Old 02-09-2014, 10:23 AM   #16
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,418
2 brush starters(most bikes) 180 degrees... 4 brush starters(most cars) 90 degrees to reverse rotation.
OldPete is offline   Reply With Quote
Old 02-09-2014, 11:00 AM   #17
Motopsychoman
Not a total poseur
Motopsychoman's Avatar
Oddometer: 812
Eek Backwards charging
Yes, you can reverse charge a lead-acid chemistry. But, it will not have any capacity whatsoever. The battery is toast. It will self-discharge very rapidly.
Also, any battery that has been run to 0.0 volts is toast. Safe discharge levels for lead-acid chemistry is around 70% to 75% of float voltage. For a typical 12V battery that is about 10.5 volts (75% of 13.7V).
Batteries that are designed for deep discharge can be run down lower, but most are only rated to about 55%.
AGMs are more durable than flooded (wet-cell) batteries, but shouldn't routinely be run down below 70%. At 10.5V, there is very little capacity left in the battery.
"It's a topsy-turvy world, and maybe the problems of two people don't amount to a hill of beans. But this is our hill. And these are our beans!" - Frank Drebin
Current Rides: '13 Sertao, '98 Bandit 1200, Currently a 1200 piece puzzle: '86 R80G/S PD
Past: '66 Suzuki T10, '72 CL350, '74 GT550, '80 GS750, '7? XT500, '83 RM250, '85 XT500
Motopsychoman is offline   Reply With Quote
Old 02-09-2014, 01:18 PM   #18
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,364
Originally Posted by eric1514 View Post
6V yes, positive ground, no.
Wiring Diagram
''66 was the first year for 12v, 1300cc, & it was also the first year they dropped the dual link front end.
If my foggy memory is correct.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 02-09-2014, 02:25 PM   #19
eric1514
(R)
eric1514's Avatar
Oddometer: 306
66 was the only year of the 1300. It was still 6v. 12 volt happened in 67.
Scroll down to the middle of THIS PAGE if you don't wanna believe me.
eric1514 is offline   Reply With Quote
Old 02-09-2014, 03:19 PM   #20
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
I had a '66 I cut up for a dune buggy. 6V, I remember my bud EXPLODING the battery jumping it with a 12 truck (running!! 13.6V!!) and the front end was the standard twin horizontal beams with torsional leaves. It was a 1300. Sure of that, after I blew it up, and had to buy cyls, pistons, head, etc
Old 02-10-2014, 09:51 AM   #21
markgsnw
WTF?
markgsnw's Avatar
Oddometer: 3,592
Originally Posted by concours View Post
This. The Brits had positive earth on cars and bikes.
So did the Yanks. My dad's Pontiac was 6 volt positive ground. Sometime in the late 50's it was discovered that negative ground was a better set up.
http://vasaphoto.wordpress.com/
2011 Moto Guzzi Norge 8V GT
markgsnw is offline   Reply With Quote
Old 02-10-2014, 10:55 AM   #22
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,364
Thanks for the correction. Foggy times, back then.
Old 02-10-2014, 12:40 PM   #23
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,541
Many UK automotive applications were pos.(+) ground. My brother's Triumph motorcycle is + ground....Joe Lucas!!!??!!
def is online now   Reply With Quote
Old 02-10-2014, 12:56 PM   #24
ttpete
Oddometer: 6,039
Original VW was link and pin front end with 2 torsion bars. At some point they switched to link and 2 ball joints, still torsion bars. The Super Beetle had McPherson struts and coil springs.
6 volt Fords were positive ground, as were 12 volt Lucas equipped Brit cars and bikes.
Old 02-10-2014, 06:54 PM   #25
P B G
Oddometer: 10,001
Never seen that happen.
Jumped 6V porsches, tractors, trucks etc.
I have an 8V battery around specifically these days for when such vehicles act up.
Old 02-13-2014, 09:07 AM   #26
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,639
Assuming things are as they should be are often the culprit...
My BIL had a little honda car, local shop made an engine swap with a complete motor including accessories.
Tech could not get car to run correctly, different codes getting thrown out, sensors, wire harness, and ultimately the CPU was replaced over the course of a couple weeks. No go.... same issues. Bad CPU? tried 2 different ones... same result...
Tech ended up referring car to local dealer out of frustration, same thing, harness, cpu, same result...
At this point the car had been mulled over by a dozen people, ultimately it was the suggestion of a onlooker at the dealer that someone ought to replace the alternator.
Problem solved, alternator was supplying dirty current to system and ultimately causing the erratic behavior and apparent wire harness and cpu issues..
80$ part literally caused thousands of dollars of labor and parts swapping and stumped more than a dozen people.
Jayrod1318 is offline   Reply With Quote
Old 02-14-2014, 05:44 AM   #27
riverflow
Adventurous Commuter
Oddometer: 975
Originally Posted by trailer Rails View Post
I seem to remember a car that was produced where the cassis was positive. Like a MG or something.
My neighbor has a BSA Royal Star and it's a positive ground. It also has specially sized nuts & bolts so you had to buy their tool to open just about anything. Brits.
-Tyler
'05 BMW F650 GS Dakar
"There is no such thing as bad weather, only the wrong clothes" ~ Billy Connolly.
riverflow is offline   Reply With Quote
Old 02-14-2014, 08:31 AM   #28
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,097
Anybody know why they switched to negative ground? A positive ground system will reduce the corrosion if the wiring gets wet.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 02-14-2014, 10:33 AM   #29
ttpete
Oddometer: 6,039
They didn't do that on purpose. Whitworth was British standard at the time they were built. You should have been around 60 years ago when it wasn't possible to buy metric tools at the local store, either.
Old 02-14-2014, 02:29 PM   #30
eric1514
(R)
eric1514's Avatar
Oddometer: 306
Mostly for standardization.
Times are GMT -7.   It's 06:40 PM.
