Old 11-03-2005, 03:34 PM   #31
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
Originally Posted by GregCifu
I still believe its a less reliable design. The Thyristors are having to deal with switching the full output of the system rather than a 'normal' regulator simply controlling a field coil.
Thyristors are designed to switch large currents. I've seen some very large ones. They are used to controll lifts! Mean Time between Falure calculations are used to estimate reliablity in the design stage.
The problem is the design is not for reliablity alone, but for cost, asthetics and marketing. Oh and profit.
Frank Warner screwed with this post 11-03-2005 at 03:59 PM
Frank Warner is offline   Reply With Quote
Old 11-05-2005, 02:56 PM   #32
SmutMug
Oddometer: 40
I installed my system this week and played around. Here as some pics and a write-up. I asked and obtained permission from bcostell to use some of his pics.
Nov 4, 2005
I just returned from a test ride with my R80RT after installing an Enduralast 450 Watt system from http://www.euromotoelectrics.com/enduralast.html
The bottom line is that from about 1200-1300 rpm onwards, the system puts out 14.1 to 14.2 volts. At idle, it’s between 12.4 and 12.6 volts. I installed a Datel volt meter to give me a constant read-out during riding. I puttered through town this evening and briefly hopped on the freeway. At all points the voltage was constant between 14 and 14.2. Yesterday, after ensuring I had rigged everything up correctly, I wired up an electric vest and a 70 Watt power inverter to the battery. Flicking the high beam on and off at idle makes the voltage blip, but it returns a steady number after a second or so. Since the inverter and jacket didn’t seem to make a difference in the voltage readout yesterday, I did not wire them up for the test ride.
The kit contains a rotor (solid magnet) and stator, a mounting bracket, a rectifier and a bewildering array of little wires and connectors, of which you end up using a fraction. There’s even a rotor puller bolt included.
The installation is relatively straightforward, but you do need to read the manual carefully. The wiring diagram is a no-brainer. Since I am going to move this system to my G/S in a few months, I did not bother removing any of the original wiring. Since none of it is needed in the meantime, I taped up all the ends and left them where they were.
Installation:
First job is to remove the original stator, rotor, diode board and voltage regulator. I left the voltage regulator in place courtesy of two spun screws.
Mounting the rotor is the same procedure as a regular one. Since we’re dealing with a solid magnet rotor, you want to make sure your wallet and credit cards are not in the vicinity. I wondered about the Hall sensor with this thing nearby, but a timing light check confirmed nothing had changed.
The stator is mounted between two aluminum brackets and screwed into place with 3 screws in the same location as the original. No brushes here … this is a “contact-less” system. As with the original stator, you need to slowly easy it into place and tighten the screws in turn. There is one big wire going up and out of the front cover cavity, that’s it. The only other wire under the front cover after the install is the wire to the timing can (for post-81 machines). Lots of space to mount a small box with tools where the diode board was… hmm.
I ended up mounting the rectifier to a frame tube and ran a car-size ground wire to the battery negative. This was pure laziness on my part, as others have installed this rectifier under the tank after removing the voltage regulator. It fits in that space.
The wiring is simple: The voltage regulator plug ground and blue wire are used (with spade connectors), a wire (with provided 30 amp fuse) to battery positive. Two plugs connect the rectifier to the stator, one wire connects to a switched positive. For the latter you need to bare a (small) wire that gets “hot” when the ignition is on and splice one in. That’s about it.
I spent most of my time trying to figure out where I wanted to mount the rectifier … the RT has less space than other configurations and I could not remove the voltage regulator. In hindsight, I preferred it that way.
During riding I noticed not much difference, except that my stock voltage regulator was reading much higher than before. It’s nice to know that even when you’re loitering through town you’re not draining the battery. I was somewhat concerned that given the strength of the magnet, there would be more drag on the motor and hence I’d have to adjust idle (more fuel consumption…) but that proved to be unfounded. As well, the rotor weighs less than the stock one. I touched the rectifier at the end of the ride to see if it had heated up, but it was cold.
I’m going to eye-ball this setup for a while and decide whether I want to move this over to the G/S. This whole thing started when I contacted John Rayski (Euromoto Electrics) and quizzed him on whether he wanted to have a “guinea pig” for his new system. He was happy to provide me a system, gratis, for which my thanks. Next April, I’m off for a LONG trip across Europe to China and beyond. In order to eliminate the need for carrying an extra rotor and diode board, as well have better charging, I want to take this setup. Since it’s on the RT, I’ll put ample mileage on it between now and then to provide me with enough comfort to put it on the G/S.
