Old 02-15-2014, 03:00 PM   #1
GSFunADV OP
GSFunADV
GSFunADV's Avatar
Oddometer: 6
Time for a new chain
At 18,000 miles my G650 GS needs a chain replacement (red dust coming out of a few links).
And I have a few questions.
What make chain is a good/best replacement for the OEM chain?
I have heard that if the chain is being replaced that the sprockets should be replaced also. But the sprockets on my bike don't show much discernible wear.
So should the sprockets still be replaced?
And if the sprockets need replacement. What is a good/best make sprocket?
What is a good source for the chain and/or sprockets?
Thanks Much,
S.
GSFunADV is offline   Reply With Quote
Old 02-15-2014, 03:35 PM   #2
jon_l
jon_l's Avatar
Oddometer: 3,457
Sprockets are cheap. Buy new ones. Adjust gearing if you wish, now's the time.
O or X chain, I usually buy here http://www.rockymountainatvmc.com/c/583/Drive
Their Primary Drive brand sprockets are fine. Chain is up to you, DID, EK, RK are all fine. Haven't tried Primary Drive chains, might be fine.
Sometime kits with sprockets and chains are available, if what you want, could save $
Clip links are OK with me, install clip with closed side so it pulls towards the C/S sprocket; many prefer rivet. Decide now if you need a chain tool. For clip master links, these are helpful, though not req'd:
CBF1000 & PCX150, PCX Fuelly
jon_l is online now   Reply With Quote
Old 02-15-2014, 03:45 PM   #3
stephen.stallebrass
stephen.stallebrass's Avatar
Oddometer: 272
I like the DID ZVMX with gold links. It's recommended to change the chain and sprockets together but it's not absolute. Don't get the OE chain, it's shite.
I've had the Renthal front sprocket, which was pretty good and cheaper than OEM if I recall. I think I had OEM rear sprockets last time from Motorworks.
www.AdventureVagabond.com Mongolia & Siberia 2012: Adventure Moto Madness
stephen.stallebrass is offline   Reply With Quote
Old 02-16-2014, 05:46 PM   #4
BossMaverick
Oddometer: 245
Everyone has covered the most important things already, and I'm not sure if this hold true to your GS, but sometimes the factory front sprocket has a rubber ring in it. You might notice a little noise difference if you get a solid metal aftermarket sprocket, but it really makes no operational difference.
'09 GSF1250SA Bandit
BossMaverick is offline   Reply With Quote
Old 02-17-2014, 07:05 AM   #5
anotherguy
anotherguy's Avatar
Oddometer: 6,631
I run DID ZVMwhatever and JT steel sprockets on my Tuono and get 30K plus with the caveat the front sprocket gets replaced at 15-16K miles. Current chain has 34K on it and am up in the air about slapping a new front sprocket on and seeing just how far we can go. Use the Dupont teflon stuff from Lowes every other tank of gas or so and rarely clean it.
you don't see luggage racks on a hearse..........act accordingly
Old 02-17-2014, 08:32 AM   #6
TonyKZ1
TonyKZ1's Avatar
Oddometer: 727
I too was needing a new chain and thanks to that link above from rocky mountain, I just ordered new sprockets and chain for my '97 Yamaha Seca II.
Thanks, Tony
1997 Yamaha Seca II - mostly stock, Oxford Sports Style Heated Grips, Barkbusters Blizzard Cold Weather Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old 02-17-2014, 08:45 AM   #7
JayRitz
Oddometer: 21
Good place to get some parts: Amazon.com
Bought chain and sprockets at the end of last year for my BMW F650 last fall off of Amazon. DID chain and JT sprockets. Cost was much cheaper than I expected. There are even sets that that you can buy - just make sure they are specifically for your bike.
'97 BMW F650
JayRitz is offline   Reply With Quote
Times are GMT -7.   It's 10:03 AM.
