Old 01-13-2014, 04:13 PM   #1
Unsung OP
Oddometer: 60
VT500 Ascot for tracker or dual sport?
Found a VT500 Ascot very cheap, was thinking of buying it and turning it into a dual sport. Specs say 390ish dry weight, about 50 horsepower from it's 500cc vtwin. Attached is a picture of what it looks like stock, following by one that's chopped down. Anyone think this would make a cool on/off road bike? Top speed is about 100, it's also a 6-speed. Shaft driven. Has a 31" very low seat height. I'd probably want to jack it up a bit. Wanting to build a tracker or dual sport type bike. What you guys think?
This next picture is one chopped down a bit. Looks like a neat little Evel Knievel wannabe tracker.
Unsung is offline   Reply With Quote
Old 01-13-2014, 04:28 PM   #2
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,055
Search the forms for the Loser. It has been places that no bike should have gone.
Have a look at this. http://advrider.com/forums/showthrea...ighlight=loser
Marc
84 R100RS LE, 14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax screwed with this post 01-13-2014 at 08:05 PM
Lomax is online now   Reply With Quote
Old 01-13-2014, 06:30 PM   #3
TrophyHunter
Oddometer: 2,211
1 vote Tracker
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 01-13-2014, 06:37 PM   #4
kenstone
newb
Oddometer: 631
VT500 Ascot
Mine's more of a dirt road bike than a dual sport
It had a rotted tank so I fit a Shadow tank to it... now a "Shascot"
There's thread here for VT/FT
http://www.advrider.com/forums/showt...ht=vt500+ascot
kenstone is offline   Reply With Quote
Old 01-18-2014, 05:58 AM   #5
Hughlysses
Hughlysses's Avatar
Oddometer: 3,335
Technically, it's a tracker already.
Ascots are fairly rare bikes, so if it's in decent condition with a good gas tank, side panels and rear tail section (ALL of which are nearly unobtanium now), I'd be hesitant to modify it much. If you do decide to modify it anyway, there are plenty of people that'd be glad to buy those parts from you if you don't use them.
Check out the Yahoo VT500FT Ascot Enthusiasts Group at: https://groups.yahoo.com/neo/groups/...thusiasts/info for questions/info on the bike. Some guys have parts bikes, so the group can be a good source for spares.
The main issues with older Ascots are the gas tanks tend to rust out on the bottom, and replacements are impossible to find. Your best bet for that is to have the gas tank professionally repaired; there are shops that specialize. The only other tank that is a near-direct swap is the larger tank from a VT500C Shadow, but the Ascot side panels won't fit up to it properly so they'll have to be modified or left off.
The other issue with older Ascots is weak ignition coils. This will show up as the engine dying at idle or being difficult to crank in hot weather, and as a high speed miss under the same conditions. Don't waste your money on used coils; they'll have the same problem. New coils are still available from Honda (about $170/pair IIRC). Dyna also makes coils that will work but you'll have to make some simple brackets to mount them.
Good Luck.
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses screwed with this post 01-18-2014 at 06:04 AM
Hughlysses is offline   Reply With Quote
Old 03-23-2015, 07:29 PM   #6
NorthBayPete
NorthBayPete's Avatar
Oddometer: 17
This is my 84 "Ascot Adventure". Custom 3" taller and longer (forward) seat, MSR high ATV bars, heated grips, homebuilt pannier brackets, auxillary gas tank, auxillary LED lights, Shinko 244 tires, vent for shaft drive hosed up under the seat, new bearings in wheels and steering head, fork seals with gaitors. Still have to build a skid plate to protect the water pump but for the most part I am pretty well done my build.
NorthBayPete is offline   Reply With Quote
Old 03-23-2015, 09:08 PM   #7
dpforth
no inline fours
dpforth's Avatar
Oddometer: 316
A couple pics of my tracker
Rescued from a bad attempt at bobbing.
This species has amused itself to death
dpforth is offline   Reply With Quote
Old 03-24-2015, 02:47 AM   #8
Hughlysses
Hughlysses's Avatar
Oddometer: 3,335
^ Nice job!
Old 03-25-2015, 08:28 PM   #9
dpforth
no inline fours
dpforth's Avatar
Oddometer: 316
Originally Posted by Hughlysses View Post
^ Nice job!
Thanks. I'm pretty pleased with the result, but wish it was chain drive.
Old Yesterday, 05:40 AM   #10
dirt hokie
Oddometer: 685
how much range of motion can you get out of the drive shaft joints
Say it has 3" of suspension travel in stock form, can you increase that to 6" or 8" just by modifying the shocks?
dirt hokie is offline   Reply With Quote
Times are GMT -7.   It's 09:16 AM.
