Old 01-27-2014, 03:50 PM   #1
sierraoffroad OP
sierraoffroad's Avatar
Oddometer: 1,339
i phone 4 mount
I'm new to the smart phone world and recently got an I phone 4. I am looking for a water resistant case I can put on my bike. I'm looking for a case that has a clear lid that will accept the phone while it is in it's otter defender case and allow it to be plugged into the bike's power. I see that pelican offers an Icase, but was wondering if there was something you guys could suggest.
thanks
2013 Super Tenere
2004 Yamaha Wr250f
sierraoffroad is offline   Reply With Quote
Old 01-27-2014, 08:37 PM   #2
KoolBreeze
KoolBreeze's Avatar
Oddometer: 608
Well you can dump the defender and pick up a lifeproof case and bike mount. rei has the bike mount on sale now. (and extension adapter so you can still use the phone on alarm clocks and other ports)
the case is water PROOF (submergible and capable of being used while swimming) but.. not when the port is open for charging.
edit: the best price on the lifeproof case is amazon, if you have a local fry's they will price match and no wait.
KoolBreeze is offline   Reply With Quote
Old 01-28-2014, 08:41 AM   #3
MotoDaveL
MotoDaveL's Avatar
Oddometer: 420
Just as a point of reference I can confirm that an Otterbox defender in the side pocket of motorcorss pants is not suitable to watercrossings over the top of said pocket.
MotoDaveL is offline   Reply With Quote
Old 01-28-2014, 08:53 AM   #4
tyrsmkkyle
off the ground.
Oddometer: 250
I have the otterbox armour its waterproof and crushproof up to 2 tons.
tyrsmkkyle is offline   Reply With Quote
Old 01-28-2014, 08:56 AM   #5
kevin2735
kevin2735's Avatar
Oddometer: 163
I went with a Lunatik case. $100 (If you have access to Promotive you can get this case at a very good discount.) I like this case because it has hard rubber edges which help hold it securely in the cradle. It is also the thinnest most durable "otterbox" like case I have seen. Out of the cradle is it comfortable and easy to carry in any pocket.
https://www.lunatik.com/products/iph...taktik-extreme
Then I used a Ram PDA Cradle from Powerlett, here is one on E-bay $20. I have ridden int he desert and have had a coupe of falls and this cradle holds the phone like a champ. It has never come loose or fallen out.
http://www.ebay.com/itm/like/191042935738?lpid=82
Lastly, I used a weatherproof USB port for motorcycle from Burns Moto. I like this because it includes a snap connector for attaching to switched power. Makes it very easy to install and will only be on when the bike is running. So you can't accidentally leave something plugged in and drain your battery.
http://burnsmoto.com/dual-usb-charge...motorcycle.php
2011 BMW R1200GS Adv | 2012 KTM 690R | 2008 BMW F650GS |
http://kevin2735.blogspot.com/
kevin2735 screwed with this post 01-28-2014 at 09:02 AM
kevin2735 is offline   Reply With Quote
Old 01-28-2014, 09:00 AM   #6
sierraoffroad OP
Oddometer: 1,339
thank you guys for the replies. the lunatik mantinoed looks very nice. i was really hoping not to buy another phone case and rather have a box i can drop my phone into on the bike so i can see the screen for navigation.
2013 Super Tenere
2004 Yamaha Wr250f
Old 01-28-2014, 09:15 AM   #7
kevin2735
kevin2735's Avatar
Oddometer: 163
I have seen the Otterbox and it is also great case, just a little more bulky than the Lunatik. I think that the cradle I used will work with the Otterbox. It has a spring tension component to it that clamps the arched prongs down onto any type of case/device in the cradle. The prongs on the side of the cradle are adjustable for width.
Old 01-28-2014, 09:38 AM   #8
sierraoffroad OP
Oddometer: 1,339
wow kevin now that I noticed your pics posted that lunatik case is incredible.
2013 Super Tenere
2004 Yamaha Wr250f
Old 01-28-2014, 12:15 PM   #9
scootertrog
Oddometer: 313
Check out SlipGrip. The holder is vacuum molded to the phone shape. They utilize RAM mount 1" balls.
scootertrog is offline   Reply With Quote
Old 01-28-2014, 12:34 PM   #10
Black-Ops
The left one....
Black-Ops's Avatar
Oddometer: 119
I use a quad lock from http://www.quadlockcase.com
Clips in nicely and has never given a problem. They have a poncho thats fits over your phone for the rain.
Roam if you want to.
Black-Ops is offline   Reply With Quote
Old 01-28-2014, 03:28 PM   #11
2Stamp
2Stamp's Avatar
Oddometer: 389
Rokform. They also have a motorcycle mount.
_______________________________
2011 F800GS
2014 350XCF-W
2006 450EXC
2014 Honda Grom (hers)
2Stamp is offline   Reply With Quote
Old 01-28-2014, 05:00 PM   #12
patmo
Oddometer: 820
Aerosticth sells a case for the IPhone that easily mounts on any size handlebar, is waterproof, and costs about 40 dollars. The only problem for you might be that the phone will only fit in without an outside case already on it. I don't find that a problem as my current case slips on and off very easily. However, the phone fits in the mounted case very snugly and the mounted case slips on and off the mount in a snap. I generally just snap it off when I go inside to eat and take it with me. It has a clear face cover that allows me to see the phone face and is touch sensitive. It also has a port that can be opened to allow charging with the car charger plugged into my auxiliary port.
patmo is online now   Reply With Quote
Old 01-28-2014, 05:11 PM   #13
sierraoffroad OP
Oddometer: 1,339
Thanks for the replies keep them coming. The quad case looks decemt
http://www.quadlockcase.com/collections/run
2013 Super Tenere
2004 Yamaha Wr250f
Old 01-29-2014, 04:41 AM   #14
sierraoffroad OP
Oddometer: 1,339
ok so i think i'm down to deciding on (2) different cases: the lunatik or lifeproof. both seem very good and the price is similar. i see a lot of each on ebay with varying prices. how can you tell if it's fake besides the obvious coming from hong kong?
2013 Super Tenere
2004 Yamaha Wr250f
Old 01-29-2014, 06:29 AM   #15
Hikertrash
Oddometer: 2,895
My iphone shuts off after 5 minutes in direct sunlight on the bike. You guys don't have this issue?
IBA #50489
Hikertrash is offline   Reply With Quote
Times are GMT -7.   It's 05:59 PM.
