Old 03-19-2014, 01:32 PM   #1
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 353
BMW 1150GS Clutch Splines spacer kit
Hello everybody.
Some new input on this subject regarding modified clutch hub. This is what I have been playing with for the past month or so.
UPDATE: 1/8/2015. Parts are available
Thank you for your time.
I want to be unique, just like everybody else.
WORN INPUT SPLINES CLUTCH HUB SPACER R1150XX
http://advrider.com/forums/showthread.php?t=964425
cele0001 screwed with this post 01-09-2015 at 07:44 AM
cele0001 is offline   Reply With Quote
Old 03-19-2014, 02:27 PM   #2
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,294
So how thick is your spacer?
tbarstow is offline   Reply With Quote
Old 03-19-2014, 03:58 PM   #3
vagueout
vagueout's Avatar
Oddometer: 1,632
Beautiful work.
i just seek clarity
vagueout is offline   Reply With Quote
Old 03-19-2014, 05:31 PM   #4
j911brick
Squidinator
j911brick's Avatar
Oddometer: 513
Nice simple solution.
_________________
james
Its not how fast you go...Its how you go fast.
R1200GSA; Honda Hawk GT; Honda NSR250 SP Rothmans; Honda RS250 GP; Honda CRF250X; Honda 300 Dream.
http://www.bikepics.com/members/j911brick/
http://www.youtube.com/watch?v=v3CPzKpZYSU
Porsche (several)
http://members.rennlist.com/j911brick/rennlist3_002.htm
j911brick is offline   Reply With Quote
Old 03-19-2014, 09:27 PM   #5
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,636
Put "solution" in quotes for a while.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 03-20-2014, 07:03 AM   #6
liviob
liviob's Avatar
Oddometer: 702
Looks like the Bruno mod sans rivets. Using bolts makes assembly a little easier. Do you plan to sell the spline hubs?
Current road bike 2001 BMW R1150GS
liviob is offline   Reply With Quote
Old 03-20-2014, 01:15 PM   #7
_cy_
Oddometer: 6,030
Originally Posted by cele0001 View Post
Hello everybody.
very nice .. so did you custom CNC above parts?
Old 03-20-2014, 04:22 PM   #8
_cy_
Oddometer: 6,030
pretty slick .. how much?
Old 03-20-2014, 11:03 PM   #9
Ravenslair
Oddometer: 477
Put me in line for one as well. Toss it in the tool box and hope to not need it for quite a while.
Ravenslair is offline   Reply With Quote
Old 03-20-2014, 11:16 PM   #10
sweatmark
Oddometer: 51
Top left is custom machined spacer. The rest are BMW cluch parts (minus the rivets)
This is the next step.
Nicely done!
This, plus your emergency spark plug coil trick, UNI filters (over on the Rockster board)... You do good work.
Oregon USA
Now: 2004 R1150R Rockster, 2007 F800S
Then: R850R, R1100R, R1150R, R1200C, Buell, crotch rockets
sweatmark is offline   Reply With Quote
Old 03-20-2014, 11:35 PM   #11
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 353
Originally Posted by sweatmark View Post
Nicely done!
Thank you . I like to play. But this is an attempt to provide the parts needed to modify the existing clutch to become "Bruno" clutch. The idea is the same. I am still testing mine in the bike. It is riveted now. UNI filters are the mod to make removing the transmission easier. It is out in 30 minutes and back in in 45.
The spacer has been designed for BMW clutch. I did not play with Siebenrock clutch.
I want to make sure that the average guy can perform this mod using basic tools. Dremmel or grinder, punch, hammer. Hydraulic press would be nice for the rivets but we will see. I don't want to go into discussion about causes of stripped splines, it has been talked about ad nauseam. My real test would be to get somebody with stripped splines to install modified clutch and nothing else, no additional parts.
I believe that the bike would have long happy life. Either way it is not ready yet.
If there is enough interest I will run 10 parts. Right now I am hovering at about $100 for the kit but nothing finalized yet.
Old 03-21-2014, 12:32 AM   #12
madjimbo
Hertz, Donut?
madjimbo's Avatar
Oddometer: 1,248
Definitely interested!
2001 R1150GS-P!
madjimbo is offline   Reply With Quote
Old 03-21-2014, 04:04 AM   #13
_cy_
Oddometer: 6,030
so you think your spacer would work without changing out stripped splines?
spacer would allow undamaged splines to mate up with new clutch disc. giving back aprox 1/3 to 1/2 of original spline length
_cy_ screwed with this post 03-21-2014 at 04:21 AM
Old 03-21-2014, 04:16 AM   #14
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 353
so you think your spacer would work without changing out stripped splines???
6 speed has 19 mm of spline length available. It does not use 6 mm, so only 13mm are actually carrying the load. Thank you GSAddic for the info. If you look at the worn shaft, (and you dont have to look far),
(EDIT: ONe just popped up above this post.)
there is about 4mm that is only partially worn. And you are gaining the second point on contact on the front of the shaft to stabilize the clutch plate further. Both of these areas are "virgin" more or less. So I think that this middle portion would be safely bypassed. Speculation at this point so an official tester would be nice.
Old 03-21-2014, 06:00 AM   #15
liviob
liviob's Avatar
Oddometer: 702
A spacer for the Siebenrock clutch disk would need to be made thicker than for the OEM BMW clutch disk as it's hub is approximately .125" shorter.
Times are GMT -7.   It's 11:32 AM.
