Go Back   ADVrider > Riding > Trip Planning
Old 03-03-2014, 02:34 PM   #1
zigyphoto OP
Pay attention
Oddometer: 914
Gps maps for iceland?
Riding in Iceland end May-mid June.
Planning on taking my ZUMO 550 and have some questions:
What maps include Iceland? I note the "global map" shows it, but there are no ways to create a new route.
Would it be just as easy to use my iPhone 4s in a waterproof case?
Does anyone have an Iceland digital map file I could borrow or rent?
All suggestions about this appreciated.
thanks
z
zigyphoto is offline   Reply With Quote
Old 03-04-2014, 12:18 AM   #2
Jamie Z
Jamie Z's Avatar
Oddometer: 7,796
Open Street Maps.
http://garmin.openstreetmap.nl/
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is online now   Reply With Quote
Old 03-04-2014, 12:38 PM   #3
zigyphoto OP
Pay attention
Oddometer: 914
Originally Posted by Jamie Z View Post
Jamie,
thanks. I downloaded the file, but am confused about the contents. The one that seems to be the operational one -- since I already have MapSource on my computer is:
[ ] osm_generic_gmapsupp.zip 27-Feb-2014 04:07 9.3M Compressed file that contains a single image that can be placed directly onto the SD-card of the GPS.
when I attempt to run it after unzipping it, it tells me to burn to a disk; is that the only way to use it?
thanks,
z
Old 03-04-2014, 07:39 PM   #4
Jamie Z
Jamie Z's Avatar
Oddometer: 7,796
thanks,
z
I haven't used OSM with a Zumo, so you'll have to forgive me, what I believe you need to do is unzip the zip file, and there should be an .IMG file in there (if you don't have extensions turned on, you probably won't know if it's an .IMG file or not). Just copy that .IMG file onto the SD card in your Zumo.
When you turn on your Zumo, you might have to go into some map settings or something to turn the map on, or maybe it'll work right away, I'm not sure.
Another option is to download the .EXE file, run it, and then run Mapsource or Basecamp, whichever you use, and transfer the map to your Zumo.
I've only used OSM a couple of times, so I'm still learning too, but from what I've seen so far, it's good maps.
Jamie
Old 03-04-2014, 08:38 PM   #5
zigyphoto OP
Pay attention
Oddometer: 914
I haven't used OSM with a Zumo, so you'll have to forgive me, what I believe you need to do is...
jamie,
thanks for that; appreciate your time on this. will check it out. was concerned that since I already have Mapsource, it might derange my current version.
anyone else have any input on this issue?
thanks
z
Old 03-05-2014, 11:22 AM   #6
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,817
open it into mapsource, it will not mess anything up, you will just have a choice in the map drop down in the upper L corner.
PFFOG is online now   Reply With Quote
Old 03-06-2014, 08:07 AM   #7
icelandmg066
Oddometer: 33
hope you have a nice time here but dont forget the westfjords and the kjolvegur the kjolvegur is a highland road going from north to south i think it would be a good ride....iceland
icelandmg066 is offline   Reply With Quote
Times are GMT -7.   It's 01:01 PM.
