Old 02-17-2014, 12:46 PM   #1
ohgood OP
ohgood's Avatar
Oddometer: 2,727
tubed tire will not seat - sorry search is broken
apologies, the search never happened. google fu/foo/fool is weak.
+1 new front sedona knobby, looks round to me
+2 hours on the trucks bed liner in the sun
+1 drz front wheel (cause the back would be difficultererer)
+ 1 gallon dawn + water, or wd40, or motor oil, or well, i've tried everything in the garage now
+85psi
the damned thing still won't set in the bead as it should. i've a stack of tires taller than me that didn't have this problem.
i've gone up/down on the pressure but 85 psi was my limit. i really don't want to get impaled. i've hammered on it, dropped it from shoulder height, rode it at 30 mph with 8psi, rode it at 70mph at 20 psi, kicked it and used all my really good cuss words.
it will not seat.
ideas not covered already ?
(yes, the tire is in the rim lock correctly, no it's not tightened yet)
(yes, i cleaned the rim/bead)
(yes, i put a 21" tube in, not a 26, or 700c, or whatever)
ok, fire away.
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 02-17-2014, 01:43 PM   #2
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
deflate completely, core out, squeeze tire inward to expose bead area, slather with soap/water mix, quickly inflate, install core, enjoy
Old 02-17-2014, 01:53 PM   #3
Switchblade315
Switchblade315's Avatar
Oddometer: 5,562
Go to a tire shop and get a glob of some of that lube they smear on a tire before they mount them. Or come to Ms. And I'll send you home with some.
Get some of that, break the bead and lube like mad. It drys clean inflate and it should go. I've never had it fale me and I've seen it work when other things will not.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 02-17-2014, 01:59 PM   #4
CrazyTed
CrazyTed's Avatar
Oddometer: 63
Also be sure there's nothing on the rim in the way. I've seen guys use duct tape on their rims to cover the spokes and they put it out too far where the bead goes. Also, I've seen guys with rims that are corroded and the corrosion prevents the bead from seating.
CrazyTed
Virginia Beach, VA
08 Triumph Rocket III
2010 Husaberg FX450 for sale
CrazyTed is offline   Reply With Quote
Old 02-17-2014, 02:18 PM   #5
Lucida
Oddometer: 3
Got the same problem, no matter what I did, it just don't seat. Learn from youtube by using tie wrench, it become very easy to seat the bead. problem solved.
Don't forget to take the change to do the balance. This is also very easy, no need a fancy balance machine.
1 cylinder -KDX220
2 cylinders-Suzuki Murader
3 cylinders-BMW K75
4 cylinders-Yamana Maxim 700
Lucida is offline   Reply With Quote
Old 02-17-2014, 04:49 PM   #6
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,426
Also try pushing the tyre in to the rim a bit opposite the area where it won't seat, as you inflate. My 640 front wheel can be a PITA like that with some tyres.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 02-17-2014, 10:18 PM   #7
RVDan
RVDan's Avatar
Oddometer: 2,600
Ask for some better cuss words in Jomamma
Break the bead and move the tire on the rim, you've obviously got two sticky spots in the same place.
It is a 21" tire right?
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 02-18-2014, 05:20 AM   #8
AlfromNH
Oddometer: 81
I just went thru this with tubed street tires on cast rims. I got a gallon jug of RU-Glyde from Pep Boys, slathered that on and the beads slid right into place
AlfromNH is offline   Reply With Quote
Old 02-18-2014, 05:21 AM   #9
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,261
by far the best lubricant i've used is windex - i have tried them all, and it has worked everytime for me.. make sure rim and bead is clean and rim is straight/not bowed out or in at bead. lubricate, rotate tire 90 degrees on rim. lubricate again. put bad spot up, and push down moderately on rim as you inflate quickly to 40psi or so. wait a while.. if it doesn't seat, pull core, and repeat. riding on it will not seat it.
current bikes
stainlesscycle screwed with this post 02-18-2014 at 05:27 AM
stainlesscycle is offline   Reply With Quote
Old 02-18-2014, 07:43 AM   #10
ohgood OP
ohgood's Avatar
Oddometer: 2,727
i use duct tape, without a big controversy, I'll double check what you suggested. thanks!
Old 02-18-2014, 07:44 AM   #11
ohgood OP
ohgood's Avatar
Oddometer: 2,727
I Balance on the bike, after prying out the pads a little. thanks for the reminder
Old 02-18-2014, 07:45 AM   #12
ohgood OP
ohgood's Avatar
Oddometer: 2,727
good idea, I'll give it a shot. thanks, yes, it's a 21"wheel with tube
Old 02-18-2014, 07:46 AM   #13
ohgood OP
ohgood's Avatar
Oddometer: 2,727
OK, I'll slather some more, thanks!
Old 02-18-2014, 09:01 PM   #14
Little R
Oddometer: 67
Did you get it to pop?
Little R is offline   Reply With Quote
Old 02-18-2014, 09:09 PM   #15
ohgood OP
ohgood's Avatar
Oddometer: 2,727
this ones the winner. I had cleaned, but not well enough. the glue from the tape plus dirt and oxidized aluminum looked to be minimal, but wasn't and blended into the corner of the rim.
was it enough to scrape, sand, and finally clean ?
no. 75psi finally pushed it in place.
won't be using duct tape (for that) again.
the garage rocks, thanks guys!
Times are GMT -7.   It's 11:08 PM.
