Old 04-27-2014, 05:29 AM   #46
kbroderick
Oddometer: 1,041
Originally Posted by slartidbartfast View Post
Wish I could find some winter gloves designed for heated grips - Nice thick insulation on fingertips, thumb and backs of hands but none on palms - Not only would be warmer but would elminate this squeezing problem.
Someone pointed out a Rev'It glove designed for this task; I'd recommend the Held Warm N Dry, although they're a bit tough to get in the U.S. at the moment. They're not quite a full-on winter glove, but with heated grips, I've found them plenty warm enough a bit below 40' Fahrenheit; if you had wind-blocking hand guards, which I don't, I expect they'd be fine and dandy well below that. My experience is that the Held gloves are a much better value than the Rev'its...they're still pricy, but they have the build quality to back it up. I have a pair of Rev'it rain gloves (I forget the model at the moment), which are pretty decent, but not at the same level of quality as the Helds. The biggest difference seems to be that they're missing the final touches—the liners want to pull out with your hands when you take them off, and they don't have a finger squeegee. No such issues with the Helds.
kbroderick is offline   Reply With Quote
Old 04-27-2014, 08:20 AM   #47
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,855
Originally Posted by dwoodward View Post
Like this? Google "Heated grip gloves" for more. Warning- these are not cheap...
Rev'It! Fusion GTX Gloves
Tailor made to work with your heated grips, the Rev’It! Fusion GTX glove makes do with a slightly thinner construction to take full advantage of the heat transfer. And though the insulation material might be thinner, the winter riding properties of the Fusion GTX are as tough as ever. Protective, waterproof and very comfortable are all key words here with this premium motorcycle glove.
Do these actually have an unlined/uninsulated palm and insulated back or are they just lightly insulated gloves? The description implies the latter.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 04-27-2014, 08:22 AM   #48
kwb377
kwb377's Avatar
Oddometer: 205
For those who hate to wear gloves, I hope you have a really good friend lined up to assist you while your rashed hands heal. You know, someone that will wipe your ass for you, pull your pecker out when you need to piss, bathe you, etc.
My father suffered burns to his hands when I was a kid, and my mother had to do everything for him for about 6 weeks. Not something I want to experience.
~ IBA #55309
'11 Ninja 1K
'04 200 EXC
'82 GS650G
http://www.bikepics.com/members/kwb377/
kwb377 is offline   Reply With Quote
Old 04-27-2014, 03:52 PM   #49
Falconx84
Lurker
Oddometer: 371
Its been said a couple times before but I feel its worth mentioning again.
I held off on buying a crampbuster/ throttle rocker for years because I thought it would get in the way and only be good for interstate travel. I decided to buy one when I did my fly/ride from flatistan (aka Florida) figuring it wouldn't hurt with no curves to speak of.
I haven't taken it off since, 10k miles later. Once I found the sweet spot it allows me to have a looser grip on the bars while maintaining better throttle control.
Turns out that my gloves were stretching slightly through the day and I was gripping the bars much firmer than necessary to compensate.
V-Strom DL1000k7
Falconx84 is offline   Reply With Quote
Old 04-28-2014, 06:56 AM   #50
Jim Moore
Jim Moore's Avatar
Oddometer: 13,168
I've got a pair of Held Steves that I don't think I'm ever going to wear out.
I don't think I could wear a pair of gloves named "Steve." Who came up with that?
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 04-28-2014, 09:06 AM   #51
dwoodward
dwoodward's Avatar
Oddometer: 5,352
No clue, but I know there are some out there like you're asking for. I had a pair, but they still had too much insulation. Caveat: My heated grips go to '11'.
I wear the Held Steve's, which have some padding on the back and are unlined. If it's going to be below 35 or so for more than an hour of the ride, I just throw the handlebar muffs on, then I can wear my favorite summer gloves.
dwoodward is online now   Reply With Quote
Old 04-29-2014, 02:49 AM   #52
Idle
Oddometer: 700
Hmm, so I should not wear gloves because my hands likely will contact the ground first. Sounds legit...
I think I will put my hands in my pockets at the first sign of trouble to be safe.
I also will train my body to overcome the laws of physics so I can remain in the fetal position, tumbling gracefully along the tarmac. This will allow me to roll well clear of my sliding bike, as well as eliminate any possibility of getting road rash. There will be no need for pants.
Idle is offline   Reply With Quote
Old 04-29-2014, 04:04 AM   #53
Mat
Mat's Avatar
Oddometer: 444
Well at least he still had fingers. My motorbike trainer told me about a guy he knew who had minus two fingers after he thought no gloves is fine. They were just sanded down in a relatively minor crash. That was enough to convince me.
For me it is Kangaroo. Almost feels like you wear nothing: super flexible, thin, and (hopefully) quite wear-resistant. Apparently they can be as annoying as deer if you live in that part of the world, but what do I know.
Good gloves are well worth the money.
So you just stick your Steve in the muff, got it.
Ah the joys of being childish never get old
I think there might be a more scenic route somewhere...
Mat is online now   Reply With Quote
Times are GMT -7.   It's 07:26 PM.
