Old 02-15-2014, 07:23 PM   #16
trailer Rails
trailer Rails's Avatar
Oddometer: 4,912
Originally Posted by broncobowsher View Post
That cycles backwards from what the OP is desiring. Baseboard thermostats open on rise, the OP needs the contacts to close on temperature rise.
I was pointing out the post above about using a relay with a regular thermostat. You would also need to add a power supply that could run the thermostat and relay, thus overly complicated.
Oops, yea, backward. Wonder if they make 110v cooling thermostats?
trailer Rails is online now   Reply With Quote
Old 02-16-2014, 12:40 PM   #17
Spam16v
Squid Rocket
Spam16v's Avatar
Oddometer: 857
I say again how about a regular thermostat? Mine runs on 2 AA batteries. Simple 110v relay...problem solved...
Spam16v is offline   Reply With Quote
Old 02-16-2014, 07:59 PM   #18
broncobowsher
broncobowsher's Avatar
Oddometer: 1,890
More then likely the 2AA is a backup. You would still need a power supply to power the relay. The thermostat is just a switch, you need power for that switch to turn on and off. Not line voltage for a regular thermostat or we would not need this thread.
So yes, your thermostat has 2AA batteries in it. I have owned several that didn't even have that. How long would a pair of AA batteries last powering a relay (if it even worked that way, which it doesn't)? I can get a couple hours out of a standard flashlight on a pair of AAs. A good relay will suck more power then a tiny incandescent bulb. So there are too many flaws in this plan. Give up on a standard thermostat. Yes, it can be made to work. But isn't simple, and there are simple solutions to this problem.
broncobowsher is offline   Reply With Quote
Old 02-17-2014, 02:10 PM   #19
BrianCa
airheads and stuff.
Oddometer: 24
I would consider something like this:
http://www.amazon.com/Thermostat-Swi...ref=pd_cp_hi_2
BrianCa is offline   Reply With Quote
Old 02-20-2014, 10:14 AM   #20
Plaka
Brevis illi vita est
Oddometer: 4,615
Originally Posted by nomad guy View Post
Hi All,
Part of a remodel project at a customer's house is an audio room.
Basically a large closet size room where all the electronics are going to reside on a designated rack.
A temp of no more then 75F needs to be maintained in the room.
We installed a Panasonic 50cfm Whisper Ceiling exhaust fan.
I need a a thermo-switch to control the fan.
It needs to fit either in a single/double gang box or inside the fan housing.
Any ideas of a model and where to source would be welcomed.
You got 50CFM worth of air inlet (low down) to the room, right?
Old 02-21-2014, 07:37 PM   #21
climberevan
planning the next journey
Oddometer: 315
Another thing to consider (especially if the house is newer) is that the exhausted air will have to be replaced somehow. I would expect that fan to be running a LOT (amps and whatnot can create quite a bit of heat), and if the house is really air-tight (as it should be), you'll have to provide a way for the air to come in.
Alternatively you could vent the air back into the conditioned space--perhaps into an adjacent room. The Panasonic fans are great, btw. I recommend them to all of my customers, who are universally impressed at how quiet they are. I recently used one in a recording studio mix room to ventilate some electronics, and even those discerning ears found it acceptable.
KTM 200EXC, 525MXC, R1100GS, Seven Axiom Steel, Spot SS 29er, Echo trials, Giant Trance 27.5
climberevan is offline   Reply With Quote
Times are GMT -7.   It's 04:41 AM.
