Old 03-21-2014, 04:29 AM   #1
FredRydr OP
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
Basecamp - using trackpad in MacBook
I have Basecamp installed in my Macbook Pro. About 20% of the time, when I use my trackpad to move the map, the map spins instead of moving in the intended direction, so that north is no longer up.
If there is a preference to turn this feature off, I cannot find it. Can anyone share a remedy?
TIA
Fred
FredRydr is offline   Reply With Quote
Old 03-21-2014, 08:52 AM   #2
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,471
There is no setting to turn off the map controls. To avoid the condition you describe, only touch the trackpad with one finger at a time.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 03-22-2014, 03:17 PM   #3
Critic
More or less!
Critic's Avatar
Oddometer: 1,248
Use the left side of the pad!
It is always something! Rosann Rosanadana!
Moto's: 300xcw,500exc,990Baja
past:BigBear250,T100cs,Savage250s,TS185,DT175,GT550,TY250,XR200/350/250,R75/7,Ft500,RD350,YZ125,KDX175,SP500,K1000rs,DR250,883,S1,ST2,KLX650,KE100,GS1000,Monster,Vstr om1000&650,950adv,625sxc,250SSherpa,530exc,990adv, 690e
Critic is offline   Reply With Quote
Old 03-22-2014, 03:45 PM   #4
FredRydr OP
FredRydr's Avatar
Oddometer: 2,460
Thanks, guys. I shall take more care when stroking my pad.
Fred
Old 03-23-2014, 10:15 AM   #5
Critic
More or less!
Critic's Avatar
Oddometer: 1,248
Actually, unless you want to turn the map, just stay out of the lower right corner of the pad.
Old 03-28-2014, 03:45 PM   #6
FredRydr OP
FredRydr's Avatar
Oddometer: 2,460
Here is Garmin's diagnosis:
What is happening is BaseCamp is confusing a gesture of swiping with 2 fingers for a gesture of rotating one finger around another. Swiping will result in dragging the map, and spinning will rotate the map. There isn't really a way to fix this other than to make sure that when you are dragging with 2 fingers you are doing it in a perfectly straight line and not in a curve which will rotate the map.
Fred
Times are GMT -7.   It's 11:32 AM.
