Old 02-02-2014, 03:31 PM   #1
tyreybel OP
Oddometer: 23
Bad gasket Replacement = Wont Start
Bike was running around 3000 rpms at idle this fall. Still rode it a lot. But wanted to get it in good running condition.
Engine had a horribly degraded head gasket (you could see air coming out), so I took it apart and replaced all the top end gaskets. Adjusted the valve shims and had a shop change my valve seals while I had it apart.
Also took some rust off the exhaust pipes and clear coated them.
Put it back together and it wouldn't start. Got a good spark on the plugs and the cams all rotated smoothly, so i figured it was the carbs.
Took the carbs off and cleaned them, they are getting oodles of gas now, and there is a new filter in the intake.
Still wont start and I am flat out of ideas.
Anyone have a thought?
tyreybel is offline   Reply With Quote
Old 02-02-2014, 03:38 PM   #2
tyreybel OP
Oddometer: 23
Here is a video for how it sounds
https://www.youtube.com/watch?v=Lw6_...e_gdata_player
And the original gasket issue
https://www.youtube.com/watch?v=u1Nu...e_gdata_player
Old 02-02-2014, 03:38 PM   #3
anotherguy
anotherguy's Avatar
Oddometer: 6,207
Cam timing or valve clearance too tight.
Old 02-02-2014, 03:53 PM   #4
bisbonian
bisbonian's Avatar
Oddometer: 1,025
+1
Double check your timing.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 02-02-2014, 03:56 PM   #5
mcma111
mcma111's Avatar
Oddometer: 11,864
Is there gas in the tank??
Got spark???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-02-2014, 04:16 PM   #6
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,311
As noted above...
Pull a spark plug out and see if it has gas on it. Insert it back into the spark plug cap, lay it across the top of the motor so the metal base of the plug is in contact with the head. Switch the key on and press the starter button, do you have a good strong spark at the plug gap ?
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 02-02-2014, 04:21 PM   #7
tyreybel OP
Oddometer: 23
Spark is good on all the plugs, pulled them and they are all strong blue.
Can timing is good. Double checked when assembling, and is turns over smooth if I do it manually.
And haha Yea, it has gas. I've forgotten that enough times
Checked valve clearance with gauge. All clearances in spec.
Old 02-02-2014, 04:46 PM   #8
anotherguy
anotherguy's Avatar
Oddometer: 6,207
Time to check cranking pressure. On all four holes.
Old 02-02-2014, 05:21 PM   #9
tyreybel OP
Oddometer: 23
Waiting for an ordered compression tester to come in. Will report back.
Thanks for all the tips
Old 02-02-2014, 05:23 PM   #10
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,311
Ignition timing 180 Deg out ? Have you sprayed any "helper" into the air box while cranking to see if you get it to light or pop ?
Mike
Old 02-02-2014, 05:29 PM   #11
tyreybel OP
Oddometer: 23
Nope, I haven't tried any starter fluid. Was hoping that I can get it going without. But Yea I will give that a try.
Old 02-02-2014, 06:36 PM   #12
joexr
Oddometer: 3,773
Mike
This is a good point. You could switch the two inner spark plug caps with the outer two.
Old 02-02-2014, 11:55 PM   #13
PeterW
Oddometer: 2,595
Be a bit careful here, it's quite hard to steer a bike that's running backwards.
Pete
PeterW is offline   Reply With Quote
Old 02-03-2014, 05:13 AM   #14
trailer Rails
trailer Rails's Avatar
Oddometer: 3,344
Why is it that people hesitate to reach for the starter fluid? I have seen a couple threads here recently where people where having starting issues and refused to use starting fluid. I use the stuff all the time, it is a lot easier to adjust a carb when the bike runs. Is there something I am missing?
trailer Rails is offline   Reply With Quote
Old 02-03-2014, 06:55 AM   #15
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,739
In this video, it doesn't sound like there is any compression
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Times are GMT -7.   It's 09:51 AM.
