Old 01-21-2014, 08:42 AM   #16
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,468
OK, time for more coffee
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is online now   Reply With Quote
Old 01-21-2014, 08:50 AM   #17
steveWFL
steveWFL's Avatar
Oddometer: 1,344
just ordered the 60 flood. I was looking for a cheap LED to use as a 12v work light.
I'll rig a cigarette lighter adapter to it and use it outside of my truck
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 01-21-2014, 10:31 AM   #18
Butters OP
Kwyjibo
Butters's Avatar
Oddometer: 2,576
I bought a pair of both. I'm thinking of using one pair as back up lights on my truck. I'll figure out a use for the other pair or keep them around until I get another bike. Maybe some aux lights one the front bumper or use one of the 60 degree ones for an underhood light (assuming it can take the heat).
I do think it is funny that the pic shows the lights compared to "cheap China junk." Nowhere could I find a country of origin, but can only assume they are also Chinese.
I'm not expecting much, but with the good reviews and $18 each, I don't see how you can go wrong.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 01-21-2014, 11:04 AM   #19
xr400r
xr400r's Avatar
Oddometer: 3,139
I am thinking of buying these lights. Are they something that you can wire right to the battery and run thru a switch on the handlebar? I don't know much about wiring... Thanks,
xr400r is offline   Reply With Quote
Old 01-21-2014, 11:21 AM   #20
Butters OP
Kwyjibo
Butters's Avatar
Oddometer: 2,576
You could do that since the draw is only about 2 amps. I would think most switches can handle that fine. But you need to remember to turn them off when you're done. I always prefer using a relay - with switched power as the trigger and a direct run to the battery to power the lights. That way you don't need to worry about the switch or killing your battery by leaving them turned on.
Marc
07 XChallenge
Old 01-22-2014, 04:13 PM   #21
Butters OP
Kwyjibo
Butters's Avatar
Oddometer: 2,576
My lights arrived today. Here's my impressions:
Quality seems fine, especially given the price. We'll see if they last.
As discussed, they're a bit over 4.5". They are quite heavy, maybe 3 pounds each. I bought them for my truck, but I wouldn't put them on my thumper. Maybe a bigger bike or ATV they'd be fine. But they are pretty heavy to be bouncing around offroad. The brackets seem strong and they'll need to be to control their weight.
I powered them up quickly in my lit garage and they're bright. Not shockingly bright given their size. Maybe as bright as my ADVmonster lights, but much bigger and heavier.
The 30 degree spots are pretty broad - more like floods than spots. The 60 degree are more broad, but not 2x as much. I would think the 30 degree lights would be broad enough for anybody wanting floods.
No complaints as they will work perfect for my project (car based). Maybe not ideal for use on a motorcycle though. And they are made in China, so I'm not sure why the vendor compares them to "China junk."
Marc
07 XChallenge
Old 01-26-2014, 05:03 PM   #22
ERD
Custom Rider
Oddometer: 347
Do you have any pictures of the beam pattern?
ERD is offline   Reply With Quote
Old 01-28-2014, 07:51 PM   #23
BlackHawkChief
BlackHawkChief's Avatar
Oddometer: 551
Sweet deal I bought a 60.degree. One it arrived today I'm mounting it on my TTR to replace the stock headlight
Sent from A bar in Mexico
BlackHawkChief is offline   Reply With Quote
Old 01-28-2014, 08:06 PM   #24
BlackHawkChief
Oddometer: 551
But now I'm looking at buying another to mount on my naked sv what's better the 30 or 60 degree light ?
Old 01-28-2014, 10:28 PM   #25
steveWFL
steveWFL's Avatar
Oddometer: 1,344
I bought a 60. I'll use thick speaker wire and have a 12V cigarette plug at the other end, needed a low-draw shop floodlight light outside of the truck when in remote places changing KTM oil
'08 ZZR600 minty
Old 01-28-2014, 11:51 PM   #26
steveWFL
steveWFL's Avatar
Oddometer: 1,344
I just went out in the garage and did it
Now, I want it to work on my truck or Concours14 cigarette 12V port.
So I gather a scrap 12V plug and cut the end of, enough old speaker wire to go about 3 truck lengths, some heat shrink tubing, soldier, and the FRUGAL waterproof work light.
Here is my junk:
And here it is after my cutting, stripping, soldering and heat shrinking is done. I also used a multimeter and "ohmed out" to make sure my 12V and grounds were correct.
And here is working with garage dark, its plugged into the 12V outlet of the Connie14 (engine off). Its so bright I'd back it up if i was really working on a bike/car/tent with it
'08 ZZR600 minty
Old 01-29-2014, 03:24 AM   #27
josjor
Location: The largest geological formation in the U.S.A.
Oddometer: 2,785
Thanks for that. Now go out to the driveway and show us a couple pics comparing it to the low beams on your pickup/car.
Neutiquam erro.
Originally Posted by Stagehand View Post
listen mister, we didnt evolve porcelin shitters just so we could squat to take a shit, like monkeys.
josjor is offline   Reply With Quote
Old 01-29-2014, 06:15 AM   #28
steveWFL
steveWFL's Avatar
Oddometer: 1,344
I bought the 60 "flood", it won;t compare to the low beam. Perhaps the fog lights but still not a comparison. Let me see what I can do
'08 ZZR600 minty
Old 01-29-2014, 07:51 AM   #29
TimothyCaseTimothy
Oddometer: 486
If one were to choose one or two of these to light off the side of a camper van for camping ops, which one would be chosen?
TimothyCaseTimothy is offline   Reply With Quote
Old 01-29-2014, 08:04 AM   #30
worwig
Lost in Georgia
Oddometer: 1,169
If it is anything like the ones that I have, and I'm sure it is, get the 30s. I have the 30s and they have enough 'scatter' to cover the sides, and enough control to put light way out ahead. For me, the 60s would likely be too broad.
Hog mountain Weather
worwig is offline   Reply With Quote
Times are GMT -7.   It's 07:55 AM.
