Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 01-17-2014, 08:14 AM   #1
Qaz OP
Oddometer: 235
What attribute make a good/great ADV bike
I have been reading these builds for about a year and like everyone else, I think: Man that is a good idea or I wouldn't do that. Let's face it, the BMW GS is a street bike and although the old Yamaha DT 250 was hell of a trailbike, it was limited on the road! As you move up in size and cc there should be a point where it all balances. The Versys and V-strom are good starting points but the KLR with the 650 twin engine offers more.
My question is: If you were to build frankenstien, what would it include and why? I think we need some guide lines, it must be capable of 200+ miles on a tank of gas, comfortable enough to ride 600+ mile days strung together (ie. Touring), keep up with highway traffic, nimble enough to ride single track.
Qaz is offline   Reply With Quote
Old 01-17-2014, 08:37 AM   #2
XC Rider
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 3,094
The hard part to achieve is the "nimble enough to ride single track" along with all that preceded that.
Personally I'm a big fan of the modified Versys/Ninja, and I simply accept that due to the limitations of the bike and myself as a rider, this is not the bike for me to ride single track with.
Where is XC Rider?
XC Rider is online now   Reply With Quote
Old 01-17-2014, 08:46 AM   #3
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,817
I would build exactly what I built with the ninja 650 but I would change the following
Replace pds shock and swing arm with a linkage from a KTM 690. That gets rid of the tank mods. Probably. I would also run shorter travel. I have 300mm and I could get by with less.
Perhaps go custom on the tank, but that is beyond my skill level. My bike you can stand but the shape of the tank prevents it being comfortable for long distance.
I had also considered running the KTM 690 subframe and tank setup. This would get rid of huge ninja tank and replace with 3.2 gals. I would then augment with maybe a side tank opposite the exhaust. Now I could have a seat that goes all the way to the bars for better seating positions.
Probably would require a custom frame and a ton of work. I considered doing this as I have the parts to frame it up but I simply don't have the time or ambition to tackle another huge project right now. But it would be awesome
My bike is fuel injected, gets 40ish mpg. Has plenty of power, weighs 385 lbs and that is full of fuel. I don't know if I would want it I do a 600 mile day on it but I probably could. It will easily pull 75 all day long and rips past 100 when required.
To me the big thing is weight. It makes a huge difference. You know how fun it is to ride a 450 dirt bike. But adding 200lbs just kills the fun off-road. My ninja is pretty close to exactly what I would want but def needs another revision.
I will do it someday just can't dedicate the time.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 01-17-2014, 08:49 AM   #4
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,817
The more I have considered it, I think the KTM 690 with some mods would pretty much check all the boxes. I guess you might lose a little comfort on the road, but it sure makes up for it in performance and off road ability. And they have been around long enough to be within reach of most buyers. Building a bike is not cheap. Especially with fun bling components. Anyone who tells you different hasn't done one
Nessmuk
Old 01-17-2014, 09:14 AM   #5
jdrocks
Gravel Runner
Oddometer: 4,586
...I think we need some guide lines...
there are no guidelines, never will be either. the bikes are purpose built and tailored to satisfy the builder's criteria, not some other rider's notions of what "ideal" means, no matter the usage. riders can't even agree on the capability and usage of bone stock motos, how are they to set guidelines for custom builds?
if custom bikes happen to end up with some similarities, it's because the builders had similar goals and might have faced the same problems and constraints.
KLR with a ptwin offers more what, exactly? some great builds by some very talented guys, and that bike might offer more of what you're looking for, but certainly not more of what i'm looking for. see what i mean.
your money, your time, your skills, your ride...build whatever the heck ya want.
jdrocks is offline   Reply With Quote
Old 01-18-2014, 08:15 AM   #6
Navin
Navin's Avatar
Oddometer: 8,481
Tonymorr is going to nail it with the Ninja 300 conversion. The engine is a doll of a motor. The torque is flat and useable, the gears are spread wide enough for one sprocket set to do trails and highway. Capable of big MPH numbers and smooth at high RPMs.
I rode/raced KTM Adv and/or a SE950 since 2003. Put this 300cc engine in a SE type frame and it would be a riot. In an Adv it would put the KLR out of business. No, it won't power wheelie in 3rd gear, but it would be nimble off road and do over 100 MPH.
Kawasaki needs to hire a few guys away from KTM and grow a set!
