Old 02-16-2014, 08:32 AM   #46
effensteve
Enjoying the ride
effensteve's Avatar
Oddometer: 697
Was that the initial start-up after the rebuild, or does it have a little time on it? Rebuild + low weight break in oil will smoke and knock/ ping a little.
effensteve is online now   Reply With Quote
Old 02-16-2014, 10:29 AM   #47
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,537
First run??? That little (or lots) of oil from the wet tests can smoke for quite a long time.Sniff test??? Smells like oil or gasoline????
Another compression check for sure but the vacuum carb synchronizer can also tell if there are leaky valves. That's in how you interpret the movements of the needles. I have that on paper I think, came with my single gauge but will also apply to most "synchronizers" even my old mercury columns one.
Have tools, will travel!
Old 02-16-2014, 03:57 PM   #48
tyreybel OP
Oddometer: 23
Yea that was the first warm up. I did a wet compression test only in cyl #4 though so I'm worried about it smoking so much.
What would you all recommend? I am going to work on adjusting the carbs tomorrow, but is it OK to run up to warm with it sounding so bad?
tyreybel is offline   Reply With Quote
Old 02-16-2014, 05:31 PM   #49
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,312
No, you need to find the source of the noise and correct it before moving on.
Depending on what the source of the noise is it could affect the running of the engine.
Can you do another video with sound, moving the mic around to try and pin point the source ?
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is online now   Reply With Quote
Old 02-16-2014, 06:11 PM   #50
Mrmerlin
K1300S fast as shi..
Mrmerlin's Avatar
Oddometer: 331
Sounds like your getting close...
However, before you run the engine again,
check the valve clearances,
if they are off from where you set them,
IE some of the gaps are wider than where you set them
then you most likely have bent bent valves,
if the clearances are good, then do a compression check,
NOTE make sure the cam chain is at the proper tension,
it can rattle on the engine case,
and recheck the timing
Mrmerlin is offline   Reply With Quote
Old 02-24-2014, 04:27 PM   #51
tyreybel OP
Oddometer: 23
Welp....
Ran it again to adjust the carbs. The smoke stopped and the engine is running much better now.
I adjusted the points a little too, so I think that has helped.
That's all for now! Thanks for all the help everyone. Maybe I'll do some more maintenance this summer...
Old 02-24-2014, 06:59 PM   #52
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,739
Did the clicking sound go away?
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is online now   Reply With Quote
Old 03-04-2014, 07:49 PM   #53
tyreybel OP
Oddometer: 23
It is still there at very low RPMs when the engine hasn't yet warmed up.
The sound was present before I began working on the bike and is now present after I sent the head off to a local shop for them to inspect valves and evenness. I honestly can't think of what it is.
Old 03-05-2014, 10:11 AM   #54
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,537
Clickety click....you don't want to listen to my bike at idle if just for the clicks & rocks. But normal for them....
Yours??? Worn cam chain? That would do that. Did you arc it sideways when you could see it? New ones can't be arced much if at all. As the pins wear they sure arc. Worse case scenario you'll see the side plates get closer or farther apart. AND click as they climb the gears.
Depending on the wear, they can click for a very long time before things get worse but then again depending on wear you may never get a smooth engine.
You can maybe get an idea of the chain wear moving the crank back & forth at the alternator and see if there is any play there before you encounter the resistance from the valve train/camshafts.Too late for pics, the old Honda XL500 is apart but holy crap....I think we could get 60-70 degrees rotation at the alternator before the cam even moved.
Old 03-05-2014, 11:57 AM   #55
fast4d
Oddometer: 2,278
I think a quick way for you to find the actual problem and to get your bearings.... a leak down test should be done with each cylinder at TDC.
check valve clearance while you're at TDC.
if those check out then know you have sound mechanicals and you can look at fuel or spark.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is online now   Reply With Quote
Old 03-06-2014, 04:45 PM   #56
itsatdm
itsatdm's Avatar
Oddometer: 4,819
It still doesn't sound like the timing is correct. Any chance you switched cams? Intake for exhaust and visa versa. Sounds like a bent valve also. If it is, it won't close all the way and you will excessive valve clearance on the bent valve. Probably in the range of 1/4"
itsatdm screwed with this post 03-06-2014 at 09:47 PM
itsatdm is online now   Reply With Quote
Times are GMT -7.   It's 06:57 PM.
