Old 02-03-2014, 09:33 AM   #1
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
BMW 650GS/Dakar/Sertao YZ/WR suspension upgrade
Axle kit - A$350.00
Axle and nut - 4140 steel, nickel plated
Right spacers - 304 Stainless Steel
Left spacer(with bearing cover) - 6061 T6 hard anodised
Calliper Hanger - A$125.00
Calliper hanger - 6061 T6 Aluminium, Anodised
Mounting holes - M8 with 102mm pitch
Please Note: this calliper hanger is designed to be used with 46mm and 48mm 'Open Cartridge' forks.
Closed Cartridge or SSS forks have a different hole pitch for the calliper mount.
Please make sure what forks you have before purchasing this calliper hanger
Swing arm 25mm raising links - $105.00 - Sorry guys, unavoidable price increase.
Links - 6061 T6 Aluminium, Anodised.
Bearings, seals and bushes are NOT included
ABS sensor bracket(Old Style) - $25.00
Bracket - 2mm 304 Stainless Steel
Bolts included
ABS sensor bracket(New Style) - $35.00
Bracket - 6061 Aluminium
Bolts included
Cable Guide - $30.00
Cable Guide - 4mm Stainless Wire
Hooter Bracket - $15.00
2mm Stainless Steel
Fender Support Bracket - $30.00
As you can see the mounting holes have been updated to include the BMW lower clamp holes. So the support bracket can now be used to strengthen the fender on an OEM BMW front end and a Yamaha converted front end
2mm Stainless Steel
Hooter and Fender Bracket Installation Guide
8mm Neck Spacer with bearing cover - A$30.00
I want to keep this post as simple and clean as possible. Any further info required please don't hesitate to contact me. PM or email
For those who have already purchased, please feel free to add any feedback below.
And pictures of your installations please. Lots of pictures.
Cheers
Craig
Aquatic screwed with this post 12-26-2014 at 06:26 AM
Aquatic is offline   Reply With Quote
Old 02-03-2014, 09:37 AM   #2
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
Aluminium Case Saver - BMW 650 Engine
Case Saver - $110.00 - Sorry guys, I've had to put the price up $15.00
To suit a rotax 650 donk
BMW F650GS(single), BMW F650GS Dakar, BMW X-Challenge/Country/Moto, G650GS, G650GS Sertao, Husqvarna TR650 Terra/Strada
Within reason you can choose your colour if you are prepared to wait for the next batch.
Otherwise I will be making in these basic colours which pretty much cover all basic requirements
Black - Bronze - Red
GunMetal - Clear - Blue
Aluminium 6061 T6, Anodised
On the bike
150g/6oz
Deceptively light
Anyone interested, PM or email me
A special request from the Husqvarna boys
Aquatic screwed with this post 08-16-2014 at 05:10 AM Reason: Added Product
Old 02-03-2014, 09:38 AM   #3
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
Foot Peg relocation brackets
Footpeg relocation Brackets - $195.00
There are 4 different mounting positions. And rotating the channel 180 moves the pegs 5mm up or down.
So that makes 8 different positions all up
From 35mm to 70mm offset to the rear
from -7.5mm to +7.5mm up and down
4 sets of mounting holes
BMW OEM footpegs
Yamaha WR/YZ footpegs
Brackets - 4mm Stainless Steel
Plus a bracing plate of 3mm to strengthen the channel mounting threads.
Bolt on interchangeable peg mount channels - choice of Yamaha or BMW
Aquatic screwed with this post 06-20-2014 at 09:20 AM
Old 02-03-2014, 09:39 AM   #4
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
Place Holder 3
Evan more goodies to follow
Old 02-24-2014, 06:28 AM   #5
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
Current stock available
5 - axle and hanger kits
2 - suspension linkage kits
1 - ABS bracket
1 - hooter fender bracket kit
Cable guides are made to order
1 - footpeg relocation brackets
Anyone got a project on the go?
