Old 02-24-2014, 07:46 PM   #16
FR700
Heckler™©®
FR700's Avatar
Oddometer: 8,062
Originally Posted by johnwesley View Post
surely not worse than the 1st 3 pics. now the last 3 are not anywhere close to as bad as my pops drive and he has a creek crossing too. He drives his road glide up the drive as well as the 100 anniversary harley sidecar.
Everything comes back to what you are comfortable with ... or regard as , 'normal'.
I wouldn't think twice about riding a harley through that, chair or no chair.
here is the most technical terrain I remember on the TAT most go around this section.
You're used to rock crawling so you know it's about, pick your line and know the rigs limits.
This will not change just because it is a sidecar.
that really is a good question. If I had experience then there would be no need for the question.
Maybe a easier question to swallow would be If I have a sidecar with 4" of travel should I stick with a tug that also was short on travel sat in the 4-6" range because they would work better as a unit? same question different twist.
Current build has 2 1/2 on the chair ... on a rising rate geometry ( which also includes a manual ride height adjuster ) and I run a coil over designed for a car.
If I was going to run the Baja at 100 + mph, I'd go with a tad more travel ... and a different bike
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 02-24-2014, 08:02 PM   #17
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
thanks for the insight that clicks in my head. It's always about the line and the ability to see it. I use to teach off-road riding before my current Job and the line is import there its just easier to find. Of course the track schools also worked on the lines and how they changed based on traffic and over taking.
Yea good thoughts, a nice boost of confidence that I am going the right direction.
DaveBig: I am talking with Claude and he is working out some options, just airing out thoughts here without blowing up someones phone
I'm pretty sure I'll click with the rig I mean it has a motor whats not to like
the tiger is more "normal" with the suspension travel so it may be a better tug. the sporty is a little bit more out there
johnwesley is offline   Reply With Quote
Old 02-24-2014, 08:04 PM   #18
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,222
John, I have very little travel on the front and sidecar and I run what you showed as normal TAT roads at 60-80 mph but a lot of these are not as well groomed. I do have to check bolts for tightness after every 100-200 mile day.
The old body.
The new body.
In the stable now. '76 Moto Guzzi Convert Hack
'93 Moto Guzzi Calli 3 with Leaner turned rigid
'99 WR400F
Hack build: http://www.advrider.com/forums/showt...rt+floor+build
cleatusj is offline   Reply With Quote
Old 02-24-2014, 08:34 PM   #19
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
yea, but you have a Guzzi. Thats like saying sure you can do it, I saw superman do it once
I love the goose. I sold my last one and have regretted it ever since. It was a SPIII
what is that in the left side of the pic? a T3 maybe with LL
Old 02-24-2014, 08:46 PM   #20
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,222
'76 Convert. The build thread link is in my sig. at the bottom.
'99 WR400F
Old 02-25-2014, 03:36 AM   #21
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,351
Most of the longer travel dualsport rigs (GSA) seem to benefit from having a sway bar. I perceive this as balancing the effect of longer travel bike suspension vs the shorter sidecar suspension.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 02-25-2014, 08:23 AM   #22
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,339
how much travel does the sidecar have?
being a newbie what is the diff between a hack and a car?
I haven't measured exactly how much wheel travel my side car has, but the shock has 5" of stroke. The bike has the stock travel front and rear, just sprung (and valved) different for the added weight.
To me a side car is something the passenger sits inside of like my rig:
The side hack is basically a platform that the passenger (aka "Monkey") mostly stands on and has plenty of room to move around and transfer their weight to help stabilize the the rig (like the trials bikes in the vid) or here:
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 02-25-2014, 08:33 AM   #23
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
With those thoughts I'm looking at a car
Old 02-25-2014, 10:16 AM   #24
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,025
One thing that limits where you go in the backcountry on a sidecar is considering what's gonna happen if you get to a point where you can't go any farther and have to turn round and come back.
In this pic here, I'd gladly ride WUMPA from the background to the foreground, but I don't have the chops to ride from the foreground to the background no matter what line I picked. Maybe I could walk it through there, but it would be a trick. Part of that is because of the terrain, part because of the rig's limitations, and part because I'm old and fat and can't do half the stuff I was able to do 15 years ago.
There were several times in my travels over the past three years where I've gotten to a place and turned around even though I knew I could get through. I turned around because I didn't know if I could get back if I had to. Now, if I had a active monkee with me (not a "passenger" who just sits there), the whole formula changes. With a monkee I can go places I'd never try solo.
WUMPA
Sidecardogs.com
DRONE is online now   Reply With Quote
Old 02-25-2014, 10:35 AM   #25
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,654
I can see where having a monkey to help push isn't such a bad idea
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 02-25-2014, 10:38 AM   #26
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,025
The thing about long travel is, sure, it's great to help you crawl through the rough stuff, but that high center of gravity is a limitation for general use on smooth roads. And, of course, the high ride makes off camber situations more dicey.
What I'd really like to see is something like this for a sidecar rig--
WUMPA
Sidecardogs.com
Old 02-25-2014, 10:41 AM   #27
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,025
But seriously, I was thinking more about hanging out, or standing on the passenger step if you got one.
WUMPA
Sidecardogs.com
Old 02-25-2014, 10:42 AM   #28
Dan Alexander
Oddometer: 7,654
I was wondering this before, would a Goldwing type air shock and compressor be good for the sidecar to raise and lower it? They are on ebay pretty cheap. Maybe even one on the rear of the bike? Would that do what the Jeep is doing in a limited way.
Old 02-25-2014, 10:43 AM   #29
Dan Alexander
Oddometer: 7,654
I'll see if I can find a pic of a cute one doing just that. This Walter Mitty lives large
Old 02-25-2014, 11:33 AM   #30
johnwesley OP
wanta be
johnwesley's Avatar
Oddometer: 1,634
Never really had to worry about HCG on a solo and on the crawler I just made the track wider and put on adjustable sway bars. I have seen sidecars for adv anywhere from 7"-14" if just graded gravel low and fast is the way to go.
It may just be a pipe dream to have a decent exploration off-road rig and expect it to drive 1,500 on the road heading home.
Times are GMT -7.   It's 03:06 PM.
