01-29-2006, 08:43 AM
#61 |
Another advantage of the coventional system would be the number of small roadside workshops in remote parts of the world which would actually rewind the rotor or stator for you if needed.
This reminds me of a guy I met about 20 years ago with a Suzuki with a flat battery. This bike model was never sold in Norway. I took him to a shop which rewound his stator and he managed to continue his journey. |
01-29-2006, 09:04 AM
#62 | |
This controller can be found at the Silent Hektik site which is linked from my page. |
01-29-2006, 09:22 AM
#63 | ||
De Jo Momma
Oddometer: 8,699
1) Measure the battery voltage while the engine is running. Is it over 13 volts at about 2500 RPM? If so, everything is fine. 2) If it's not, unplug the Enduralast stator from the regulator. Start the engine. Measure between each of the three wires (AC scale). Do you have about 15-18VAC between ANY pair combination? If so the stator is good, replace the regulator rectifier unit. 3) If any pair of windings is not putting out full voltage, replace both components because there is no way for a mortal to check the regulator rectifier unit. It's simple to troubleshoot but not cheap. So if the Enduralast fails, you're replacing about $400 worth of parts. By comparison, you'd spend a similar amount to replace a stator and rectifier/regulator on a Honda so it's not unreasonable--just not palatable to me. OTOH, the stock and Omega systems use many inexpensive components but are more complicated to troubleshoot. IMO getting rid of the stock diode board and ground jumper harness fixes all of the "problems" with the stock system. Beyond that, it's a reliable design. The Omega is just more output. All the talk about brushes is just whining. As I posted before, every car on the road uses the exact same design. If brush wear really weighs heavy on somebody's mind, check them before a long trip and carry a spare set. Quote:
That one failed at 60K as well (with no warning--and the bike had a stock digital voltmeter). THAT is exactly why I am so opposed to fixed magnet charging systems. We've debated this to death. I just wanted to jump in and present an opposing view.
Greg |
01-29-2006, 10:28 AM
#64 | |
Oddometer: 1,139
This is great info. Thanks Greg and Indian.
Indian recommended fix the diode board problems? Indian, the info. on the Lima Controller is in German. Do you know of an English version? And do you know the price? Thanks again guys. |
01-29-2006, 10:31 AM
#65 |
Oddometer: 1,139
Also, I heard about using a Police model voltage regulator to allow charging at lower rpm's. Anyone know if this is true? It would mean I could cruise at lower revs and not worry about my charging system not charging.
01-29-2006, 10:47 AM
#66 | |
De Jo Momma
Oddometer: 8,699
That solution gets you all of the wattage the system is capable of but remember that it doesn't buy you any MORE wattage. In perfect condition, the stock system is still too weak for high current accessories like driving lights and electric clothing. That's why I went to the Omega. I know nothing about the Lima controller. Indian? We'll turn it over to you...
Greg |
01-29-2006, 12:18 PM
#67 | |
'The SH lima controller-Micro chip automatic controller with a low-loss electric rectifier. Developed for the Martinek Guzzi, which participated with the 24h von LeMans. Improved early load characteristic with higher efficiency under 2000 U/min.' ![]() The unit pictured is for the Guzzi. The graph below applies to both models. Check out the dealer Motoren Israel site which is also linked from my site. There is an English catalogue there too. ![]() SH-K=SilentHektik Lima Controller B-R= Authority automatic controller(police model) ST-R. = Seriel Transistorized Regulator SK-R. = Seriel Standard Regulator The price for the unit: R4132 lima controller 12V 37A with cooling fins €167.00 Indian screwed with this post 01-30-2006 at 10:06 AM |
01-29-2006, 03:34 PM
#68 | |
XLV750R
I don't think there's a clear choice between the two systems: as I've said a squillion times, if I was leaving for Siberia the next day I'd probably install the Omega system because it has a longer track record. It's also plug-and-play, and anyone who understands the BMW charging system will find it easy to check out since it works the same way. As it is, I won't be crossing Siberia any time soon, I do all my own bike work anyway, and I've installed the Enduralast system. It helps that I know a fair bit about electronics, and feel confident installing and troubleshooting this system. I wouldn't recommend it to anyone who is not comfortable soldering connectors, as shoddy installation could lead to rapid failure. However, a properly installed system is, in my opinion, unlikely to fail. Someone mentioned cooling: yes, cooling airflow is critical to the regulator, and indeed to all semiconductors ... failure rate at 110°C is about 35x failure rate at 55°C. This is the main problem with the stock diode board location inside the front engine cases. I'm amazed the Omega system doesn't relocate the diodes somewhere more sensible. -----sharks |
01-29-2006, 07:47 PM
#69 |
Instigator Deluxe
Oddometer: 1,316
Okay, I've made a decision - I'm going with Enduralast for 2 reasons.