Pictures of the rectifier mounting:
Pictures of another install (used with permission):
Comparison of 3 rotors: The middle one is the Enduralast one. The others are stock and the rotor used by Motorrad Electric. The Enduralast is the lightest.
GS install:
Rectifier install on the same GS:
Pictures at various speeds:
Note: The digital voltage readout at the left in the pictures below is about 0.2 volts below what I measured at the battery with the same voltage meter. Probably due to some loss as I spliced the volt meter into a switched circuit up front. The high beam is on during the test.
800 rpm
1000 rpm
1100 rpm
1500 rpm
SmutMug is offline   Reply With Quote
Old 11-12-2005, 06:08 PM   #33
matteo
HPM
matteo's Avatar
Oddometer: 499
I got my Enduralast alternator today. Very nice unit. Installing it mechanically was very straightforward. The electrical not so easy. I think that Euromotoelectric would do well to make this simpler. I understand that the different models have different needs, but all situations use the yellow to yellow connection and that still required some work to make the connection.
So first of all, I want to thank bcostell and sharkey for their photos. It helped a lot. But I'm still confused about the white and black connector. Where is the best place to hook them up? The instructions say to connect it to a green/blue wire, but bcostell, I think you say to hook it up to the blue wire. Is this the blue wire to this connector.
This connector is not currently attached to anything. It makes me think that I did something wrong.
Finally, I disconnected a blade from the starter when I was removing the old harness. I think this is engages the starter motor. Is this the same black wire as is on the hanging connector?
I'm pretty sure it was connected to the right side of the diode board, as seen in this picture.
I'm embarrassed to say that I didn't keep a note on where the starter wire came from.
Thanks in advance for all your help.
matteo is offline   Reply With Quote
Old 11-12-2005, 06:22 PM   #34
bcostell
Oddometer: 192
Assuming it's an R100GS....here's my instructions from earlier in this post.....
The following apply to the mini loom you removed that connected to the old voltage regulator, starter motor, etc
Take the removed little loom and carefully cut open the black sheathing.
Remove the big rubber grommet that goes through the top of the timing cover and fit to field winding cable - the two yellow wired cable attached to the field coils. I used WD40 to help slip it off without splitting it.
At old voltage regulator three spade connector - cut light blue wires.
Seperate from the bundle the two spade (blue and black wires) connector with its two wires still attached.
The Black wire should have the single spade that goes to the starter solenoid still attached.
The blue wire that was cut above now needs to be connected to the white wire of the reg/rect unit.
When you come to do the assembly the black wire can be squeezed in to the rear large rubber gromet at the top of the timing chest and reconnected to the starter solenoid.
..............end of mini loom instructions.....
So, in your picture, the black wire from the BMW connector goes to the starter (small spade connector on the starter solenoid), the blue wire from the BMW connector goes to the white on the new reg/rect unit (this is for the dash light). Don't worry about the left over wire, put it away with all of the other bits.
bcostell is offline   Reply With Quote
Old 11-12-2005, 07:24 PM   #35
matteo
HPM
matteo's Avatar
Oddometer: 499
Thanks bcostell, for all the help. The only wire left is the black wire from the new regulator/rectifier. I guess I use the "T" splice into the green/blue wire on the ignition coil.
Overall, I would say I'm happy with the Enduralast product. But from looking at how the wiring is done, I truly believe this is the weak point. In terms of reliability, the system is simpler than the stock and I expect it to be more robust, but I would not be surprised to find over the years that it is the harness that gives the most trouble to most owners.
I'm going to look into upgrading the connectors for the added reliability.
Also, from looking at the maintance papers from the previous owner, it looks like the diode board was replaced about every 20k miles. At least I don't have to deal with that going forward
Old 11-12-2005, 09:29 PM   #36
bcostell
Oddometer: 192
You can splice in at the ignition coil, I felt a more robust connection would be to solder to the major connection that's wound up inside the loom just behind the steering head.....look for the barrel shaped 4 pin waterproof connector on the left hand side of the main tube, just behind the steering head. If you look carefully you'll see a bit of a bulge in the loom...I unwrapped it at that point and revealed multiple green wires crimped together which I then soldered a fresh wire to and then ran the other end to the black on the reg/rect unit.
I agree with your sentiment on the connections....I cut them all off and used more robust connectors, solder and shrink-wrap. I have a spare reg/rect unit pre-wired so that on my trek if one of the bikes has a failure we can do a quick swap to keep us going (and order a new spare!)
Old 11-13-2005, 01:04 AM   #37
sharkey
XLV750R
sharkey's Avatar
Oddometer: 875
Eh?
Originally Posted by sharkey, while drunk
G'day all, i won't say a lot now becausse I'm a little bit psissed tfom a BBQ this safternoon ao I'll noyt say a lot now, but I'll read this agaon this morning and try ad say saomething sensible.''
