ANY CLICK
HOW CAN I SET IT??? IS THIS WORKING???
can someones help???
KTM 990 , 2011 white
editorxx is offline   Reply With Quote
Old 01-12-2014, 09:11 AM   #2
spafxer
spafxer's Avatar
Oddometer: 2,635
There have been numerous reports of that corroding I believe. Although usually you cannot turn it at all. Possible that it snapped off and now turns but does nothing?
Email Superplush Suspension or suspension tuner of your choice. They will know. Common problem area.
When I first overhauled my rear shock they told me it was not put together from the factory properly.
spafxer is offline   Reply With Quote
Old 01-12-2014, 09:15 AM   #3
editorxx OP
Oddometer: 5
im in argentina, so there is NOT a "suspension tuner of my choice" but THANKS anyway
I WILL CHECK IT WITH MY SERVICE MECHANIC...if anybody nows about it pls help.
thabks
Old 01-12-2014, 09:28 AM   #4
Sumi
Sumi's Avatar
Oddometer: 1,799
That's for the adjuster at the base (at the swingarm) of the shock. The upper screw near the reservoir - which also has a hex nut around it to adjust shouldn't corrode - but yes, it shall click, so probably it's snaped inside - I wouldn't care about it, unless you need to adjust it.
Old 01-12-2014, 09:30 AM   #5
editorxx OP
Oddometer: 5
Originally Posted by Sumi View Post
That's for the adjuster at the base (at the swingarm) of the shock. The upper screw near the reservoir - which also has a hex nut around it to adjust shouldn't corrode - but yes, it shall click, so probably it's snaped inside.
YES IM TALKING ABOUT THE screw near the reservoir...thanks!!
Old 01-12-2014, 09:46 AM   #6
Hipster
Hipster's Avatar
Oddometer: 1,811
On my shock, I can't hear it click but, you feel the detents.
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 01-12-2014, 11:49 AM   #7
Sumi
Sumi's Avatar
Oddometer: 1,799
Originally Posted by hipster View Post
on my shock, i can't hear it click but, you feel the detents.
+1
Old 01-12-2014, 06:53 PM   #8
spafxer
spafxer's Avatar
Oddometer: 2,635
thabks
Argentina does not have POST to send it to a tuner? NEws To ME ! Setting UP SusPension is the best thing that can be done 4 your Riding.. And I DON'T MEAN TWISTING knobs.
Tell YOUR SERVICE mechanic a HAMMER CAN FIX ANYTHING !
MY MIND reading ABIlIty went out with your lack of filling out your location INFORMATION ....
SORRY FOR TRYING TO HELP NooB !..... {sarcasm}
Old 01-13-2014, 09:17 PM   #9
renogeorge
Oddometer: 1,389
The original post seems pretty clear to me. He was talking about the compression adjuster--not the rebound adjuster that you incorrectly assumed. Lots of guys don't specify their location. Gonna go after all of them?
Question was perfectly valid with or without location specified. Too bad he got such a welcome.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 01-13-2014, 10:01 PM   #10
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,062
Hey Editorxx, if the screw just turns and turns, yer screwed. You need a total service. Hopefully, it is stuck in a good place.
But, if it turns about 6 turns before it stops, you are ok. The detent balls are just corroded. 1/4 of a turn is equal to one click.
Some time you should put some lube in there. Unscrew the hex nut and pull it out. Leave the screw alone, don't turn it. Shoot some penetrating oil in there and reinstall. Then work the screw.
"Son, you can't do both"
Old 01-14-2014, 02:13 AM   #11
Yascher
Yascher's Avatar
Oddometer: 388
if you can do couple turns and find a stop-you are good, just keep on working that adjuster till you are happy with how the suspension is working,
or it is always better to give it for full owerhaul at professionals, just to get it dialed in to your preferences
Yascher is offline   Reply With Quote
Old 01-14-2014, 07:33 AM   #12
AdvRonski
They call me......Ronski
Location: Wishing I was back in Grand Junction, now in MN
Oddometer: 703
Zuber, I believe he is talking about the compression adjuster. DO NOT unscrew the comp adjuster!
The resulting oil bath would not be much fun, and the velocity at which the adjuster would be propelled could put your eye out.
Ronski
Enduro Racer & Big Bike Adventurer
AdvRonski is offline   Reply With Quote
Old 01-14-2014, 07:53 AM   #13
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,119
I can tell you from experience that it starts oozing oil before it becomes a projectile. My compression adjuster screw has the same symptoms. After a couple services that didn't fix the problem, I just set the screw by measuring the location of a friend's, and putting mine to match. Works well enough for now.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Times are GMT -7.   It's 04:52 PM.
