Old 04-16-2014, 08:09 PM   #1
broncobowsher OP
broncobowsher's Avatar
Oddometer: 1,799
When do I need a new tire?
OK, how long does a rear tire last? I was cleaning the bike up and looking at the tread blocks. The leading edge is now worn to ~3/8" radius and the trailing edge ~1/4" radius. Not sharp square lugs anymore. Still soft rubber from poking it with a fingernail.
I am sure upper class riders would have replaced it long ago. But what about a lowly Novice rider? At what point should I consider replacing it?
broncobowsher is online now   Reply With Quote
Old 04-16-2014, 08:24 PM   #2
DerViking
Shred
Oddometer: 354
I run mine until the knobs are completely round, and pretty short.
I'll put on a new tire for Ute Cup, where it makes more of a difference, then take it off and save it for later. Most of our CAT sites have so much traction that it doesn't matter much. Jones Crossing when wet is worth the trouble. Kingman Mtn Site as well.
I have found that putting on a new tire after riding awhile on a really tired tire makes for a little boost in my learning curve.
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly.
DerViking is offline   Reply With Quote
Old 04-16-2014, 08:34 PM   #3
broncobowsher OP
Oddometer: 1,799
It was Alto Pit where I felt like I was just getting a ton of spin and not hooking up. Thought it bit better in the past. Lets seen next two events are Kingman and Jones crossing. When has it not rained for Jones crossing?
I'm really trying to figure if I need the tire or not. Was it the tire, the really dry Alto pit, or was it just me?
How is that new Gasgas anyway?
Old 04-17-2014, 05:07 AM   #4
lineaway
Oddometer: 3,098
In the dry southwest I`ve seen them run until almost no nobs are left by the top riders. Some how they still seem to get more traction than the lower class riders.
lineaway is offline   Reply With Quote
Old 04-17-2014, 05:10 AM   #5
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,037
We run em till they are shot around here. I just ordered one to have when we move into the forest areas later this summer. I'm sure that it makes a difference up there.......maybe.
I've see some top riders have no problems whatsoever on cooked tires
Also seen Smage come through a few different times and his tires were toast. He was pulling out of deep sand like a demon with nothing but little chevron nubs where the knobs used to be.
Btw, the Michelin I just ordered was $170. WTF? A truck tire is about the same!!!
Gordy is offline   Reply With Quote
Old 04-17-2014, 05:32 AM   #6
lineaway
Oddometer: 3,098
That`s why I run these. https://www.denniskirk.com/643074.sk...FdBcMgod0HAAjg
Old 04-17-2014, 06:02 AM   #7
DerViking
Shred
Oddometer: 354
Alto can be a little ravely. Large diameter grains make for low traction even by the standards of sand. I often lower my pressure a bit there, maybe 3.5psi? just enough to keep it from acting too weird on the rock. Like Gordy says, its all technique. A really fresh tire is nice though, if you can afford it. I too have found the Dunlops to be great tires, and the price is much better than the Michelins. Only flats I have ever had on the back have been the Michelins sidewall cutting, though my triple stack plug is still holding from Oak Flat.
Haven't ridden Johns new GasGas yet. We'll see if he lets me. I am going to mate his Eco with my Pro. I'll have a 2009, 2007, 2000 GasGas, as many of the parts on my Pro are taken from my 2000 parts bike.... Gonna try the jug swap that Motobene has done, and see if I don't have a bike that will last another year or two.
Old 04-17-2014, 06:45 AM   #8
motobene
Motoing for 44 years
Oddometer: 1,562
I have long used only the Michelin X-11. I've tried the other tires but nothing seems to work as well a Michelin for me.
The new X-Lite rear is a bit vulnerable in the sidewall for my tastes, so I don't buy it. I do use the X-Lite in front, however. It's very close to the same weight as the previous, but it feels really good as it tracks.
As for how worn? In my area we have a lot of dry dirt and gravel, and some rocks but with very small grains. While a sharper leading edge on knobs isn't absolutely critical, it does help me hook up. Before the Comanche Cup, my Raga's X-11 had rounded leading edges, roughly a 1/4" edge round on each knob. So I flipped the tire around just before the event, and I believe that gave me a 'bit of an edge' over my fellow competitors. I was running my usual 4-1/2 psi. With the retardation mods and a steady throttle hand, I was sticking like glue in places that were hard to walk across without sliding down.
If I rode mostly sticky rocks like out west or at Ravia/Tishomingo, OK (come to our amazing Sooner Cup 26&27 April) I'd probably just let the tire shred to little nubs.
motobene is offline   Reply With Quote
Old 04-17-2014, 12:49 PM   #9
Monty348
Monty348's Avatar
Oddometer: 67
For those of us who pinch pennies, an electric kitchen knife will easily cut the knobs shorter. You loose the small kerfs from the knobs but gain square edges. Less depth of tread may be an issue for the upper class. Just sayin'.
Monty348 is offline   Reply With Quote
Old 04-17-2014, 02:02 PM   #10
broncobowsher OP
Oddometer: 1,799
I was thinking of replacing next year simply due to age. I guess I will stay with that plan.
Old 04-17-2014, 06:33 PM   #11
lineaway
Oddometer: 3,098
Cutting tires is fine for areas with mud. But cutting or flipping the tire, just wears it out faster and wasting time. As stated previously, Smage shows up with a tire with inverted knobs and does not spin at all!
Old 04-17-2014, 06:36 PM   #12
motorcyclemark
motorcyclemark's Avatar
Oddometer: 165
Have only tried turning the rear tire over once and have to admit felt no difference (tire was two thirds gone at the time) might have even felt worse on the braking side. Their is something to be said for the mental aspect of having a new tire in bad conditions even at my level.
motorcyclemark is online now   Reply With Quote
Old 04-17-2014, 06:38 PM   #13
broncobowsher OP
Oddometer: 1,799
That probably has more to do with the skill of the rider.
Old 04-17-2014, 07:07 PM   #14
2feetdown
Oddometer: 107
I have always rotated when one side worn. Currently riding michelin that came with bike after rotating vrubber. but if i tire of too many flats on the vrubber and Michelin i may go to dunlop.
2feetdown is offline   Reply With Quote
Old 04-17-2014, 07:25 PM   #15
slicktop
Oddometer: 280
I jumped on a new Mich comp for the front but may go for the Dunlop on the rear after the flipped Mich rounds off.
slicktop is offline   Reply With Quote
Times are GMT -7.   It's 07:43 AM.
