Old 04-16-2014, 09:47 AM   #16
kojack06
kojack06's Avatar
Oddometer: 376
http://usrack.com/cradle_motorcycle_carrier.php
One of the best accessories I purchased to hold the bike and to help load it.
kojack06 is online now   Reply With Quote
Old 04-16-2014, 09:52 AM   #17
Shunka
Supervision Required
Shunka's Avatar
Oddometer: 3,952
Few years ago. Lasted 6500 mi family trip. I did use two additional rachet straps from the bike frame to the rear anchor points in the truck though. Didn't use a wheel chock.
Check bike and straps at each stop.
Shunka is offline   Reply With Quote
Old 04-16-2014, 10:29 AM   #18
crazyjeeper
crazyjeeper's Avatar
Oddometer: 391
I use a wide tri-fold ATV ramp and ride the bike in. The Tenere is ratchet strapped from the crash bars and the XR from the handle bars. I use large padded hook straps from tractor supply. I drove 2400 miles with them like this without a problem. There is also a 3rd strap from the luggage rack to the side of the bed on the Tenere to keep it from moving towards the center, same with the bungee around the back tire on the XR. I also bolted a big loop into the bed to act as the center tie point.
2012 Yamaha Super Tenere, 1997 Honda XR650L, 1985 Honda XR350R, 1976 Honda GL1000 Goldwing
crazyjeeper is offline   Reply With Quote
Old 04-16-2014, 10:38 AM   #19
JonU
Oddometer: 821
What I do when I put my bike in the truck is to put at an angle so that I can close the tailgate. The front wheel goes in one cornwr and the back goes in the opposite corner. Then I use two straps with one going to a rear tiedown and the other going to the front tiedown. Leave it in first gear and get it strapped down nice and snug and it doesn't budge at all. Here is a crude sketch of what I'm talking about.
Sent from my SCH-I605 using Tapatalk 2
JonU is offline   Reply With Quote
Old 04-16-2014, 10:56 AM   #20
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,654
I put a concrete block in the bed in front of the wheel to keep from bending the panel, I had an old floor mat under and in front of the block to not tear up the bed too. Soft ties just above the lower triple clamp with tie downs to the holes in the front pockets - no load on the bars and good triangulation. Do the rear to the back pockets, back wheel will stick out over the tailgate, but no problem. Wrap up and tie up the extra tie strap after pulling them tight. Most of the time for short hops I only do the front ties.
Use the rear view mirror to take a look on occasion to make sure nothing is loose.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 04-16-2014, 11:44 AM   #21
OkieJoe
Oddometer: 44
Pretty good video here
http://rideapart.com/2013/05/how-to-load-a-bike/
In Training For The Wilford Brimley Look-Alike Contest
OkieJoe is offline   Reply With Quote
Old 04-16-2014, 12:47 PM   #22
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,575
Originally Posted by DAKEZ View Post
Say... A Gas Gas... Isn't that a TRIALS bike? Can't you just hop it up into the truck?
bike loading: level 1 for sure. I used to HATE loading my GS. so freakin tall and crazy heavy. I always thought it was going to kill me
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time.
T. S. Eliot
Originally Posted by Burnszilla
I was SO high, I could have hunted duck with a rake
Originally Posted by VxZeroKnots View Post
MX stuff isn't my cup of tea, but falling down the side of a mountain is
eatpasta is offline   Reply With Quote
Old 04-16-2014, 12:48 PM   #23
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,575
That's amazing
T. S. Eliot
Old 04-16-2014, 01:33 PM   #24
CaseyB
Adventually
CaseyB's Avatar
Oddometer: 522
Originally Posted by eatpasta View Post
That's amazing
Certainly is. We both go about it the same way. I of course could only verbalize it till now
Only thing i do different is add a strap to footpeg or skidplate - going forward to stop movement
CaseyB is online now   Reply With Quote
Old 04-16-2014, 02:49 PM   #25
Grreatdog
Grreatdog's Avatar
Oddometer: 11,082
That is how I do it. In both my current Ranger and old Toyota it almost doesn't need straps loaded like that. But it gets four anyway. It doesn't take any pressure of the forks loaded that way. You only need enough tension to keep the wheel straight.
525EXC, 640 Enduro, XT200
Grreatdog is online now   Reply With Quote
Old 04-16-2014, 03:46 PM   #26
farmerstu
Oddometer: 455
i'm going to chime in here and try to bust a myth. compressing the forks hard will not damage the seals.(providing they are not overfilled to begin with).
think about it . you have a freakin enduro bike that can withstand a 10 foot drop with no suspension damage. think bottoming the forks with a ratchet strap is going to blow the seals? what will hurt thou is hitting a big pothole with the pickup and watching your bike fall over because the strap came unhooked when the bikes suspension compressed.
otherwise they way we do it is (typically with a 650 KLR is one person grabs it by the lower fork and handlebars on each side and set the front end in. then grab the rear rack and pick up the back and push it in. front wheel in the corner one ratchet strap from lower triple tree to each side. ratchet down tight. two more ratchet straps from rack to center stake pockets.
usually it's my son or son in law helping but my wife and i have done this alone.
farmerstu is offline   Reply With Quote
Old 04-16-2014, 04:12 PM   #27
tokyoklahoma
75%has been25%wanabe
Oddometer: 1,617
Laugh how not to
Someone has to serve as a bad example.
http://youtu.be/z2EfBPgwi8E
I noticed that no one has mentioned keep the bike in gear (not running), and use the clutch as a sort-of emergency brake while pushing it up or down the ramp. If things start to go sideways, just let off the clutch and the bike will stop rolling and you can concentrate on it not falling over.
You can call me TKO
tokyoklahoma is offline   Reply With Quote
Old 04-16-2014, 04:30 PM   #28
holckster
dougholck
Oddometer: 834
Originally Posted by Mr_Gone View Post
I don't know how well you can see the straps in this photo, but it's a good representation.
NO !
Wrong for BMW's. OK for telescoping forks.
Never strap a Telelever front end BMW down by the handlebars, they will bend.
Straps around the fork tube over the front fender is the proper way.
http://www.youtube.com/watch?v=_6v8dy5XwZg
Additional straps to the frame or crash bars recommended.
For bikes with centerstands, DO NOT USE when hauling, allow suspension to do it's job.
I prefer a trailer, low with wide dropdown tailgate/ramp.
Doug Holck
Lodi, CA
3 Continents - 7 Countries - 50 States
04 BMW 1150GS Adventure
08 DR650
02 BMW K1200LTe
05 Yamaha TW200
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
holckster screwed with this post 04-16-2014 at 04:47 PM
holckster is offline   Reply With Quote
Old 04-16-2014, 04:40 PM   #29
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,575
Dirt bikes are so dammed light it almost doesnt even matter how you do it. Going out the races you see every imaginable configuration of bike loading you can imagine and after awhile it kind of just boils down to preference.
I do like the diagonal configuration because bein able to close the gate is nice. I do it sometimes that way if I have the time or care that much.
street bikes..... different sport all together
T. S. Eliot
Old 04-16-2014, 04:42 PM   #30
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,575
FYI; how not to
T. S. Eliot
Times are GMT -7.   It's 09:40 AM.
