10-11-2005, 08:55 PM
#16 | |
EuroMotoElectrics
Oddometer: 12
10-12-2005, 08:10 AM
#17 |
Oddometer: 174
Ha! John, you saved me getting out the kitchen scales!
I guess then if it's lighter, and if the 400w upgrade has no reliability issues assosciated with the heavier rotor, then your system should have no issues due to mass. thx for clarifying. |
10-12-2005, 04:48 PM
#18 | |
Traveller
Oddometer: 6,593
I hope you have sized your rectifier/regulator components better than the jap bike makers - they suffer reliablity problems with them - mainly SCR hot spot shorts if I understand correctly.
Regards Frank Warner motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S http://www.geocities.com/fwarner_au/ |
10-12-2005, 04:55 PM
#19 | |
XLV750R
Honda does seem to be doing their utmost to destroy their reputation for reliability by tucking their regulators in the most unlikely places ... the older bikes always used to have them out in the breeze, and never suffered this problem. VFR owners who've improved their heatsinks don't seem to have the problem any more, either. http://www.geocities.com/MotorCity/S.../reg-rect.html I reckon Honda are just jealous of BMW's fine work in mounting semiconductors _inside_ the engine casing :-). -----sharks sharkey screwed with this post 10-12-2005 at 05:03 PM |
10-12-2005, 05:34 PM
#20 | |
Traveller
Oddometer: 6,593
Keeps their friends at HPN in business. They cut the al off the top of the motor and mount the electrics around the starter motor. MotoGuzzie have the same alternator - they put their electrics out of the motor (including the diode board). And with the heavier guzzie flywheel don't have the rotor failure rate of airheads (the 'newer' ones with the light flywheel - about 1975 on I think?).
10-12-2005, 05:41 PM
#21 | |
XLV750R
Of course, there's not much point unless you're planning on replacing the frame ... -----sharks |
10-12-2005, 06:06 PM
#22 | |
Traveller
Oddometer: 6,593
Oilheads is a differnet matter. You need to vist Paul Rooney - next time yer up Grafton way. Seeing things in the fleash is so much better. Was there two weeks ago - one R65GS (light weight and low), a R100 with oilhead rear end, and two others ... all being built up for customers. Maybe the next Horizons Unlimited meeting? Oct next year. |
10-14-2005, 07:00 AM
#23 | |
EuroMotoElectrics
Oddometer: 12
The Stator / Rotor / SCR Rectifier are all sourced as a matched set from the Original Equipment Manufacturer ; mounting the Volt Reg / Rectifier close to the stator and in airstream should provide reliable voltage and long term life. JR Thx for the opportunity to clarify ! |
10-14-2005, 05:52 PM
#24 | |
Still a stupid tire guy
Oddometer: 7,272
Try HPN's web site. There's a menu on the left with a photo gallery that includes some gorgeous high-res photos. Makes me feel all dizzy (in a good sort of way) every time I look at them.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." - Abraham Lincoln |
10-14-2005, 11:33 PM
#25 | |
XLV750R
-----sharks |
11-02-2005, 09:59 PM
#26 |
De Jo Momma
Oddometer: 8,705
And now for the opposing view
Okay, not trying to stir the pot here, just trying to point out the differences between the Omega and EnduraLast kits. I for one prefer the design of the Omega and this is why:
Greg |
11-02-2005, 11:15 PM
#27 | |
XLV750R
-----sharks |
11-03-2005, 06:59 AM
#28 | |
De Jo Momma
Oddometer: 8,705
I was just trying to point out that like everything, there is no clear winner. It just depends on how you intend to use it as to which design comes out on top. The EnduraLast has its place. Forums like this tend to exagerate claims and this was starting to look like "hey, everybody should dump their alternators--even if they're Omegas and go get this new system...it's how BMW should have done it in the first place." Unfortunately, every failure that I've had of this 'type' of system has been regulator AND stator. My guess is the electronics fail first (to ground) which overheats the stator and 'blam' they're both toast. My 86 Goldwing (500 watts) blew the charging system every 60K, like clockwork (three of them). After number one, I moved the regulator out to fresh air. It did nothing for the longevity. My friend's 95 Honda Shadow did exactly the same thing (50K). Thanks for keeping me honest though
Greg |
11-03-2005, 08:57 AM
#29 |
Oddometer: 174
Hi Greg, glad to see the Omega arrived. To clarify from a personal perspective .... I think both are great systems, but my needs are for three identical systems, minimum spare parts and maximujm reliability on a long trek. I wouldn't encourage anyone to swap under more normal circumstances.
Reliability can only be measured over time, but as the components are the same electrically as fitted to Ducati's I'm assuming the wrinkles have been ironed out. I work on the basis of less parts means less points of potential failure. I will be taking one spare reg/rect unit on my trek (for three bikes) and I'm sure that if I needed a second faster than I could get a replacement sent I could most likely jury-rig something up locally (note to self...identify South American bikes with this type of set-up). My understanding re. the output is that is engine speed dependant, and it's about 200watts at about 1500rpm raising up to 450W at 6k rpm (working from memory). After all, what we all need is more power low down, 400w vs 450w is academic for me. |
11-03-2005, 11:47 AM
#30 | |
XLV750R
I've been riding Japanese bikes with permanent-magnet electrics for quite a few years now, and never had any problems. There are some troublesome models, though. I reckon at a pinch you could use two of the three phases of a UJM rec/reg with the EnDuraLast stator, if you had to. -----sharks |