1. It is less expensive. Alot less expensive right now. 2. I'm not going to Bungle Bungle Kilimanjahara anytime soon. Okay, 3 reasons. The "test pilots" here don't seem to offer any real reservations about either system. Thanks to all for your information, great logic on both sides, but in the end, both seem to be well suited to my application and one of them is over $100 cheaper.
Life must be understood backwards; but... it must be lived forward. Kierkegaard |
02-01-2006, 12:39 AM
#70 |
Zen Adventurer
Oddometer: 5,239
Fitting a rectifier to an R80G/S
Just updated ...
Feb 1, 2006 http://tinyurl.com/aydkf After a few thousand miles, the next step is to move the Enduralast over to the G/S. I contacted John and got a spare rectifier to take along on the trip. Mounting the rectifier proved unexpectedly easy. I was dreading having to fight for space under the Acerbis tank where I'd only last week managed to squeeze in an alarm system. A visit to my welder netted the simplest of solutions. After debating a bracket welded to something given the tank's hogging of all the frame space, he suggested an aluminum plate right behind the battery. That would allow the battery straps to catch the plate and provide a mounting surface for the rectifier. Since it's about as close as you can get to the battery, this seemed an excellent plan. Below is a pic of the aluminum plate. It's 5.5 X 7 inches. It sits right along the battery (which is the same size) and fits snugly between the battery box and the battery. The rectifier points backwards towards the rear fender. It's completely in the open and does not interfere with anything. I run a full toolbox under the seat, FWIW. The wiring runs downwards. Come to think of this, I should have followed the same system on my RT. I run a smaller diameter Odyssey PC 680 and there is a LOT of room at the front of the battery to do something similar.
On a trip around the world.... details here: www.nohorizons.net |
02-01-2006, 12:59 PM
#71 |
The Road Scholar
My Experience with the EnDuraLast System
I have had one of the EnDuraLast sytems on my hack rig all winter up here in Milwaukee and it has been doing great!
I have a 1982 R100RT with the fold-out fog/driving lights (55w ea, only one turns on at a time), a 55w headlight on the chair, as well as the extra tail/brake light, turn signals, heated grips, and my new GF has commandeered my 'lectric vest when she rides in the chair... I can run with everything turned on above 4,000rpm with no problems. Because I know that A/C current doesn't suffer as much loss traveling over distances, (That is why your house gets A/C current) I put my Rectifier/Regulator back by the battery. Gets it away from the heat of the engine, very short D/C path to the battery, lots of cooling air back there, and plenty of space. The bullet connectors were all cut off and replaced with Posi-Lock connectors wherever a wire needed to be extended/joined. Same for the stator plug. They have a great solid mechanical grip, are field removable/reusable, and don't require any special tools. I have used them for quite a while in many applications with great results. www.posi-lock.com Tapped into switched power at the coils. Right out in the open and handy, and on the dual-coil models, there is even an empty terminal on top of the coil just waiting for a female blade connector to be put on! Though I may change that and take it up into the headlight shell and plug into the contact board inside of there... Get the connection out of the elements, and reduce the miniscule chance that any additional draw on the coil feed wire will affect ignition performance. But it hasn't that I have noticed... I will try to get some pictures of my installation posted over at my site and let you all know when they are up. Malindi - That plate looks like a good idea. Just make sure that you have countersunk fasteners on back so you don't wear a hole thru your battery case...
Karl Kugler www.theroadscholar.net 2005 BMW R1200RT w/Hannigan-LT sidecar 2002 BMW R1150RA In Memoriam: Harley, 1993-2010 You will be missed. |
02-01-2006, 03:17 PM
#72 |
Oddometer: 1,139
Hey Karl, thanks for the info. Is that a rubber mount I see for the rec./reg.? If not, I wonder if that would be a good idea.
02-01-2006, 05:55 PM
#73 | |
Zen Adventurer
Oddometer: 5,239
02-01-2006, 08:41 PM
#74 |
Oddometer: 1,139
So, would it be a good idea to rubber mount it, or would it not make a difference?
02-01-2006, 08:49 PM
#75 | |
Zen Adventurer
Oddometer: 5,239
