Old 02-14-2014, 02:15 PM   #1
indr OP
Oddometer: 501
How to fill big broken plastic hole?
indr screwed with this post 02-22-2015 at 09:13 PM
indr is offline   Reply With Quote
Old 02-14-2014, 02:23 PM   #2
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,751
Use some mesh screen to back it. Fiberglass tape for strength. Bondo and paint.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 02-14-2014, 03:32 PM   #3
k-moe
Oddometer: 2,855
Get some black ABS sheet, cut, weld, sand, paint.
Or. Cut the same size hole in the other side, stick a light behind both, and call it custom.
k-moe is offline   Reply With Quote
Old 02-14-2014, 03:51 PM   #4
Beezer
Oddometer: 5,874
fiberglass cloth and black ABS glue.... several layers and a couple extra coats. does it have to look pretty? if so then weld, sand, paint.
Beezer is offline   Reply With Quote
Old 02-14-2014, 04:40 PM   #5
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,630
Talking
I just bought a big roll of black Gorilla tape!
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is offline   Reply With Quote
Old 02-16-2014, 10:18 PM   #6
squish
Out of the office.
Oddometer: 6,355
You can try and look for a busted up matching fender part. Cut the new part in the same size as the hole
And hot air weld it in.
Or get some abs sheet and use a hot air gun to form it into the right shape.
Put a piece of paper behind the hole, draw the outline of the hole. Transfer that shap to the abs only make it bigger to take in account the stretching to fit the profile.
Then hot air weld it. Use a little fiberglass mesh on the back side for some support
Some reinforced body filler to fill and smooth the small gaps
Prime and paint
On vacation for a spell
squish is offline   Reply With Quote
Old 02-17-2014, 02:31 AM   #7
b1pig
Oddometer: 940
this is what i had to weld up on a ZX7
if you can get some ABS sheet and shape it with a welding shoe and a heat gun... you might be able to make the repair. but if you dont already have the tools, getting a replacement part might be cheaper for you. because you'll have to finish/fill/paint the repaired part.
this was the same panel after i was done... you'd never know....
this album has a lot of the photos of the repairs. i didn't have to do too much shaping. the hardest part i had to do was where the left panel was broken at the large air vent. i used more filler there.
https://www.facebook.com/media/set/?...1&l=2293e56788
the golden rule is this. the top repairs are only as good as the base repairs. the better job you do on the panel, the less filler... the better the repair will end up being and the less likely it will fail later.
'07 Jeep JKU Rubicon, '73 Super Beetle, '15 Ram 1500
'08 KLR 650, '07 GZ250 (wife)
b1pig is offline   Reply With Quote
Old 02-17-2014, 02:36 AM   #8
ragtoplvr
Oddometer: 6,519
weld it
Cheap kit
http://www.harborfreight.com/plastic...ure-96464.html
Rods
http://www.harborfreight.com/50-piec...ods-41602.html
also need abs glue, they make abs pipe glue and there are lots of others.
Your local paint and body shop supply store will have a good selection.
Labor intensive
Takes practice. Not normally as strong unless reenforced.
Rod
ragtoplvr is online now   Reply With Quote
Old 02-17-2014, 01:03 PM   #9
Switchblade315
Switchblade315's Avatar
Oddometer: 5,773
This. Plastic welding is easy.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 02-17-2014, 03:41 PM   #10
MotoDaveL
MotoDaveL's Avatar
Oddometer: 430
it is, I welded my KLX side panel after parking the bike forcefully and at speed against a tree. It wasnt ABS plastic but a crappy soldering iron and some shavings from other parts of the panel did the trick.
ABS is kind of nasty to breath in so wear a respirator.
MotoDaveL is offline   Reply With Quote
Old 02-17-2014, 06:59 PM   #11
k-moe
Oddometer: 2,855
Originally Posted by ragtoplvr View Post
weld it
Cheap kit
Rods
also need abs glue, When welding there is no glue required
Labor intensive Much less so than metalwork, and only slightly more work than prepping for paint
Takes practice. Not normally as strong unless reenforced. Actually a welded repair is usually stronger than the originel part, but you must be sure that you use the correct filler rod and amount of heat. Don't bake the plastic until it's brittle.
Rod
Just my experience from 25 years of welding plastics.
Old 02-18-2014, 07:01 PM   #12
k-moe
Oddometer: 2,855
A kit is a good way to get your feet wet without undue stress.
http://plasti-mend.com
Old 02-27-2014, 12:19 PM   #13
kantuckid
Oddometer: 3,104
you need a piece of the same plastic to weld with
take a weller soldering iron & use the "paddle shaped" tip
have a btl of spray water close by to "set" the hot welds
Puddle weld in the piece of plastic you cut to fill the hole. Tin snips are used to cut a "welding rod" for filler
good technique is to tack some spots then finish off the whole weld-also clamps may help initial positioning
some same marked plastic(read the letters on the old part) will give you much free material-get a broken one free from nearest car salvage place or AB shop
it works & much cheaper than glue or kits or HF plastic welders.
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Times are GMT -7.   It's 08:42 AM.
