Old 02-19-2014, 01:25 AM   #1
john82q OP
john82q's Avatar
Oddometer: 24
Lower front mount advice
I am a long time lurker and only post on here occasionally, I do value the opinons of this forum.
So a little back ground story
My outfit is a 84 suzuki GS1100G with a DJP side car. Loaded with passenger and gear about car wieghs about 150Kg I like to ride as hard as i can in the twistys, She gets a work out.
The outfits been together for about 20 years that I know of I have had it for 5 and ive done about 60K on it
So I figure it was only a matter of time before something broke.
this welded stack of washers not my work and while ugly never gave any trouble, seems the tube crack fatigued n broke
And going by the rust cracked for a while...
I remade the joint (a little long I will trim it to adjust toe in.
it attaches to a sorry looking OEM clamp. (loose for now on pupose)
Now my QUESTION:
I am thinking of ditching the clamp and making a mounting plate which would go under the engine mount bolts.
proposed mock up
The right bend would wind up about on a 45 degree angle, the engine bolts are 7mm. plate would be a about that thick and maybe have a welded on rib.
Will this be strong enough?
have I sacrificed too much fore and aft strength? (the bent bars used to oppose each other)
Just wrong and the world will end?
Cheers John
john82q is offline   Reply With Quote
Old 02-19-2014, 08:05 AM   #2
jaydmc
Oddometer: 1,077
Do the bolts where you are attaching this go through to the other side of the tube making it a nut and bolt set up? If it does one easy way to make it much stronger would be to use longer bolts and put plates on both sides of the tube.
The type of frame clamps you have I have seen them cause failures in the frame of the bike right next to the clamp. I would at least loosen them so that you can move them a bit and inspect for any frame issues.
Where the weld broke, if a weld bead had been laid down 90 degree's from the main weld to break up the line of stress it may not have failed.
Hard to really see in the pictures just what you are trying to do. All 4 mounts should be thought of as a unit not 4 individual mounts. More part of a mounting system.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jaydmc is offline   Reply With Quote
Old 02-19-2014, 04:35 PM   #3
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,234
John. if it would be possible, I would atleast run a strap behind head pipes to matching plate attached to the other motor mount also.
In the stable now. '76 Moto Guzzi Convert Hack
'93 Moto Guzzi Calli 3 with Leaner turned rigid
'99 WR400F
Hack build: http://www.advrider.com/forums/showt...rt+floor+build
cleatusj is offline   Reply With Quote
Old 02-20-2014, 07:22 AM   #4
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,527
A good start for a bad future.
Rust in your SC's future ?
One way how it may have started is when a weld is not finished.
It may appear as only a tiny pin hole & the paint or powder coating didn't seal the hole.
This will permit water inside.
Sometimes an entire metal tube will fill w/ water & then sit there & rust away over time.
This is why welding should not be an ''on the job training program'' on anyones sidecar.
Welding is more than just holding two or more more metal parts in place.
It should be considered a seal.
Wolfgang55 is offline   Reply With Quote
Times are GMT -7.   It's 10:22 PM.
