Old 02-07-2014, 07:07 PM   #1
nomad guy OP
A legal alien
nomad guy's Avatar
Oddometer: 814
110V Thermo-switch. Need advice
Hi All,
Part of a remodel project at a customer's house is an audio room.
Basically a large closet size room where all the electronics are going to reside on a designated rack.
A temp of no more then 75F needs to be maintained in the room.
We installed a Panasonic 50cfm Whisper Ceiling exhaust fan.
I need a a thermo-switch to control the fan.
It needs to fit either in a single/double gang box or inside the fan housing.
Any ideas of a model and where to source would be welcomed.
Cheers
Guy
04 KTM ADV 950S GO!!!!!
09 KTM 690 ENDURO R
nomad guy is offline   Reply With Quote
Old 02-07-2014, 07:21 PM   #2
_cy_
Oddometer: 6,047
http://www.grainger.com/product/Thermal-Switch-44F234
about $16 surface mount in several temps
Old 02-07-2014, 08:05 PM   #3
broncobowsher
broncobowsher's Avatar
Oddometer: 1,511
There are also line voltage thermostat available.
Couple of quick grabs off a Google search
http://www.grainger.com/category/lin...ecatalog/N-ju9
http://www.johnstonesupply.com/store...027857-p1.html
Lots more. Finding the right search words is often the hardest thing.
https://www.google.com/#q=line+voltage+thermostat
broncobowsher is online now   Reply With Quote
Old 02-07-2014, 08:24 PM   #4
nomad guy OP
A legal alien
nomad guy's Avatar
Oddometer: 814
Thanks, guys. Very helpful.
I guess a trip to Grainger is in my near future.
Cheers
Guy
09 KTM 690 ENDURO R
Old 02-07-2014, 08:39 PM   #5
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,681
Talking
Try Amazon. Grainger is a rip off. Close on rise (75 or less) switch.
Are you sure a ceiling fan will supply enough cooling?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 02-07-2014, 09:20 PM   #6
bmwdon75
Street Adventurist
bmwdon75's Avatar
Oddometer: 198
Be sure to specify a cooling thermostat, perhaps this would fit the bill.
http://www.grainger.com/product/DAYT...Code=P2IDP2PCP
The specs say it will fit in a handy box but I would use a 4s deep with a single gang mud ring.
bmwdon75
K75s
bmwdon75 is offline   Reply With Quote
Old 02-08-2014, 05:46 AM   #7
trailer Rails
trailer Rails's Avatar
Oddometer: 3,370
It should as long as the house does not get above 75.
trailer Rails is online now   Reply With Quote
Old 02-08-2014, 06:42 AM   #8
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,681
Depends on how much heat the audio equipment emits, the size of the room, insulation and ventilation in the room etc...
http://www.energystar.gov/?c=roomac.pr_properly_sized
Ceiling EXHAUST to atmosphere fan not a regular ceiling fan. My bad.
http://www.amazon.com/Thermostat-Swi...thermal+switch
Cheapest one I could find.
http://www.amazon.com/White-Rodgers-...age+thermostat
Watch out for cool breezes behind walls that will mess up the thermostat control.
D.T. screwed with this post 02-08-2014 at 06:56 AM
Old 02-09-2014, 05:43 PM   #9
Patriot4570
Trail Blaster
Patriot4570's Avatar
Oddometer: 2,742
Grainger is the way to go .There is a store about 3 miles from the crib.They have a lot of items and will test stuff out for you. I had an air compressor that had a bad capacitor they tested it and I got it running with a new one.
I've learned that pleasing everyone is impossible, but pissing everybody off is a piece of cake.
Patriot4570 is offline   Reply With Quote
Old 02-09-2014, 05:48 PM   #10
Midnightventure
Oddometer: 738
Air moving in a closed space will actually raise the temperature. Especially with the electronics the air needs to be changed or air conditioned.
Midnightventure is offline   Reply With Quote
Old 02-09-2014, 07:01 PM   #11
trailer Rails
Oddometer: 3,370
Retread the first post, he is using an exhaust fan.
Old 02-15-2014, 10:15 AM   #12
Spam16v
Squid Rocket
Spam16v's Avatar
Oddometer: 797
how about a regular thermostat and a relay?
Spam16v is online now   Reply With Quote
Old 02-15-2014, 01:46 PM   #13
broncobowsher
Oddometer: 1,511
Don't forget a power supply to run the thermostat as well. Getting complicated for something that there are off the shelf parts to make work just fine.
Old 02-15-2014, 03:17 PM   #14
trailer Rails
Oddometer: 3,370
You don't need all of that, they make 110v thermostats for baseboard heaters.
Old 02-15-2014, 05:39 PM   #15
broncobowsher
Oddometer: 1,511
That cycles backwards from what the OP is desiring. Baseboard thermostats open on rise, the OP needs the contacts to close on temperature rise.
I was pointing out the post above about using a relay with a regular thermostat. You would also need to add a power supply that could run the thermostat and relay, thus overly complicated.
Times are GMT -7.   It's 10:32 AM.
