Old 04-04-2014, 06:14 AM   #31
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,707
Originally Posted by jfman View Post
hmmm.. "small dent on edge".
that's all it takes if it unseats der bead. been there.
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 04-04-2014, 06:45 AM   #32
jdrocks
Gravel Runner
Oddometer: 4,323
Sometimes you get lucky
before you source rotors, find a machinist. the DL650 wheel needs some work for use on the Versys, while the DL1000 wheel does not.
jdrocks is offline   Reply With Quote
Old 04-04-2014, 11:12 AM   #33
jfman
jfman's Avatar
Oddometer: 1,271
I already have access to a good machinist.
BTW: Either dl1000/dl650 do not work anyway with the versys 1000 wich runs a 25mm front axle.
Gotta source bearings, spacers and and a way to mate the ABS plate on there.
Have access to great wheel shop that is cheap but I may leave it as is depending on how bad it is.
jfman is online now   Reply With Quote
Old 06-21-2014, 04:47 AM   #34
bmacneil2008 OP
Oddometer: 81
What is the width of the front wheel you picked? And what tire are you running on the bike now?
Shinko AV tires. Same width in back but down to a 3.5" up front I think. Woody's wanted me to go narrower but so glad I did not. I am 90/10 street/dirt.
bmacneil2008 is offline   Reply With Quote
Old 07-20-2014, 12:13 PM   #35
Crashit
GO HARD OR NOT AT ALL
Crashit's Avatar
Oddometer: 515
You can get a tkc 80 can you not? What's the point of bigger rims?
2008 KLR--AR--K.I.A.
2008 KAWI VERSYS--CO,AR,MO,TN,OK,TX
2007 YZ450F--AR--lost
Crashit is offline   Reply With Quote
Old 07-20-2014, 12:14 PM   #36
Crashit
Crashit's Avatar
Oddometer: 515
Anybody wanna sell there stock front rims? I'll buy both if I have to.
Old 07-20-2014, 03:28 PM   #37
bmacneil2008 OP
Oddometer: 81
You had/have a KLR and a VS, think you could answer your own question, yes?
Old 07-20-2014, 06:54 PM   #38
jdrocks
Gravel Runner
Oddometer: 4,323
...I wouldn't ask a question I had the answer to.
the 19" wheel with tire is very close to the same diameter of a 21" wheel with tire.
since you have owned at least 2 bikes with 21" wheels, and are familiar with that setup, it's not a stretch for the OP to assume that you should know the advantages of a 19" wheel on the front of the Versys, irrespective of tire choice.
you're making a big deal outta nuthin'.
as for a 17" TKC on the OEM Versys wheel, many Versys riders have mounted this tire once it became available in the OEM tire size.
Old 07-20-2014, 07:46 PM   #39
Crashit
Crashit's Avatar
Oddometer: 515
I'm not trying to make a big deal. But if I could answer my own question I wouldn't have one. Thank you for the response. May be I'm just stupid in the subject. But I still don't understand what the advantages are from putting a larger diameter wheel on a 450 pound bike dry. I've had a dirt bike from the age of 4 I'm 28 now. I get a bike and I learn to ride it the way the big guy designed it. I received the first versys in Arkansas. Sure it has its sort comings but all around its a pretty awesome bike. What I was trying to simply ask was what advantages are there from having a bigger tire. I taller tire/rim would have a smaller foot print over the stock tire which is much wider so what is the advantage. wider tire equals more contact so more traction right? Like I said I get a bike and learn to ride it l, if I feel it doesn't meet my ability I get rid of it. That's why I saw the klr engine failure as such a blessing in disguise, hated the bike to underpowered fairings are like wings on the freeway. Loved the 07 and below. I've seen somewhere that a larger tire takes a bigger rolling area to complete one revolution but how does that translate into a better set up?
Crashit screwed with this post 07-21-2014 at 11:14 AM
Old 07-20-2014, 11:49 PM   #40
Crashit
Crashit's Avatar
Oddometer: 515
Handling off road is different than highway. A street bike generally has 17/17" rims and they corner great and stick great. The best handling though is NOT a fat front, ride a TW 200 Yami and see. The fast street bikes run a reasonably narrow front tire. Not exactly sure of the physics of it all but they roll into a turn better and have less flex in the sidewalls than a fat tire does. A fat tire like what you see on Harleys and the like are usually 15" or so and they are mushy handling and sloppy feeling.
A tire like that in the dirt does not track well at all and gets very little feel and feed back. I have done it many times and it is not impossible, but not that fun either.
A comprimise is a 19"/17" frt/rr combo like many ADVenture bikes run like on a Super Tenere or BMW Gs/GSA. The fat front on those still limit TRUE off road ability IMHO, but they are better than the smaller diameter on a sportier or tourer style bike.
As for the 21" front wheel you can not get any better in the DIRT but less traction and control on the pavement. The front 21" inch in soft sand works more like a rudder on a ship, It does dig in a bit to sand but it manuvers through the sand much easier that a 19" or smaller wheel does. It dopes still wander in soft sand but goes where it is pointed overal whereas a 19 or smaller with a fatter tire also digs in to soft sand but it PLOWS the sand and if it catches any edge under the sand it just hooks and burys in and you corkscrew in.
I have owned and DO own many bikes, If I was 100% pavement or hard pack dirt I would not hesitate to run a supermoto style 17" set like a Ducati Multi Strada. If I am 80/20% highway with some gravel & dirt mix then I am 19" frt, 17 or 18" rear. If I am any soft sand or rocky dirt with 65/35% or greater tar to dirt ratio it is 21" front and 17-19" rear, period.
So the key is picking the right bike for your riding style and places and use it. In a perfect world we could all have many bikes and choose what we were doing today and use that weapon.
I hope that helped a little. Your premise is not without merit, but until you get into REALLY fat tire like a quad or 3 Wheeler style tire it will not track on top off sand, like a Honda Fat Cat, but then you have NO street useability for all intensit purposes. It is ALL a comprimise of some sort,
This was the reply I was looking for or explanation. Totally understand. But would have to say it seems by buying a bike designed for one type of riding and trying to change it to suit another is pointless. I personally would love to get my hands on a 950/990. But by doing all that to a Versys IMO you take away from its ride ability. I like to be able to tear up the streets but I can still carry a decent pace off road. If you want to do some rougher off roak get a different bike....guess I answered my own question. Just my two cents. Me and the versys haven't meet a double track or forestry road I couldn't carry a dent pace on. If I had 2grand to blow I'd buy another dirt bike. I was talked into the new Metzler tourance next...this tire is absolutely worthless on anything not payment. I was burning through the avon in about 1000-1500 miles so I got to talking with my local dealer and they recommended the next said it had the same ability etc. I escort funerals full throttle...full brake...repeat repeat every weekend. So naturally I tend to wear a tire out faster than most. Next question would a larger tire increase or decrease braking force over stock. A avon is roughly 200 so I thought I could find a used rim to mount a tkc on for about the same price if anybody who has done the mod would like to sell theirs.
Side note the next is an amazing tire for on the street wet and dry conditions. Avon distanza leads it by far off road. Typically I can ride 50+ on a nice forest road except this weekend every time I got close I was everywhere. Still managed but wasn't as smooth as past experiences. Ive always had to compromise on tires because I ride my bike for hire so any help on a second rim would be awesome.
Crashit screwed with this post 07-21-2014 at 11:19 AM
Times are GMT -7.   It's 11:04 AM.
