Old 02-15-2014, 07:05 AM   #1
syntec4 OP
syntec4's Avatar
Oddometer: 1,375
Welding Cart/Bench? What ya got?
Hi all, I want to build/buy a welding cart/bench. Must be on castors so I can push it around for cleaning and working outside. I want to put the MIG on it with small bottle and have the vice mounted on it as well. I don't want it to be that big, maybe 4'x2'6".
Give me some inspiration!
My Smugmug
syntec4 is offline   Reply With Quote
Old 02-15-2014, 07:20 AM   #2
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,415
I keep my welding equipment modular. The torch is generally in it's packing until needed and I rent bottles. The mig and tig welders are on their respective carts. For a table, I use a Stronghand Nomad: http://www.stronghandtools.com/stron...ucts/nomad.php. Which can be folded up and set beside a wall. A Jawhorse w/welding accessory serves a similar purpose and can be folded up and put away. This works out for me since I tend to weld sporadically and let junk accumulate. As usual, YMMV.
Stan_R80/7 is offline   Reply With Quote
Old 02-16-2014, 04:38 AM   #3
josjor
Location: The largest geological formation in the U.S.A.
Oddometer: 2,836
+1 for keeping the welder on it's own cart, separate from the work bench thingy. You can either build the MIG cart or, probably for around $50.00, buy one that will hold the welder and bottles.
http://www.harborfreight.com/100-lb-...art-61316.html
For a welding table I've got a 4' x 6' monster with 3" pipe legs, a shelf underneath for stock and a 3/8" thick steel plate top. Most certainly not portable as the top itself weighs in at 300+ pounds.
Neutiquam erro.
Originally Posted by Stagehand View Post
listen mister, we didnt evolve porcelin shitters just so we could squat to take a shit, like monkeys.
josjor is offline   Reply With Quote
Old 02-16-2014, 08:53 AM   #4
Gillus
High Desert Rat
Oddometer: 792
+2 on the Jawhorse, very handy versatile tool for wood or metal stuff. This is a safety required item for me.
I built a 32" x 48" 1/4 plate and 2" angle frame table with a lower shelf 16" x 48", side shelf/ slot to hold grinders. Heavy enough to mount a vise and use it. $200 worth of new steel.
Mig welder on a separate HF cart.
Plasma on a separate HF cart.
Torch set on a separate hand built cart.
HF metal cutting band saw on wheels parked under the welding table.
Separate scrap metal (pos) cart 16" wide with bins for storing scraps and stock.
Wish ida built this set up years ago. Takes a 32" x 60" footprint plus the grinder on a stand next to it. I'd post some pics but it is covered with remnants of the last project and needs cleaned.
Disclaimer: I am only responsible for what I said........... Not what you understood or how you interpreted my words!!
Gillus is offline   Reply With Quote
Old 02-16-2014, 01:11 PM   #5
syntec4 OP
syntec4's Avatar
Oddometer: 1,375
The jawhorse looks interesting although I'm not sure we get them here. We do have the Triton which looks like a similar concept.. http://www.amazon.co.uk/Triton-SJA20...bxgy_diy_img_y
My Smugmug
Old 02-16-2014, 01:18 PM   #6
Hardware02
Hardware02's Avatar
Oddometer: 3,412
Built this from scratch...
With the Lincoln on board...
Bench from scratch...
"These instructions are at our present level of
knowledge. Legal requirements do not exist.
Technical issues subject to change."
Hardware02 screwed with this post 02-16-2014 at 01:23 PM
Hardware02 is offline   Reply With Quote
Times are GMT -7.   It's 06:19 AM.
