Old 02-10-2014, 06:55 AM   #16
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,689
http://www.gottrikes.com/Tube_Bender.htm
Some people have built their own. Probably the best resource is pirate4x4.com in the shop and tools section.
I have a jd2 model 3 and converted to air/hydro with a harbor freight jack. It's a little hoopty, but it works ok. I eventually want to get a real hydraulic ram as I have a spare hydraulic power unit.
The dies for the jd are $150 and up. I have 3-4 total. The actual bender is about $300. They come up for sale often on pirate and clist especially in areas where 4wheeling is popular.
Lots of people have tried to bend tubing without a real bender. There is a reason that it's not a cheap too. To keep the tubing from collapsing and kinking, the dies need to be well engineered. The bends from mine are always perfect and with the hydraulic jack, electronic protractor, and a magnetic angle finder it's not hard to get consistent results.
Fortunately the resale market for dies and benders is very strong. You could buy one used, and sell it after the project and not take much of a hit at all. The jd benders are def the most popular.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 02-10-2014, 12:07 PM   #17
ttpete
Rectum Non Bustibus
Oddometer: 5,949
These are the Cadillac of tube benders. I used them at work.
http://www.diacro.com/benders/hand-operated-benders.php
15 BMW RnineT
09 Kaw Versys
Old 02-11-2014, 08:34 AM   #18
JStory
JStory's Avatar
Oddometer: 2,777
Those look expensive.
Jeff
"He who makes a beast of himself gets rid of the pain of being a man." Dr Samuel Johnson.
JStory is offline   Reply With Quote
Old 02-11-2014, 02:07 PM   #19
TimThePilot
Oddometer: 2
Compact Tubing Bender
I'm faced with a similar issue on my KLX 450 R, there is only one rack available for the bike and it doesn't fit my needs. So, after doing some research, I have come to this conclusion: make it myself. I recently purchased a compact tubing bender from Harbor Freight along with a wire welder. The bender was less than 90 bucks! The welder was less than 115! Went to the friendly neighborhood Home Depot and picked up some 1/2 inch square tubing. It was about 10 dollars a stick. Now I am in the process of building a rack. I've made a couple of bends and welds and both work like a dream! Might consider checking Harbor Freight. Hope this was helpful.
TimThePilot is offline   Reply With Quote
Old 02-11-2014, 02:32 PM   #20
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,603
Edit------- was it this one?
Please post photos when done.
My plan is to do the same thing...going to check out HF bender.
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 02-11-2014, 02:45 PM   #21
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,393
Fred
I bought the HF bender, it doesn't have a stand but I bolt it and all the other benders I have to the corner of my welding table. Works good and easily removed when not needed.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 02-11-2014, 03:15 PM   #22
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,603
Thank You Sir
Another Edit-------interesting video HF Compact Bender
Fred
YouTube feed
USAIR screwed with this post 02-11-2014 at 03:24 PM
Old 02-11-2014, 10:06 PM   #23
yokesman
Oddometer: 514
that hf is for rod and strap.
look at the experimental aircraft sites for bending info,I think some have filled the tube with sand and had good results.
yokesman is offline   Reply With Quote
Old 02-13-2014, 05:08 AM   #24
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,603
I kinda new to metal working so...
I want to make some wolfman type racks
What about these?
Northern Tool $150
Harbor Fright $170
Fred
YouTube feed
USAIR screwed with this post 02-13-2014 at 05:13 AM
Old 02-13-2014, 05:11 AM   #25
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,689
Those roll large radius bends. I have one it's a deal for what you get. Swag off road builds hop up kits for rolling heavy tubing.
They wouldn't be helpful for racks though
Nessmuk
Old 02-13-2014, 06:22 AM   #26
rustycager
rustycager's Avatar
Oddometer: 597
What about these?
Northern Tool $150
Fred
That is the one I mentioned and linked earlier. Did you catch the .047 max wall thickness?
Review of one.
http://www.youtube.com/watch?v=G_9RbST9TeU
Notice the kink and not 180 degree @:45 in this vid.
http://www.youtube.com/watch?v=59qPY3o3jq8
Forgot to add they had it on sale for $100 a week or so ago.
2004 DRZs
rustycager screwed with this post 02-13-2014 at 06:46 AM
rustycager is offline   Reply With Quote
Old 02-13-2014, 06:47 AM   #27
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,603
Review of one.
Boy he didn't like that bender at all.
I'm going to keep looking
Fred
YouTube feed
Old 02-13-2014, 06:52 AM   #28
rustycager
rustycager's Avatar
Oddometer: 597
The bar thing seems like a non issue but the kinks and not being able to get a full 180 would be if you want to copy wolfman. If you wanted to do to make it more square then it might work.
2004 DRZs
Old 02-13-2014, 09:33 AM   #29
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,785
sigh...
Laconic is offline   Reply With Quote
Old 02-14-2014, 04:52 PM   #30
jar944
jar944's Avatar
Oddometer: 697
JD2 or pro tools 105
either will run $700+ new
and those are the cheap tubing benders
jar944 is offline   Reply With Quote
Times are GMT -7.   It's 03:57 AM.
