Old 04-06-2006, 08:07 AM   #91
BMWzenrider
The Road Scholar
BMWzenrider's Avatar
Oddometer: 1,130
Originally Posted by Malindi
The bike's sleeping at the airport today ... ready for a crate to be built tomorrow and off it goes. I leave Sunday, so I'll be out of touch for a while...
Kevin
Have loads of fun on your adventure!
Wish I was still young and healthy enough to do something similar, but a 43yo with busted-up knees is probably not the right person to be taking on the world...
I did not realize that you had doubled up the connections of the SAE plugs the way you described in your last message. You won't have any problems...
Hit us back with updates as you can while you are gone.
Karl
I'm not weird; I'm gifted.
BMWzenrider is offline   Reply With Quote
Old 04-07-2006, 07:20 AM   #92
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,421
Originally Posted by sharkey
You have fun, Kevin! Look us up if you're passing through Melbourne, Australia ...
-----sharks
Sharks .. will do. Got your message via Ross as well. I won't be on ADV much in the future, but email still works all the time. kevin@berettainc.com. And I'll keeep the site updated. www.nohorizons.net
Back in YVR after riding around the world for 2 years. www.nohorizons.net
Malindi is offline   Reply With Quote
Old 04-07-2006, 07:21 AM   #93
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,421
Karl
I'm only 5 years behind you ..... My knees are still ok. Mind, probably not so good ....
Old 05-22-2006, 10:02 PM   #94
Crush
Oddometer: 994
So Now..........
How's the Enduralast holding up for those of you that installed one? Any notable improvements or problems compared to the Omega?
Crush is offline   Reply With Quote
Old 05-23-2006, 02:09 AM   #95
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,421
Fine for me. In Greece for the moment on my RTW. Into Turkey tomorrow. It's hot here...
Old 07-09-2006, 05:01 PM   #96
Mendodave
Road Scholar
Oddometer: 949
How is this for rectifier mounting?
R80G/S, the rear of the battery plate would not work, no space. i put it where the old regulator was, offset from the mounting plate.
under the tank, and close to some ignition part i think.
it is pretty close to the other part
How hot do these get, can one of you tell me? This will be under the dakar tank.
Thanks for any input.
David
MSF RiderCoach
'81 R80G/S 'Moby'
'82 CT110 "Postie'
Mendodave is offline   Reply With Quote
Old 07-11-2006, 01:56 PM   #97
BareRider
Oddometer: 70
That rectifier disipates all unused power as heat. It will/can get very hot. Take it's capacity (400+watts) and subtract all your electrical loads (battery charging, ignition, headlight, running lights, heated vest, grips, etc.) and whatever's left is dissipated as heat from the rectifier (think of the heat from that wattage lightbulb). The permanent magnet systems govern their output only by the RPMs of the engine thus all power must be disipated to somewhere either a useful load or heat.
Keep it in an cooling air flow or the heat may destroy it or something nearby.
Good luck,
richard
BareRider is offline   Reply With Quote
Old 07-11-2006, 11:51 PM   #98
cnycl
User Awaiting Email Confirmation
cnycl's Avatar
Oddometer: 106
Malindi,
Where are you going to stay in Turkey?
If you need help or suggestions I'm an e mail away.
Have a nice ride in Turkey
Best regards
cnycl
cnycl is offline   Reply With Quote
Old 07-12-2006, 02:11 AM   #99
Tony Graf
Oddometer: 489
convert
I am an Enduralast convert, rotor died @ 100 miles from home the other day. Had to bum a ride home (hey buddy, would you mind going 100 mile out of your way ). Took the battery from the 1150 and brought the old girl on in, it is always an adventure on my airhead...love it!
Tony Graf is offline   Reply With Quote
Old 07-12-2006, 02:55 AM   #100
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,421
Cnycl,
I'm in Damascus for the moment, waiting for a visa for Iran. I am staying in Gaziantep for a few days when I go back up, then to Dougobayazit to Iran, with a stop in Tatvan.
On the other reply around heat... I can tell you that the rectifier does not heat up at all. I run without extra wattage, just stock, and even when I was at the Dead Sea (122F), it felt no hotter than the frame. Shows 14.2 volts at all times. Works like a charm so far ... 13K miles or so...
Cheers,
K
Old 07-12-2006, 06:56 AM   #101
cnycl
cnycl's Avatar
Oddometer: 106
Tatvan is my ancestors native country, strange town beside the van lake.
Don't forget to visit nemrut, the second biggest crater lake in the world.
Actually three lakes (one salty, one regular and one hot lake) on the mountain top.
You may also visit Ahlat there, you may see the ancient stone cemetary from the Selcuk Empire and ancient stone houses built from ahlat stone.
Also buryan is the traditional meat dish. You may like it if you taste it.
Old 07-13-2006, 12:47 AM   #102
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,421
Thanks for the info. If you check www.nohorizons.net you'll find some pictures of Nemrut.
Old 07-13-2006, 07:15 PM   #103
sharkey
XLV750R
sharkey's Avatar
Oddometer: 875
Sorry, no. It is a switch-mode regulator, not a shunt regulator. See the tech information on the EME website.
My experience is similar to Malindi's ... except mine is mostly commuting miles *grumble grumble sulk*. Regulator barely gets warm, battery sits on 14.2.
-----sharks
sharkey is offline   Reply With Quote
Old 07-17-2006, 11:02 PM   #104
Mendodave
Road Scholar
Oddometer: 949
Rode test
spelling intentional
well, i can say with personal knowledge that california is damn hot!
530 mile weekend, 320 yesterday, still not on reserve on the dakar tank, either. damn i like that.
over a hundred almost the whole way, and the rectifier was cooler than i.
nice bright light, no dimming instruments at idle, never did get a chance to run the heated vest or grips, sorry.
engine off, 12.5 volts
at idle, it was 12.8 volts.
anything above 1500, 13.5v
running, and mind you i live where straights are hard to find, rpms are all over the place, it went from 13.5 to 14.2. some of you are saying 14.1 all the time and i wonder a bit about that. not too much.
but holding 70mph for hours this weekend the voltage on my 276c readout did vary in that range. seems to me a hot setup should be stable? yes i have a ground wire, yes i checked it. i do tech support, hit me with your best shot!
the old beeyatch ran fine. there is a definite whine, but not annoying.
thanks for the help
http://nt-1.mcn.org/gs80/thestable.jpg
david
MSF RiderCoach
'81 R80G/S 'Moby'
'82 CT110 "Postie'
Mendodave screwed with this post 07-17-2006 at 11:04 PM Reason: d'uh url, dude
Old 07-18-2006, 06:56 AM   #105
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,421
thanks for the help
david
You won't know the real voltage until you hook up a meter. I find the Garmin units to be about .4 to .5 low on the readout. See my site for some pics of the Datel meter I had on the RT and which now lives on the G/S.
http://tinyurl.com/bncde
Times are GMT -7.   It's 04:51 AM.
