03-30-2013, 06:29 AM
#1 |
former redriderofma
Oddometer: 1,010
More R60/5 questions
Ok Here is a silly one.
I'm putting new grips on my 1972 R60/5. The foam ones are falling apart. I got the Magura part number 3272 1230 868 for the right throttle side. How do you get in on over the throttle ? Lube it with soap , heat it ?
Unless we change direction, we are likely to end up where we are headed. It's county Fair time in New England |
03-30-2013, 08:21 AM
#2 |
Confirmed Curmudgeon
Oddometer: 3,869
Get some Grip Glue. It'll let the grips slide on then dr y and lock the grips on.
--Bill
'73 R60/5 Toaster |
03-30-2013, 08:25 AM
#3 |
Oddometer: 1,025
If you have an aircompressor you can float them into place.
Get the grip started on the end, take the airnozzle and place the tip between the grip and the bar and blow. The air will get between the grip and the bar and the grip will slide into place as you push it in. |
