Old 02-14-2014, 04:56 PM   #31
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,819
Originally Posted by jar944 View Post
JD2 or pro tools 105
either will run $700+ new
and those are the cheap tubing benders
A JD2 model 3 was $300 and the small dies are about $150. You can flip it after you are done and have perfect bends without spending a lot of cash.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 02-14-2014, 06:34 PM   #32
TimThePilot
Oddometer: 2
Originally Posted by USAIR View Post
Edit------- was it this one?
Please post photos when done.
My plan is to do the same thing...going to check out HF bender.
Fred
It is that exact one. I bolted it to a piece of plywood, because I am working in my carport and need to be able to move it to my small shed for storage. Works really well. I'll post some pics when I get the racks completed. Good luck on your build!
TimThePilot is offline   Reply With Quote
Old 02-15-2014, 06:57 PM   #33
Hastelloy-X
Oddometer: 339
Why not buy already bent tubing?
Burns Stainless sells what ever bends you would need.
There are others out there too.
They are mandrel bent without any flat spots or imperfections.
Hastelloy-X is offline   Reply With Quote
Old 02-15-2014, 07:13 PM   #34
flumpmaster
Oddometer: 11
Originally Posted by p0diabl0 View Post
Well if you were on a KLR I'd suggest to you a conduit bender...
KLR owner here....
A conduit bender will give you a 10" OD 180 degree bend with 1/2" conduit. $1.60 for a 10' stick of conduit. The bender is just over $30. I made my back rack with this and several bicycle stands.
Beware of expensive imitations...
As others have said, you can buy ready bent bends from others. I did this when building an exhaust.
flumpmaster is offline   Reply With Quote
Old 02-16-2014, 10:29 AM   #35
p0diabl0
Oddometer: 572
Originally Posted by flumpmaster View Post
KLR owner here....
Former KLR owner here... it was a learning experience.
Ninja 650R Tourer/Commuter, TW200 Playbike
p0diabl0 is online now   Reply With Quote
Old 02-18-2014, 11:45 AM   #36
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,414
I used this 1/2 tubing bender on 1/2 chromoly. Worked fine.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 02-18-2014, 03:24 PM   #37
crackhead
Oddometer: 1,254
You could use 1/2 in square. That's what I used on my GS and it has held up to numerous dumps and overloaded trips.
'98 1100GS - Mine
'02 F650 Dakar - Her's
'01 XR50 - Spawn's
crackhead is offline   Reply With Quote
Old 02-18-2014, 04:06 PM   #38
trailer Rails
trailer Rails's Avatar
Oddometer: 4,917
Do you know the brand or where you got that from?
trailer Rails is offline   Reply With Quote
Old 02-18-2014, 05:37 PM   #39
ttpete
Rectum Non Bustibus
Oddometer: 6,165
The benders are Imperial Eastman.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Times are GMT -7.   It's 09:55 PM.
