Old 02-08-2014, 03:39 PM   #16
markgsnw OP
WTF?
markgsnw's Avatar
Oddometer: 3,592
here's what I believe will work:
Feed from brake light switch-----------|>|------------LED Brake Lights
|-----------------------TIR 3
The diode blocks the 6 volt feedback from the LED cluster. The TIR3 gets either 0 volts or 13 volts, which is desirable. No relay required.
http://vasaphoto.wordpress.com/
2011 Moto Guzzi Norge 8V GT
markgsnw is offline   Reply With Quote
Old 02-10-2014, 06:28 PM   #17
StopnExsanguination
Regularly Irregular
StopnExsanguination's Avatar
Oddometer: 47
I use a 3rd brake light flasher to work the Whelen. It works well and it was not too difficult to install. Here's a link for one similar to what I use.
http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=7&products_id=319
Good luck with it. Those lights are bright!
First Rule of Trauma: All bleeding stops eventually.
StopnExsanguination is offline   Reply With Quote
Old 02-14-2014, 06:06 AM   #18
ghostrider.y2k
ride enything but HD
ghostrider.y2k's Avatar
Oddometer: 885
I run Nova strobe hooked up to brake light leed, when bike is on work as a extra tail light but when brakes applied will strobe one of 8 flash patterns.
On Maggie's bike we run two 3/4" strobe lights, when brakes applied it will strobe 3 series of 3 flashes and stay solid red.
Nice and small, we noticed that "phone booths" keep the distance behind us.
MOTORCYCLES-->created to keep us from choking the idiots around us
"w strone slonca..........."
ghostrider.y2k screwed with this post 02-14-2014 at 06:12 AM
ghostrider.y2k is offline   Reply With Quote
Old 02-14-2014, 11:42 AM   #19
markgsnw OP
WTF?
markgsnw's Avatar
Oddometer: 3,592
here's what I think I know about having a LED tail/brake light cluster:
A conventional incandescent setup has two bulbs (or a single bulb with two filaments), so that the brake light circuit is entirely separate from the tail light.
The LED array is, essentially, a single circuit, or a single "filament". Six volts is sent to it all the time to create tail lighting, and 13 volts is sent to it to create brake lighting.
In order to add an additional discreet brake light, we somehow have to mask or block the six volts from the new device. One way to do that is to use the diode in the sketch above. A diode is a one way valve, so that the 13 volts from the brake light switch pass though it, and the six volts that are always present are blocked. It's a fairly simple and inexpensive solution (diodes run about five cents each), the down side is that it involves cutting the brake light wire.
Hope that helps with the collective knowledge.
Old 02-14-2014, 12:37 PM   #20
James Adams
Misplaced
James Adams's Avatar
Oddometer: 10,012
It's probably not really six volts, just a PWM signal at ~50% so it looks like 6V in a basic DC voltmeter. But the circuit with the diode should work fine.
Alternatively, you can use a trailer light converter designed to take that PWM signal that is being sent to the taillight and "decode" it for a basic flat-4 trailer connector. This could be put to use to isolate the brake light and power the Whelen.
Something like this.
James Adams is offline   Reply With Quote
Old 02-14-2014, 11:22 PM   #21
markgsnw OP
WTF?
markgsnw's Avatar
Oddometer: 3,592
I think I'll stick with the diode
Old 02-16-2014, 07:41 AM   #22
markgsnw OP
WTF?
markgsnw's Avatar
Oddometer: 3,592
Two diodes in parallel for redundancy
Old 04-23-2014, 04:04 AM   #23
Shaggie
Unseen University
Shaggie's Avatar
Oddometer: 2,652
more info/pics/install on both of these please? linkys to sellers etc? sorry for hijack
S
Shane
"We are not at home to Mr Reasonable" - Sam Vimes
NZ Touring pics:Brass Monkey 2009:Kiwi Sun:Tiki-touring: Daytrips in NZ
Shaggie is offline   Reply With Quote
Old 04-29-2014, 09:06 PM   #24
markgsnw OP
WTF?
markgsnw's Avatar
Oddometer: 3,592
S
What is it that you are asking for?
Sent from my iPad using Tapatalk
Times are GMT -7.   It's 02:09 AM.
