Old 01-29-2014, 08:53 AM   #16
kevin2735
kevin2735's Avatar
Oddometer: 163
Not yet, but then again I'm not in Arizona. I haven't used mine through the Summer yet. Something I hadn't considered, but will report back once it heats up here.
2011 BMW R1200GS Adv | 2012 KTM 690R | 2008 BMW F650GS |
http://kevin2735.blogspot.com/
kevin2735 is offline   Reply With Quote
Old 01-29-2014, 08:55 AM   #17
sierraoffroad OP
sierraoffroad's Avatar
Oddometer: 1,339
hmm maybe i should be looking for a case that has cooling fins? or liquid cooled?
2013 Super Tenere
2004 Yamaha Wr250f
sierraoffroad is offline   Reply With Quote
Old 01-29-2014, 09:27 AM   #18
Hikertrash
Oddometer: 2,953
Lol, I'm sure you'll be fine in MA. I'm a little annoyed with iPhone because it overheats so easily when it's warm out. In the summer, mine overheats and turns off even in an outside jacket pocket. I have to bury it in my tankbag or in an inside jacket pocket. Even outside by the pool, I have to bury it under a couple of towels.
For winter months I do use a waterproof case I purchased from eBay for about $30. It has a mount that attaches to my handlebars and it will slide onto that. It has a waterproof port for the charging cable and it's been 100% waterproof. I bought this before there were any option in the states. Now I see a similar case sold for about $50-$60.
IBA #50489
Hikertrash is offline   Reply With Quote
Old 01-29-2014, 02:38 PM   #19
bicyclebradley
V-Twin
bicyclebradley's Avatar
Oddometer: 252
Thanks for the replies keep them coming. The quad case looks decemt
http://www.quadlockcase.com/collections/run
i use a quadlock also and friggin LOVE it. They always have a cupon code floating around for 10-15% off when you order it online so search for that.
the pancho isnt waterproof (its more damp-proof, or mist proof) and will not allow to be plugged in to either headphones or charger - which is not a concern for me as it never rains in Sun Diego!
Swim, Bike, Run. Faster, Better, Stronger.
http://www.bear-straps.com
bicyclebradley is offline   Reply With Quote
Old 01-29-2014, 03:25 PM   #20
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 1,012
Life proof case w/ bar mount. Waterproof with charge cap closed. Been on suspension bottoming rides and never budged. Had to modify holder in order to accept charging plug.
Shooby is offline   Reply With Quote
Old 01-29-2014, 03:32 PM   #21
patmo
Oddometer: 829
Originally Posted by Hikertrash View Post
My iphone shuts off after 5 minutes in direct sunlight on the bike. You guys don't have this issue?
Are you sure your auto lock is not set for 5 minutes? Can find this in your general settings.
patmo is online now   Reply With Quote
Old 01-29-2014, 04:12 PM   #22
bicyclebradley
V-Twin
Oddometer: 252
extreme heat will make the device shut off. ive left mine out in a summer patio table in direct sunlight and it gives a warming that its overheating, then shuts off...
Old 01-29-2014, 05:57 PM   #23
KoolBreeze
KoolBreeze's Avatar
Oddometer: 608
Buy a Lifeproof case and sit it in a small clear pelican case full of water. zip tie to handlebar.
KoolBreeze is offline   Reply With Quote
Old 01-29-2014, 05:59 PM   #24
KoolBreeze
KoolBreeze's Avatar
Oddometer: 608
I've had this happen on an iPhone 4... 114 degrees out, something's bound to heat up.
I have a sun shield for my GPS, think I could rig one up for my phone too.
Old 01-29-2014, 07:15 PM   #25
Hikertrash
Oddometer: 2,953
Yeah, I'm sure. I get the overheat triangle warning. Even my 1200GSA overheats here. AZ should be the proving ground for adventure gear. If it'll work here, then it'll work almost anywhere. Unfortunately most gear doesn't last in the AZ summer sun/heat.
IBA #50489
Old 01-30-2014, 02:39 AM   #26
sierraoffroad OP
Oddometer: 1,339
Genius that's brilliant!!!
2013 Super Tenere
2004 Yamaha Wr250f
Old 01-30-2014, 05:48 PM   #27
Mongo357
Mongo357's Avatar
Oddometer: 156
I second the zip-ties! I didn't need the ziplock bag full of water, though.
I carry some heavy duty zip-ties and strap the thing to the handlebar clamps. Works great for me - plus I hate all the RAM mounts and "robot arms" on the handlebars.
Mongo357 is offline   Reply With Quote
Times are GMT -7.   It's 07:40 PM.
