Old 02-11-2014, 02:03 PM   #1
NJjeff OP
NJjeff's Avatar
Oddometer: 1,022
P0172 too rich bank 1, where to look.
Car is a 03' Hyundai Accent 1.6L. 104K miles
CEL is on.
Code is P0172, too rich bank 1. (I'm guessing forward O2 sensor picked that up?)
Sometimes when accelerating from a slow speed, low RPM's (car is a stick) it will loose power. Feels like it's running out of gas. Back off a bit & let it gently accelerate than at a bit higher RPM it will accelerate smoothly.
My code reader gives a freeze frame.
So when it threw this code.
45 MPH
185deg. water temp
2160 rpm
12.4 in Hg
10% load
L.T. fuel trim -23.4%
S.T. fuel trim -25%
Looks like it's trying to lean things out. Do I read that correctly?
Fuel filter changed last year.
This car does not have a mass air flow sensor so nothing to clean.
MAP sensor was replaced few years ago under warranty.
Looking online it's pointing to possibly O2 sensor. I hate to throw parts at a problem.
With the software I can (will try it tonight) look at the real time O2 sensor output.
So is it possible to tell a bad O2 sensor with the car just idling, or running on the highway? It's running normal in all other cases.
NJjeff is offline   Reply With Quote
Old 02-11-2014, 02:34 PM   #2
fast4d
Oddometer: 2,278
air leak in exhaust before O2 sensor?
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is online now   Reply With Quote
Old 02-11-2014, 02:42 PM   #3
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 4,900
Try this LINK
Best thing is its free!!
Wasser is offline   Reply With Quote
Old 02-11-2014, 03:14 PM   #4
NJjeff OP
NJjeff's Avatar
Oddometer: 1,022
Originally Posted by Wasser View Post
Try this LINK
The general public can sign up to that?
Old 02-11-2014, 03:36 PM   #5
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 4,900
Yup!
Hyundai is the only manufacturer that does not charge any fee for service information to "joe customer"
Old 02-11-2014, 04:06 PM   #6
NJjeff OP
NJjeff's Avatar
Oddometer: 1,022
The cat on this car is part of the manifold. The front O2 sensor threads right into it. I'm quite positive there are no leaks.
Old 02-11-2014, 04:24 PM   #7
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 4,900
Air leak after combustion chamber would not cause this code to set. Fuel trim is being driven negative.
Old 02-11-2014, 06:33 PM   #8
big-t
Oddometer: 486
Unplug the front o2 and see if it cures the running problem.If not reconnect and clear code.
Also check the fuel pressure regulator.if its a vacuum type there should be no fuel in the hose
big-t is offline   Reply With Quote
Old 02-11-2014, 08:54 PM   #9
showkey
Oddometer: 1,896
Yup!
Where are you guys getting this is free...............$20.00 per one week session.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is online now   Reply With Quote
Old 02-11-2014, 08:55 PM   #10
freetors
Oddometer: 882
Can your code reader give you sensor voltages? It's always good to check that sensors are genuinely reading as they should.
freetors is offline   Reply With Quote
Old 02-11-2014, 09:30 PM   #11
aardschok
Fallout Rider
aardschok's Avatar
Oddometer: 556
Read this link before spending any money on parts.
Good starting point.
http://repairpal.com/OBD-II-Code-P0172-and-P0175
"When you have to shoot...Shoot! Don't talk."
MVT
aardschok is offline   Reply With Quote
Old 02-11-2014, 09:55 PM   #12
NJjeff OP
NJjeff's Avatar
Oddometer: 1,022
Regulator is in tank. I's a return-less fuel system, 1 line up to fuel rail.
I could try to unplug the O2 sensor but the car does run fine in all other conditions.
To clarify it will only go low on power when re-accelerating.
Perfect example, it occurs every day to work.
Slow down from ~35 MPH, downshift and right turn 90deg. on to interstate entrance ramp. It's a tight turn so I go into second gear. It will not have much power so I have to very slowly allow it to build RPM. Once at 2500 rpm (guessing because it has no tach.) it will smooth out and normally accelerate. Now don't jump to conclusions it will do this making left or right turns at any location.
Odd though as it will accelerate from a standstill normally. It will accelerate at highway speeds normally.
As I'm thinking and typing this it's always after a brief slowdown and downshift where it feels like it's running out of fuel, and yes I just got gas today. Fuel tank level has not made a change.
Old 02-11-2014, 10:00 PM   #13
NJjeff OP
NJjeff's Avatar
Oddometer: 1,022
Yes it does. My code reader plugs into a laptop so tomorrows trip to work it's going to be my passenger.
I think it can record a few sensors data over a trip. If so I'll record front O2 sensor and (as I have read online) MAP sensor readings.
Old 02-12-2014, 10:11 AM   #14
NJjeff OP
NJjeff's Avatar
Oddometer: 1,022
Ok ran the OBD reader with live data during drive to work. Oddly enough the car ran nearly perfect today. Only a slight power loss at one moment.
Anyway few things I noticed.
The software can give live data along a moving chart for 2 sensors. It can record data for any sensor selected. I think up to 10 at a time. Trouble is I forgot to press record.
I did watch (when I could) the real time data.
First I selected O2 sensor 1 and short term fuel trim.
Car parked in garage. Outdoor temp. 4 deg.
Within I'd say a few minutes the O2 sensor very quickly began to oscillate between .85 v and .03 v. Values were slightly changing but the high and low centered around those numbers. It switches quickly, I'd guess like 2 cycles per sec.
The short term fuel trim readings are around -2% to 2% when holding a steady speed on flat ground at around 35 mph. the graph makes a wiggled line. If I accelerate or decelerate the trim seems to follow.
I decided to try several sensors.
Water temp (when at normal gauge reading) 185 deg.
Throttle position appears to follow correctly. No "noise" along the graph.
I switched to Intake air temp after about 20 minutes of driving. it was 21deg. By that time it was around 8 deg. outside.
Ignition timing seemed to vary with load. Most I saw was 26 deg. of advance.
MAP readings clearly followed throttle position but seem inverse of my thoughts. Heavy on the throttle gave readings of 24 to 26" Hg. Closed throttle going down hill gave 7" of Hg. Steady state 65 MPH level road was around 15~17". Idle around 10.3"
Rear O2 sensor switched slowly from .8 (something) to .03 (something). Frequency was several seconds before a change.
Only odd thing I noticed is at times the short term fuel trim would drop to -23%. I'll try it again tonight to see if it stumbles and where the fuel trim goes.
This time I'll press record.
Old 02-12-2014, 04:44 PM   #15
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 4,900
First red flag I see. That is if the readings are correct on the scan tool.
Heavy throttle should= lower number (less vacuum, closer to atmospheric pressure)
Closed throttle= higher number (high vacuum)
Normal engine is ~17-22 in. hg at idle. As the throttle plates open, the numbers should start dropping. It looks like yours are going higher. Especially at closed throttle down hill. You should have a very high vacuum reading.
I'd throw an old school vacuum gage on it just to compare readings.
Since your vehicle uses a MAP, it is a speed density system. MAP is a key input for a speed density system. It is used to calculate engine load.
Your readings seem totally out of wack. Could be the scan tool. That is why I would try a "old school" vacuum gage just to compare.
Times are GMT -7.   It's 09:22 PM.