I ended up unwrapping the loom where it runs along the frame and tapping into one of the blue/green wires, cut, splice, solder, heatshrink, rebundle the loom.
Then I removed the small 'loom' which connects that two-pin connector to the regulator, diode board and starter motor.
Then I removed the spade lugs from the two-pin connector. The black one goes directly to the cunningly hidden terminal on the starter motor (protected by a bit of heatshrink)
The lightblue one and the wire I spliced into the loom go to a two-pin connector which goes to the EnDuraLast regulator.
I don't own the right tools to do a proper job of crimping the wires, and I don't like those squeeze on terminals at all. So I cut, soldered and heatshrinked everything, and it's as robust as anything.
EG: To join the double wire to the fuse holder wire, I removed the 'barrel' from the supplied yellow crimp, threw away the plastic bit, crimped the wires into the metal bit and flooded the whole thing with solder, getting it all hot enough that the solder is drawn up into the tiny spaces between the wires. Then covered it with two layers of heatshrink.
-----sharks
sharkey screwed with this post 11-13-2005 at 01:07 PM Reason: Don't Drink and Post
sharkey is offline   Reply With Quote
Old 11-13-2005, 01:14 PM   #38
sharkey
XLV750R
sharkey's Avatar
Oddometer: 875
Yes. You should have a small bit of wiring left over with a three-pin
connector for the old regulator, a two pin connector which matches that one left dangling, and a couple of other spade connectors which went to the diode board and starter motor.
You just need to connect the black wire in that two-pin connector to terminal 50 of the starter motor, and the lightblue wire to the warning light output of the EnDuraLast generator.
-----sharks
Old 11-14-2005, 08:24 PM   #39
matteo
HPM
matteo's Avatar
Oddometer: 499
Just want to follow up. Thanks for everyone's help. Got the airhead running. Still not too happy with the harness, so will be playing with it some more as I find connectors that I feel with do the job better.
Old 01-25-2006, 08:00 AM   #40
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,420
So ... After a few months of the Enduralast and no noticable problems, I am faced with the ultimate decision. I am leaving April 10 for a round the world trip, lasting a few years and want to take the Enduralast instead of the stock system. I've put about 3,500 miles or so on it, with no ill effect on anyhting. My electric vest runs a tad warmer and the voltage is not impacted during its use. Has anyone runs some significant load through their system for prolonged periods of time? Is everyone still happy?
I am awaiting a spare rectifier unit from John Rayski, just in case. But given my eperience I don't see why I could not dispense with the stock system and take this. Unless I get a torrent or oppsing views / experiences here.
What says thee?
Kevin
Back in YVR after riding around the world for 2 years. www.nohorizons.net
Malindi is offline   Reply With Quote
Old 01-25-2006, 10:01 AM   #41
bcostell
Oddometer: 192
I think you're far safer taking the new system. I took a trek down Baja before xmas and did some high speed offroad - severe washboard, airborne way too many times, split a tire, destroyed my touratech GPS mount, even my spectacles fell apart! Seeing my gps fly around I can't imagine what would happen to the stock diode board.
I've fitted three of John's systems to the three GS's I'm prepping for my Alaska-TDF trip mid year and like you all I'm taking as a spare is a rectifier/regulator unit. A far lower risk compared to stock. I don't think there's any worry with it being a new untested unit since all of the components are used on other bikes. The only new thing is the actual fitment. As long as you done a quality job of installation I see no probs.
Old 01-25-2006, 11:15 AM   #42
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,420
Thanks B'stel for the feedback. I guess your experience speaks volumes. Did you play around with increasing the wattage any?
Old 01-25-2006, 05:49 PM   #43
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,923
To answer the origional question...
I have an Omega system on my GS. I can run my heated grips and a pair of PIAA 520 lights in town and there does not appear to overload the charging system.
my .02
TEXASYETI is offline   Reply With Quote
Old 01-25-2006, 05:52 PM   #44
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,420
my .02
Do you mean an Enduralast system or an Omega system? We're talking Enduralast here.
Old 01-26-2006, 09:56 PM   #45
sharkey
XLV750R
sharkey's Avatar
Oddometer: 875
I've got a few thousand K on mine and I'm still a happy camper. Make sure you've connected and insulated all the connections well, and that everything is cable-tied into place neatly.
Remember that you can ride an airheads a long way without a
generator if you charge the battery overnight and leave your lights off.
Remember that even remote parts of the world have postal services.
Then box up your old system, including diode board mounts and rotor extractor bolt, and leave that with a friend who can post it to you if all else fails.
-----sharks
Times are GMT -7.   It's 04:07 PM.