Navin is offline   Reply With Quote
Old 01-18-2014, 03:00 PM   #7
dhallilama
Oddometer: 589
guess it depends on the rider... for me, a GS would be an utter nightmare off road & i don't even like it on road. i like the idea of a ninja 300 motor in a capable chassis/suspension package. for me the closest thing to a great ADV bike out of the box is an XR650R. It's still on the heavy side for single track, but it does the wide open throttle boogie through the desert that i love so much.
otherwise... if i were building my version of an ADV bike... either a late suzuki RM... or KTM frame/suspension, wedge a ~450cc thumper in there... or maybe a big rotax 4 stroke...
current: '89 gsxr 750 (for sale) • '77 yamaha IT250 • '67 harley xlh chopper • (3) suzuki jr50 • '62 bird mini
project: '96 husqvarna wxc250 • '69 harley xlh resto • '31 ford
dhallilama is offline   Reply With Quote
Old 01-18-2014, 03:23 PM   #8
AST236
AST236's Avatar
Oddometer: 2,174
Sit back and get ready for hundreds of answers to your question. Should be fun!
If I could just average my DR350 and my FJR1300, maybe I'd be close.
I actually liked the WeeStrom I had for a while. It was just so, SO ugly!
For me, a less ugly WeeStrom w/ laced wheels would take care of most of my riding needs.......YMMV
I usually run out of talent before I run out of horsepower.
AST236 is offline   Reply With Quote
Old 01-19-2014, 04:50 PM   #9
Kommando
Kommando's Avatar
Oddometer: 7,390
Pick up a beaten DR650SE and drag it through www.Procycle.us.
You can have a smooth-running DR790 with 400+ miles of range, a comfy seat, luggage racks, and suspension with fully-adjustable damping. Then fab some brackets to lower your passenger pegs and add touring pegs, and shop for some soft luggage bags with some PacSafe mesh bags around them. It'll run singletrack. It'll run slab for days at a time.
Kommando is offline   Reply With Quote
Old 01-19-2014, 05:44 PM   #10
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,432
what kind of ADVENTURE will you be doing?
Old 01-19-2014, 07:36 PM   #11
Wraith Rider
Oddometer: 1,604
Reliability! Most important is reliability.
So it should be an as stock as possible Honda.
Wraith Rider is offline   Reply With Quote
Old 01-19-2014, 07:48 PM   #12
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
An "Adventure bike" is (or should be) one with a 19" front wheel chain, shaft or belt final drive and long suspension.
A Dual Sport Bike should be lighter, have a 21" front wheel Chain final drive and Long suspension.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 01-19-2014, 08:12 PM   #13
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,182
1. Wide ratio 6 speed transmission with a low first gear.
2. Air cooled.
3. Minimum engine size of 350cc.
4. 40 RWHP, true HP, not Dynojet.
5. 300 pounds fully fueled.
How I would achieve that list;
1. TY350 transmission.
2. TY350 engine.
3. TY350 engine.
4. Turbo and fuel injected.
5. 7 gallons of fuel, nav tower, oil tank for pre-mix, integrated soft luggage should get me to 300 pounds which is the magic number for me in my experience. I want a little weight for good highway manners, yet light enough for single track.
Stay tuned to the 'Built, not Bought' section and I'll make it a reality.
larryboy is online now   Reply With Quote
Old 01-19-2014, 08:22 PM   #14
BanjoBoy
BanjoBoy's Avatar
Oddometer: 878
What attribute make a good/great ADV bike?
ADV ain't in the bike, it's in the rider!!!
2007 FJR1300
2007 FZ6 (Dirt bike)
BanjoBoy is offline   Reply With Quote
Old 01-19-2014, 11:10 PM   #15
CanadianLifeGuard
Oddometer: 81
For me that bike would be easy to make. Take a KTM dirt bike frame, with well sorted suspension components. Drop in the 375cc thumper from the new duke 390, with a good wide range 6-speed gearbox. Add a 20L(ish) fuel tank for some good range and a rally style fairing for some wind protection along with a good seat. Boom you have a a bike thats punchy (40-45rwhp depending on what you read), has good range, would be comfortable on the highway and capable in the dirt. Keep it all around, preferably under, 300lb ready to ride and with an MSRP of around $10,000 and it would sell like hotcakes in my opinion.
CanadianLifeGuard is offline   Reply With Quote
Times are GMT -7.   It's 09:00 AM.