Old 02-27-2014, 07:11 AM   #6
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Laugh
I'm interested in a fender support bracket. How do I go about ordering?
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 02-27-2014, 07:22 AM   #7
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
Check your PM
Old 03-10-2014, 09:10 PM   #8
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
1 - suspension linkage kits
1 - ABS bracket
Update
Old 03-22-2014, 11:50 AM   #9
Linusp3
Linusp3's Avatar
Oddometer: 191
RATEL engineering design - BMW 650GS/Dakar/Sertao YZ/WR suspension upgrade
I have had the foot peg relocation brackets mounted on my bike a while now, but I have not had a chance to ride the bike until just earlier today...
The brackets are beautifully crafted and the mounting was piece of cake; everything fitted perfectly, except I needed to change the top bolt on the left side bracket since the original bolt had a bit too large head.
Use a bolt like this instead;
The original foot peg+brackets (left + right) weighs 1350g, Aquatics bracket+my new foot pegs (heavy ass 380g pegs) weighs 1280g, so it's definitely lighter for all you weight weenies out there. With lighter pegs even better!
On the bike the new setup gave me a much better riding position sitting down, I'm 185cm tall (would be somewhere around 6"1 for non metric guys) and the cramped bent knees position are all gone now. Standing up riding are suddenly a dream... it might be the joy of the moment, but it actually felt like the bike handled totally different (read; much better). Riding standing with the original pegs always made me a bit uneasy and made my feet hurt, such a difference with the wider pegs!
The only downside (which I already was aware of before mounting the new brackets) are the brake lever now are a bit too far from the peg. I tried bending it a bit in a vice and it got a bit better, but I guess something else have to be done in the long run...
The shifter are no problem reaching, and perhaps even better a bit more forward since I always are a bit scared of getting my foot caged in a unfavourable angle between the foot peg and gear lever shifting up while riding rough terrain... my large feet!!
Last words are I'm sooo pleased with the new setup :)
I only rode a local fire trail today, but next weekend I'm going overseas to Jylland, Denmark to try it out in the dunes....
Linusp3 screwed with this post 03-22-2014 at 12:04 PM
Linusp3 is offline   Reply With Quote
Old 03-22-2014, 03:24 PM   #10
Kainic
Almost there
Kainic's Avatar
Oddometer: 380
The look top notch. How do these compare to the TT relocation pegs? Are they the same distance pulled rearward?
Kainic is offline   Reply With Quote
Old 03-22-2014, 03:59 PM   #11
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
A little further.
Mine are 60mm offset, same height. TT are 50mm as far as I know
Old 05-02-2014, 07:11 AM   #12
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
Have a look at post 2
http://advrider.com/forums/showpost....83&postcount=2
Old 05-11-2014, 03:15 PM   #13
TimHammerich
Oddometer: 3
contact
How do I get your contact info. I am intrested in the foot peg relocation.
TimHammerich is offline   Reply With Quote
Old 05-19-2014, 06:38 AM   #14
Aquatic OP
Aquatic's Avatar
Oddometer: 1,590
Case Savers
I have 1 Blue one in stock
Taking orders for the next batch. If you get your name on the list early enough you get to choose your colour.
Old 05-20-2014, 06:27 AM   #15
wiz.au
wiz.au's Avatar
Oddometer: 573
I have 1 Blue one in stock.
If I wasn't so happy with the acetyl one....
In the event of a chain failure, I actually think the acetyl version is going to be better at absorbing the impact. It's softer than the alloy and will deform, absorbing the energy. And it looks tough in black! ;)
But the blue alloy would look trick if I ever washed my bike for a show&shine...not likely!
Posted from a tiny keyboard on my phone.
"That guy with the tag on the back of his jacket, he's got a different chip in his head..."
wiz.au is offline   Reply With Quote
Times are GMT -7.   It's 08:21 PM.
