Old 03-05-2014, 12:36 PM   #1
OneEffinName OP
Oddometer: 468
TLR200 Reflex Front End
I am rebuilding a very tired TLR200 into a twin shock trials competition bike. Just for the halibut.
I am wondering about the front forks. They are weak and crappy. I know there is no revalve kit for it and no upgrade other than new forks. If I got different front forks that were disc brake - would it still be allowed to compete in twin shock classes? In our local club there is only a handful of vintage bikes, and I dont think anyone would care. But it would be nice to take the bike to the states every once in a while and have a little fun competing.
OK, so if disc brake is out - what kind of upgrade options for the (non-mighty) Reflex are there?
thanks
Check out Don's Adventure Rides https://donsadventurerides.wordpress.com
KTM 350 EXCF - KTM Freeride 250 - GasGas Raga 250
OneEffinName is offline   Reply With Quote
Old 03-05-2014, 08:53 PM   #2
lineaway
Oddometer: 3,089
The brakes on the reflex are great for a twin shock. just the rest of the bike sucks. And no you could not compete as a twin shock.
http://advrider.com/forums/showthread.php?t=562129
lineaway is offline   Reply With Quote
Old 03-05-2014, 10:18 PM   #3
OneEffinName OP
Oddometer: 468
I'm not looking to upgrade the brakes - its the forks I want to upgrade.
Old 03-06-2014, 01:17 AM   #4
Thats_a_Five
Oddometer: 56
Common upgrades:
1) Pegs lowered and moved back
2) Change jetting to reduce lean running
3) Advance cam timing
4) Cut and weld frame to steepen steering head angle
5) Battery eliminator
6) remove lights, gauges, extra wiring
Thats_a_Five is offline   Reply With Quote
Old 03-06-2014, 04:51 AM   #5
lineaway
Oddometer: 3,089
This one belongs to one of the members of Mountain West Vintage Trials. It has a complete TY350 front end.
Old 03-06-2014, 05:21 AM   #6
lineaway
Oddometer: 3,089
Another option, would be the 1995/96 Fantic section front forks were great. There were many of these bikes floating around as parts bikes if you come across one. Seems like I saw a write up somewhere about this mod.
Old 03-06-2014, 08:41 AM   #7
OneEffinName OP
Oddometer: 468
Thanks lineaway I will check into the TY and Fantic forks.
Old 03-06-2014, 10:23 PM   #8
UtahGuido
UtahGuido's Avatar
Oddometer: 5,005
I changed the oil in my forks and I think they are fine, but I'm not much of a conoisuer. Maybe check the springs while you are in there and see if they are within spec, i.e. haven't shortened up.
BTW, I did a little comparo with my Scorpa 125 and the TLR today in the driveway and I've got to say I like that TLR. It's a fun little tank.
As you get older get a slower dog.
UtahGuido is offline   Reply With Quote
Old 04-03-2014, 04:31 PM   #9
SammyD
Oddometer: 27
Spoke to the nice chap at B&J Racing today and he said that putting some air in the forks to add a little compression damping could be an option. I ride down a lot of ledges and need some more bottoming resistance.
Interestingly he did say that the stock spring rate front and rear should be ballpark for my 180lb weight. I may have to tackle that almost 30 yr old oil in the forks though.
SammyD is offline   Reply With Quote
Old 04-03-2014, 06:56 PM   #10
lineaway
Oddometer: 3,089
You don`t need air. Air is ment to be released not added too the forks. The forks can work fine. The problem is the axle is about the size of the old xr75. (actually the whole problem is it was not supposed to be competed on.)
Old 04-03-2014, 08:09 PM   #11
ridenfly
Oddometer: 113
It interesting that the trick item now is to add valving to release air buildup in the forks. Back in the day the trick was to install Schrader valves and add air to the forks. I just trimmed down an 87sp200 for single track and installed schraders just for that vintage advantage.
A proud member of the Patrol Patrol
2003 Ural Patrol "Goslovna"
1987 SP200
ridenfly is offline   Reply With Quote
Old 04-04-2014, 05:19 AM   #12
lineaway
Oddometer: 3,089
Back in the day we used atf or more atf and air. Nowadays we spend 15 bucks for a pint of `trick` suspension oil. I think the advertisers won.
Old 04-05-2014, 09:32 PM   #13
chuck4788
Oddometer: 7
Get a XR200R front end, best IMO is 84-91, about 10" of travel and an aluminum rim.
chuck4788 is offline   Reply With Quote
Old 04-06-2014, 06:31 PM   #14
neilking
Oddometer: 434
I found that mine works pretty good with 4 psi in each leg. I'm about 185 lb.
74 TY 80, 175 and 250 no longer at Brewtus's house
86 TLR200
95 Sportster 1200
13 Factory Beta 250
neilking is online now   Reply With Quote
Old 04-07-2014, 09:11 AM   #15
SammyD
Oddometer: 27
Thank you so much for posting! Looking forward to giving this a try.
Times are GMT -7.   It's 04:00 PM.
